Hi guy's I am looking for some advice regarding the B7 2.0 TFSI motor.
I purchased the car recently and it had very rough idle and used to rev up to ~2000 RPM at junctions and try and shake itself to bits at around ~500 RPM so I replaced the PCV valve and improved it a great deal.
Prior to replacing the PCV valve I had a fault code stored on the ECU - P0171 Bank 1 too lean, I cleared this and it went away after replacing the valve for a couple of hours then came back, the rough idle was much better.
The engine still feels slightly under-powered and I have noticed that once the engine is up to temp the idle sits around 1100-1200 RPM which is not right so I can assume that I have a hose split or faulty sensor maybe?
Another thing to note is that when engine braking in 3rd or 2nd gear it feels like it is still pulling rather than slowing, maybe that is just me coming from a Skoda Octavia VRS Diesel to a petrol unit I don't know but it does not seem correct.
I have had the car in to be looked at today and the technician had checked for a vacuum leak and plugged in the VAG-COM diagnostics, sure enough the P0171 code is still present, however he could not give me a diagnosis.
What the guy suggested was to pull off all of the hoses and inspect them, however I aint got a clue where to start - any ideas?
Rob.
Rob.
