Volks AutosEM Tuning
Results 1 to 32 of 32
Like Tree2Likes
  • 1 Post By Chr1sch
  • 1 Post By lynallbel
Thread: Mileage versus Engine work done
    Molnboman's Avatar
    Probably has been done to death this one....but am bored...hahaha
    Curious as to know what sort of mileage you have, versus work done over and above normal service ( belts, oil etc ). Extra points clearly go to highest miles still on original main bits without engines blowing up etc etc.
    Shall I start.... my 2.0t petrol FWD, BGB Engine currently on 219,800 kms = (136018 Miles ), still on original clutch, turbo, top end etc. Changed dv, pcv, thermostat, cam follower and that's about it.
    What you got?.....Make sure you comment what engine Model you have petrol, diesel engine model if known.
    A
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,928
    b8 18T 133k
    nothing done except belts tyres discs and pads
    craigcull's Avatar
    Oct 2011
    Leeds uk
    993
    Visit craigcull's Youtube Channel
    Still had original clutch at 100k, did the cambelt just to be sure at 88k, did the cam chain and tensioner at 95k as it was noisy. Coil packs at 77k, diverter at 80k. Other than tyres and brake pads, not really done much else serious in 3 years of ownership.
    K04 hybrid turbo. S3 injectors, Autotech hpfp internals, RS4 fuel pressure regulator, custom FMIC, APR carbonio intake, decat pipe, milltek cat back non resonated 100mm tips, unicorn developments custom remap, launch control and flat shift. Valet mode, economy map and full power map options. Stage 3 southbend clutch with single mass flywheel, Eibach pro street coilovers, eibach front and rear anti roll bars, porsche cayenne 6 pot calipers front, S4 rear brake conversion.
    North East
    568
    2005 2.0tdi ............
    A/C Compressor replaced at 45,000miles
    Front Discs replaced at 56,000 miles
    Oil Pump /Balance Shaft/Water pump and Timing belt Kit at 68,000 miles
    Turbo replaced at 88,000 miles
    EGR Valve replaced at 93,00 miles
    A/C Compressor replaced again at 95,000 miles
    Rear Discs replaced at 98,000 miles
    Original clutch and DMF still going at near the 100K mark.
    This is the most expensive Audi I have ever owned and I have been driving Audi for thirty years. Its also the first and last diesel I will have.
    Molnboman's Avatar
    Quote Originally Posted by Paul B7 View Post
    Jaysus, Paul that's a lot of bits Mate?!!.....am interested to see how the petrols compare to diesels .....clearly, there will be a few expensive reports from some am guessing.
    Interesting point that I also have been through two sets of discs since May 2012 myself....
    A
    North East
    568
    Smile
    Quote Originally Posted by Molnboman View Post
    A
    Petrol for me next time as well.
    scotty76's Avatar
    Nov 2011
    Berkshire
    803
    I have 2.0T FSI FWD. Done 38k miles. I've done routine servicing, cambelt and tyres so far. That's it.
    scotty76's Avatar
    Nov 2011
    Berkshire
    803
    Ooops, missed one thing. DV was changed at the same time as Shark remap.
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    789
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    A4 3.0TDi
    • PAS pump replaced @ ~60k miles (under warranty).
    • NSF wheel bearing replaced @ ~60k miles (under warranty).
    • NSF wheel bearing + housing replaced @ ~75k miles.
    Last edited by A4_MaJiK; 25th November 2013 at 10:23. Reason: Additional information.
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
    Nov 2012
    Worcestershire
    89
    2007 (56) Avant 2.0T Quattro (Special Ed)
    109k
    Cambelt @ 83k
    PCV & Rocker Gasket @ 83k
    New Coils @ 83k - never had them done under warranty!? (free 6yrs later - happy days)
    New Clutch last thursday on 108k
    Very reliable and a great car
    Incredibly reliable cars (its had a few wheel bearings with the previous owner)
    Nov 2012
    Worcestershire
    89
    to add - i do oil and filter every 10k to be safe....
    Mar 2010
    Cleveland, North East
    200
    2007 TDI 170 Quattro.
    4x Injectors + Loom
    DMF + Clutch
    Oilpump/Balance shaft
    EGR Cooler
    Pretty bad for a 64,000 mile car, all work was done by the previous owner though except the EGR cooler. To be honest it was the main reason I bought the car.
    sidibear's Avatar
    Looking for Zombies !!
    Nov 2008
    Birmingham UK
    1,907
    2008 B7 A4 2.0TDI 109K
    DMF
    Oil cooler
    Expansion bottle and system flush
    Cambelt
    Battery
    Oil level sensor
    Air flow meter
    Dealer serviced as per service schedules.
    JSD 2.59
    Synergy-Solutions
    Molnboman's Avatar
    Quote Originally Posted by Chr1sch View Post
    Me too every 10k - 12 km's for me...emotive subject on the Forum I know, but cheaper than a tank of gas.
    BR
    A
    scotty76's Avatar
    Nov 2011
    Berkshire
    803
    10k miles is about 18-20 months for me. When should you change the oil if you are doing low mileage?
    scotty76's Avatar
    Nov 2011
    Berkshire
    803
    Sorry, forgot to qualify that. My mileage is A road + motorway, not short journeys. I'm aware if you are doing lots of stop start then a different regime might apply.
    Jul 2013
    2005 2.0tdi 92,000 miles
    injector recall 30,000 miles
    10k interval services
    cambelt, tensioners and water pump 85,000
    (Thats all the history of engine work i can find)
    still running strong, touch wood no issues yet
    i can see other things done but its all part numbers so not sure if anything else has been done
    Molnboman's Avatar
    Quote Originally Posted by Matt10160 View Post
    Matt what engine code are you running out of curiosity?
    BR
    A
    Oct 2013
    269
    Quote Originally Posted by scotty76 View Post
    I would say annually gives someone a chance to look under the car as well.
    Nov 2012
    Worcestershire
    89
    I do 30k motorway miles a yr, but service every 10k, it makes such a difference, engine is smooth and starts/runs like a dream for mileage - amazed to see that the petrols appear to be more reliable than the diesels!
    chasdrury likes this.
    North East
    568
    Its really just the 2.0tdi units which are the dogs. The 1.9tdi and the 3.0 tdi units are generally GREAT engines.
    Jul 2013
    BR
    A
    blb
    Dec 2012
    Birmingham
    218
    2007 2.0tdi 140
    158k
    serviced reguarly about every 15k
    new glow plugs @ 153k
    oil pump upgraded in the past
    multitronic gearbox oil changed at 75k
    thats all, eveything else all original and runs perfect.
    Molnboman's Avatar
    Scotty, that's a very emotive question that. If your mileage is mostly motorway, than stop start city stuff, I personally wouldn't have it in my car more than 12 months max'. I would change mine every six month max, no matter what the milage was. Now I know I will get pelters for that from other Forum Members, but I have always done this without fail on most cars I have owned with turbos, diesel and petrol. I don't use VAG long life either just the best fully synth 5 40 ( am in Sweden remember ) my garage has at the time Castrol, Mobil etc...and change the filter always.
    Just can't imagine leaving oil in my engine for more than 12 months ( longlife or not )....and the cost of oil and filter change is less than a full tank of petrol. Not sure if it's psychological or not, but I always feel that car sounds and drives better with fresh juice in there.
    A
    Oct 2013
    269
    Im probably repeating myself here!, but ive always said oil cheap engines expensive.
    Molnboman likes this.
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    1,907
    Quote Originally Posted by sidibear View Post
    DMF
    Oil cooler
    Cambelt
    Battery
    Oil level sensor
    Air flow meter
    110k another DMF
    JSD 2.59
    Synergy-Solutions
  28. #27
    Luke2.0tdi2006's Avatar
    Oct 2012
    West London, U.K.
    171
    '06 A4 2.0tdi (BRE)
    around 138,000 miles
    Cam belt + Tensioners
    Water Pump
    Disks/Pads all round
    Oil level Sensor
    EGR Valve
    Clutch switch
    Tyres
    Rear ashtray cover!!
    Apart from a bit of a rough idle and kind of ticking noise whist idling the car runs like a dream, I love it and would never have any other car other than an audi again!
    I'm considering replacing clutch and flywheel, don't really need to but I do get quite a bad judder if I really floor it in 1st. If driven 'normally' it's fine.
    Totally agree with Molnboman, I regularly service the car (every 6k) changing ALL filters (Air, Fuel, Pollen, Oil) each time. Oil is the blood of the engine and the fresher/cleaner the oil, surely the better? For the price of an oil filter - £7, sump nut - £0.50, and 4L of oil - £29.99 (Castrol Edge from costco!) it's a very small price to pay to keep your engine a 'happy one'......IMO
    P.S. I've never changed the power steering fluid.... Should I? and what would be the symptoms of me needing to?
  29. #28
    Oct 2013
    269
    Ive never really bothered to do a whole oil change on any car pas system ive owned, but if using a vac tool to do the engine oil change its just as easy to stick the nozzle in the pas reservoir and empty it, refill with fresh atf.
    We change every other fluid at set intervals on the trucks but never the pas atf, but the filter is done every 2 years.
    Check the cars atf spec as some motors run some funny old stuff and it may not mix with std atf
  30. #29
    A4B8Sline's Avatar
    Jan 2012
    Exeter, Devon
    135
    Mine- 2009 A4 B8 Avant 2.0tfsi 211hp.
    43k new clutch and flywheel under warranty. Juddering when pulling away.
    53k rust repairs under warranty.
    65k more rust repairs under warranty.
    70k complete engine rebuild due to oil consumption parts replaced big end pistons rings etc. Also water pump and cam chain changed while this was carried out. Head is original along with the turbo. Costly to me but 70% covered by audi.
    Tyres brakes etc changed when required. I will run the car upto at least 100k and make a judgement on if it's worth keeping depending on further work required between now 77k and 100k. Great car slightly disappointed by big repairs encountered. Would like to say audi dealer has been fairly good with warranty issues when in and out of warranty.
  31. #30
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    654
    Right, not all engine related.
    2005 3.2fsi 97k had 2.5 years:
    Oil every 6 months
    2 sets of spark plugs
    2 sets of tyres
    Front and rear discs and pads
    Brake hoses
    Both top chain tensioners
    Battery
    Cam adjustment valve
    Aux. belt
    Electric fan
    DMF and clutch
    Clutch switch
    Thermostat
    Temp sensor
    2 Coolant
    2 gearbox pinion bearings replaced along with gearbox seals
    2 gearbox oil
    Rear diff oil
    MAP sensor
    Coil packs
    Oil pump
    Driver adaptive xenon
    Both xenon bulbs
    Intakes removed and valves decarboned (gaskets and seals replaced)
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
  32. #31
    North East
    568
    Quote Originally Posted by rizzini7 View Post
    Oil every 6 months
    2 sets of tyres
    Brake hoses
    Battery
    Aux. belt
    Electric fan
    DMF and clutch
    Clutch switch
    Thermostat
    Temp sensor
    2 Coolant
    2 gearbox oil
    Rear diff oil
    MAP sensor
    Coil packs
    Oil pump
    Both xenon bulbs
    If that had been a horse I would have shot it !
  33. #32
    rizzini7's Avatar
    Jun 2011
    654
    Lol, yeah. It's. Come very close several times
  1. Any work done from Hazzydayz?
    By drnutta in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th September 2009, 15:20
  2. Some of the engine work i've been doing: (1.9TDi)
    By evomaster3000 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 27th April 2009, 22:14
  3. Update on some engine work I've been doing: (1.9AFN)
    By evomaster3000 in forum Diesel forum
    Last Post: 20th February 2009, 19:46
  4. 90Q20V engine work in PA, USA
    By MLC in forum Classic Audi Forum
    Last Post: 13th April 2004, 23:22
  5. Should I get this work done on my 1996 A6?
    By cble8869 in forum Classic Audi Forum
    Last Post: 12th December 2003, 16:42
