Sky InsuranceVolks Autos
Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By jdp1962
Thread: TRIP Computer
    Sep 2009
    45
    TRIP Computer
    My 2006 A4 1.8T S-Line has no trip computer-WTF!?!?
    Astonishing considering MK5 Golf TDIs have them.
    Is it possible to retrofit using a cluster with trip computer?
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    728
    You should just need the wiper stalk with trip and someone to code it in. I've got a spare saloon stalk if interested
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
    Sep 2009
    45
    Are you sure its that simple?
    I was told I need the cluster and the stalk
    27,121
    Do you actually have a dis fitted, just not trip data in the display, if no dis at all then yes its a cluster job, if has dis then needs stalk fitting & coding, we offer these services.
    rizzini7's Avatar
    Jun 2011
    728
    Sorry didn't realise you can get nondis free clusters. Just assumed they all had them but the dis wasn't turned on like mine when I got it
    Sep 2009
    45
    DIS??
    Sorry for being a noob but can someone explain what DIS is and perhaps some pics to compare DIS & non DIS clusters??
    Sep 2009
    45
    OK Driver information display. Not sure. I have a central display with lines seperating the different sections.
    I have miles until empty, outside air temp and something else but no button on stalk to scroll through other functions.
    Does this mean I need just the stalk?
    rizzini7's Avatar
    Jun 2011
    728
    Yeah, should just mean you need the correct stalk and then someone with vagcom to code it for you
    27,121
    Mazi if you do attempt yourself, be very careful as breaking any of the parts in the way can end up costing £200+ to replace & can render the car unusable, so be careful.
    Sep 2009
    45
    Can you PM me a price to fit and code the stalk
    27,121
    What's your general location?
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,682
    I can can heartily endorse this sentiment. My inept attempts to feed a cable for my DRLs into the fuse box left me with a £350 bill and very lucky not to lose my ECU altogether. Unless you are really confident of knowing what you're doing, pay a professional to do a professional job.
    NHN likes this.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Sep 2009
    45
    Edinburgh
  1. trip computer reset
    By imported_oldboyracer in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st September 2007, 22:14
  2. Retrofit trip computer
    By Joel_Croft in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th August 2006, 07:56
  3. Trip computer - display losing digits
    By spiker in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st October 2005, 22:01
  4. Trip computer boost gauge?
    By Soupie69uk in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd December 2004, 12:50
  5. Audi 90Q20V trip computer
    By MLC in forum General Technical / How To
    Last Post: 13th April 2004, 23:35
