Results 1 to 23 of 23
Like Tree4Likes
  • 1 Post By A4_MaJiK
  • 1 Post By lynallbel
Thread: 3.0tdi heavy steering - help
    Oct 2012
    Midlothian
    248
    Twice in the last month my steering has been very heavy at start up. After driving a short distance then switching off and on a couple of times it was fine. Fluid levels look OK , does anyone have any ideas?
    PS this is going to sound daft but the first time it happened was after resetting the service indicator ( i had to reset it again to get the servotronic working) then for a few weeks everything was fine until I paired a new phone, even more weird was that once I turned the blutooth on the phone off it went back to normal!
    Can't think how these could be connected, any ideas before I pay for a scan?
    Oct 2013
    367
    Simple things first, oil level okay?, drive belt okay, not shiny and no cracks on the grooved side.
    Any leaks onto the drive belt, causing belt slip?
    All pulleys running in line, look down from above with a torch when engine is running.
    Theres loads more things, but thats the basic stuff covered.
    Oct 2012
    Midlothian
    248
    Ta, levels and belts look fine, no funny noises from the rack or sounds of slipping, it did it again this morning but this time servotronic would mot come on until i had done about 5 miles and did a quick restart. A m thinking it is more likely electrical than mechanical, does anyone know if a faulty relay could cause this?
    Oct 2013
    367
    What is servotronic?, some sort of parking aid?
    Have you had battery tested, clutching at straws i know!
    Lynall
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,658
    Quote Originally Posted by lynallbel View Post
    Lynall
    Servotronic is the brand name of the variable assistance power steering used by BMW, Audi and others. In essence, it provides more assistance (i.e. lighter steering) at parking speeds and less assistance (hence heavier steering) thereafter.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Oct 2013
    367
    So more electronic trickery to go wrong!
    Im guessing theres some sort of electric/hydraulic valve that control the flow/pressure of the oil?
    Oct 2013
    367
    Just looked on partbase, all the pump side is std gear, the servotronic bit is built into the rack itself, they also list non servotronic racks.
    There is a pic of a short loom down to the rack itself.
    Oct 2012
    Midlothian
    248
    Thanks, electrical trickery is right. Battery is fine.
    TPS. quoting £111 plus vat for a new servotronic control relay going to get it scanned first.
    Does anyone else have experience of this, it's doing it every morning now, think the service light/phone were pure coincidence.
    I can only find one other thread and the symptoms are a bit different from mine
    Oct 2013
    367
    Well if its a rare fault that means a second hand relay could be a good bet?
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    817
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    Had exactly the same issue on mine. Turned out to be the servotronic relay/module. I sourced a second hand one from eBay for about £15. As it was from an A6/A8, the characteristics of the steering were different. It made my steering heavier sooner than usual (which I actually prefer).
    If you know anybody with an Audi with servotronic nearby then it might be worth swapping modules to see the outcome?
    Azeem
    Stevieb2905 likes this.
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,658
    Quote Originally Posted by A4_MaJiK View Post
    Azeem
    I remember that episode. It seemed to consume your life for about three months before you cracked the case, didn't it?
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    817
    Quote Originally Posted by jdp1962 View Post
    It certainly did Jeff. Boy am I glad to see the end of that one!
    Oct 2012
    Midlothian
    248
    Thanks Azeem,
    There are a couple on ebay just now, a B7 one for about £60, the A8 ones are a lot cheaper so will maybe go for one of those. Fingers crossed,
    cheers
    Steve
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    817
    Best of luck with it mate. Hope you get it sorted. Keep us all updated with how it goes regardless.
    Oct 2012
    Midlothian
    248
    Will do, just got to decide which module to go for now.
    incidentally mine seems to be temp related as well, if I keep the module in the house overnight it works fine, just need to decide on whether I should maybe move further south
    Oct 2013
    367
    Can you not open it up and look for a dry solder joint?
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    817
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    817
    I believe I bought the 605 relay which was for the A6.
    Oct 2012
    Midlothian
    248
    Actually thought about opening it up but TBH would't have a clue what to look for. Azeem's link shows an internal view which has put me right off that idea. I'm going to see if my RAC warranty will cover a new one but will keep checking on ebay in case a 640 or 605 (none on at the mo) come up at a sensible price.
    It works fine when warm so I'll keep it indoors overnight or maybe see if I can find a wee fleecy jacket for it
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    817
    Had a look under the dash today and turns out I'm using the 392 control module and not the 605.
    Oct 2012
    Midlothian
    248
    Thanks very much for going to that trouble, much appreciated.
    Given the choice i would prefer the steering to be slightly heavier than stock, ie a module that gives about half the assist of a 640, i wonder what the one from the S4 would be like. There are a couple of 356s on ebay just now but have no idea what they would be like. I'll hang on until the warranty people make a decision before diving in
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    817
    Quote Originally Posted by Stevieb2905 View Post
    No trouble at all pal, was changing the clutch switch anyway.
    Oct 2012
    Midlothian
    248
    Quick update. Bad news is that I had to part with £133 for a new 640, good news is that after a bit of wrangling - is it a module? (not covered) is it a relay? (covered) - my warranty company have agreed to pay for it. Also covered 2 new reversing sensors so I'm well chuffed.
  1. VCDS help - heavy steering
    By InnerGuard in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 24th July 2012, 21:07
  2. Heavy Steering and Battary warning light on ___ Help
    By rockfanatic in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 1st July 2007, 18:32
  3. Power Steering - HELP PLEASE!
    By god_thats_quick in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th March 2006, 12:24
  4. VERY noisy power steering, HELP!!
    By MehdiB in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th October 2005, 19:59
  5. heavy steering
    By rasA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th September 2005, 16:36
