Volks AutosChris Nott
    Sep 2012
    20
    Help, running (idling) issue
    I've got a 2.0tdi SLine SE (170) and recently had the cam belt and a service done (separate)
    I had no issues that I noticed before or after the cam but since the service it idles lumpy at cold start. I can't think of anything that would have been done during the service that could cause this.
    Any thoughts?
    I have experienced a slight hesitation a couple of times before the cam and service.
    The injectors have been done under the recall.
    Any thing I can try before I get stung by the dealers, basics please I'm not 100 tech minded so no techie talk - simples please
    Sep 2012
    20
    Any help guys??
    Molnboman's Avatar
    Holidays are probably the reason for the slow replies Matey. Sorry, can't help other than recommend you take it to your friendly neighbourhood indie garage who can run a diagnostic check on it. Could be quite a few things....but a diagnostic check could point you in the right direction.
    Wouldn't have thought a cambelt change ( if done properly ) shouldn't be the root cause.
    BR
    A
    Jul 2013
    East Lancs
    46
    Any other symptoms? I have the same as you, except mine also produces excessive amounts of black smoke under acceleration and just when ticking over. I havEnt had my cambelt done recently but it's been suggested I might have a vacuum / boost leak somewhere, like a split hose. See my thread for more info.
  1. Audi A3 2.0 tdi sportback 2007 reg, poor idle issues help!
    By dawudbhai in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th November 2012, 13:10
  2. 3.0 v6 Idle issue . Throwing codes p0101 p0102 . Any help appreciated
    By J.quattro in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th September 2012, 13:48
  3. A4 TDI 110 IDLE ISSUE(Yes guys,another thread looking for help lol)
    By Keithsri in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th April 2010, 10:52
  4. A3 Idle issue, help needed
    By Crashlanding in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2009, 14:21
  5. help: irratic idle
    By in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2004, 21:02
