EM TuningAH Fabrications
    Feb 2013
    Wiltshire
    290
    any a4/s4/rs4 owners in Wiltshire/Bristol can help?
    Hi all,
    I am trying to get my parking sensors working again, and in the mean time I have removed the parking control module (part no. 8e0919283c) and wanted to know if anyone near by fancies letting me test my module on their car. I am not sure if its my parking sensors that are fubar (i know one defo is now as the car hit a block of wood on the motorway at 80mph that fell off a truck!) or the module. If i can plug the module in your car and see if the sensors post an error, then I need to replace the module. Failing that I may have to replace 1 or 5 parking sensors (4 rear, 1 front).
    Thanks guys. If anyone knows of any other way of testing to see what the problem is then give me a shout (i have done a vagcom test).
    26,716
    VCDS will log the system, it will say this sensor is down etc usually, what did vcds say?
    Feb 2013
    Wiltshire
    290
    Code:
                    Address 76: Park Assist       Labels: 8E0-919-283-8EC.lbl
    Control Module Part Number: 8E0 919 283 C    HW: 8E0 919 283 C
      Component and/or Version: Parkhilfe 8-Kan H06 0020
               Software Coding: 0001104
                Work Shop Code: WSC 06335 000 00000
                          VCID: 30650E19A038729
    4 Faults Found:
    01545 - Sensor for Parking Aid; Rear Left (G203)
                009 - Open or Short to Ground
                 Freeze Frame:
                        Fault Status: 01101001
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 3
                        Mileage: 0 km
                        Time Indication: 0
                        Date: 2000.01.01
                        Time: 00:00:00
    01548 - Sensor for Parking Aid; Rear Right (G206)
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 3
                        Mileage: 0 km
                        Time Indication: 0
                        Date: 2000.01.01
                        Time: 00:00:00
    01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
                004 - No Signal/Communication
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 3
                        Mileage: 0 km
                        Time Indication: 0
                        Date: 2000.01.01
                        Time: 00:00:00
    01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 3
                        Mileage: 0 km
                        Time Indication: 0
                        Date: 2000.01.01
                        Time: 00:00:00
    26,716
    I would check the loom.
    Also that's a fake counterfeit cable.
    Feb 2013
    Wiltshire
    290
    Thanks for that... think i might take the rear bumper off and do some continuity checks on the loom itself. Shouldnt be too difficult, as the main loom to the front will be fine, just the rear wires to and from the sensors.
  1. Any B5 RS4 owners near Manchester/NW?
    By mattfinn in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 26th April 2009, 00:32
  2. Any B5 RS4 Owners in Yorkshire
    By leecs3 in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 2nd July 2007, 10:42
  3. Will, RS4 owners from Birmingham?
    By NBirkitt in forum General Chat
    Last Post: 12th July 2006, 11:54
  4. Any 1.8 T owners de-catted?
    By JayB5UK in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th January 2006, 15:46
  5. Another happy RS4 owner
    By imported_simond in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 13th August 2004, 08:15
