JMB RetrofitsEM Tuning
Results 1 to 25 of 25
    May 2011
    Suffolk
    310
    Fuel filler flap locking actuator
    Hi all
    Started fitting the Cobra rear parking sensors earlier to my Avant, Had to remove the Bose system to get to a couple of the nuts, which exposed the broken actuator for the locking system for the fuel filler flap, great chance to replace it now
    Has anyone removed one of these as i cant actually see the head of the two retaining screws, they appear to be in the inner wing. Anyone and ideas on how to remove it please?
    The picture below isn't my car but you can see the problem of removing it. Thanks for looking
    27,108
    IIRC when I removed from someone else's, you had to loosen them with alan key & slide it out of position.
    May 2011
    Suffolk
    310
    Nigel. Are the Alan key heads hiden in the inner wing on the reverse of the actuator ?? so you're working blind as such?
    27,108
    No, afaik they're the ones facing you, so you have full view of what you're latched onto.
    The heads on the other side are what holds the item tight against the chassis.
    May 2011
    Suffolk
    310
    I may be looking at totally the wrong thing Nigel but i cant see how i can get a alan key to fit on the front of the actuator.
    I looked again tonight and also looking at the picture i posted, the two fixings poking through at bottom left and top right aren't alan key heads
    am i looking at this right mate??
    27,108
    What a twit I am, sorry I must have been in work mode, it states you need to use an hexagonal socket to undo them, apologies.
    May 2011
    Suffolk
    310
    Thanks buddy, sorry didn't like to doubt you. Do you mind me asking where you saw the info regarding requiring hexagonal socket to remove??
    27,108
    Hey doubt me lol, I made a mistake & rightly pulled up on it
    Well I've removed a few myself & also the audi bible lol.
    May 2011
    Suffolk
    310
    Haha! would you kindly take a look at these pictures Nigel? it shows the screw heads on the back of the unit. But as you say, can i remove it by fixing a hexagonal socket on the front of them and turning anti clockwise??
    #2110 Audi A4 Sport 3.0 V6 Quattro B6 01 - 04 Fuel Filler Cap Locking 8e0862153 | eBay
    27,108
    Yeah you should be able to fit hexagon socket & remove either clockwise or anti, you'll figure it out
    May 2011
    Suffolk
    310
    Thanks mate, Last question i promise.... Would i be better off getting this part from Audi main dealer to avoid another premature failure??
    27,108
    Thats your choice lol, but if its cheap enough just get from audi for a 2 year warranty.
    May 2011
    Suffolk
    310
    Thanks. that link i posted is the only used one i could really find on the e of the bay.
    Jun 2011
    Great Melton Norfolk
    1,356
    A new one from VW around £22+vat.
    May 2011
    Suffolk
    310
    Quote Originally Posted by gen.heinz guderian View Post
    Cheers for that. Hey! you're just up the road from me, i'm just south of Diss!
    Jun 2011
    1,356
    I have one i took off my mk4 Golf as it had jammed up. Its sitting in my Garage if you want it . Bloody thing worked perfectly as soon as I went to remove it.
    Jan 2013
    Unhappy I need to do the same..
    Quote Originally Posted by tuffy View Post
    Hi,
    I've just bought a 2007 A4 Avant, and I have the same broken actuator problem!
    It looks like a real conundrum to get the old part off and a new one on without taking panels off!
    Can you let me know how you did it in the end as I can't understand how you can unscrew 2 screws when the heads are hidden?
    Jun 2011
    1,356
    If I remember correctly they turn the opposite way to what would be normal, Was a pain to get out ,literally. Fitting new one was minutes .
    Jan 2013
    So what tool did you need? My guess is that you're turning the screws from the "wrong" end, so need something like pliers to grip and turn them... Is that the answer?
    Many thanks for your help...
    Jon
    Jun 2011
    1,356
    Yes, I used long nose pliers and a very small wonder wrench that grips any bar and doesn`t slip.
    May 2011
    Suffolk
    310
    Quote Originally Posted by Jonny747 View Post
    Jon
    My new actuator turned up today, delivered to my door from Audi £13 all in!! From looking at the new unit i still cant see how to remove/fit
    When you grip the hexagonal end of the screws that's visible inside the boot and undo them, buy the time the end had disappeared into the actuator the unit still wont come free from the cars body!
    Real head scratcher as others have said its a easy job, maybe i'm looking to hard and cant see the wood for the trees!
    My new actuator may soon be on ebay!!
    Jun 2011
    1,356
    If you can get to/reach the actuator try lifting it manually, spray some wd or the likes down the shaft. Move it up and down lots.
    Try the button and see if it releases
    May 2011
    Suffolk
    310
    Mine has snapped clean in half buddy.
    Jun 2011
    1,356
    ah i see. Can you get a pic of it? Are you working this week? I can give you a hand if you want.
    May 2011
    Suffolk
    310
    Thanks for that buddy. Car is completely immobile at the moment, its 6ft up in the air with no wheels as they are away for refurb and the sump is about to be dropped for balance shaft inspection. I may call on you when its all back together.
  1. fuel filler flap lock stopped working - anyone else had this?
    By M7R in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 7th May 2010, 14:43
  2. Fuel filter air lock - 2.5tdi - 180
    By S2 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 11th April 2008, 23:03
  3. Fuel Filler Necks
    By grathies in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th January 2008, 21:43
  4. Hissing from fuel filler cap
    By BigJC in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th January 2007, 22:59
  5. Fuel filler flap
    By Amchlolor in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th February 2006, 14:06
