Volks AutosSky Insurance
Results 1 to 8 of 8
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    Fans not turning off 3l tdi
    Hi guys,
    First post in this section - my father has a 2006 3l tdi avant. Recently the drivers side fan won't turn off when the ignition is switched off, thus draining the battery when parked up.
    Quick search brought up a few posts about the temp sensor malfunctioning and going into safe mode I.e. constant cooling? Can you helpful bunch shed any light on this?
    Many thanks from a lowly 8l s3 owner
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    820
    I'm presuming you mean engine fan?
    Not heard of this before... but scan it for fault codes and see if one of the sensors is giving a bad reading. Hopefully it will just be a simple replacement of a sensor
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
    JD09's Avatar
    Dec 2009
    3,080
    Apologies, yes the engine fan. There are two and only drivers side is on so wondered if this pointed to something specific. Sadly I don't have my lead, might have to take it to a garage to get it scanned.
    Mar 2012
    Essex
    118
    When you say 'won't turn off' does it stay on until you start it again, ie. next morning?
    I'm sure my fans stay on after the engine is off until it's happy the engine is cool enough then it switches itself off. Normally only for a few minutes when hot.
    JD09's Avatar
    Dec 2009
    3,080
    Unfortunately not - it runs indefinitely, until the battery is dead.
    i_786_i's Avatar
    Aug 2012
    57
    Re: Fans not turning off 3l tdi
    Hi, on a previous car (not audi) narrowed down a similar problem to a dodgy fan switch/thermostat which kept the fan running on.
    JD09's Avatar
    Dec 2009
    3,080
    Thanks for this. Going to get a mechanic to look at it to make sure as I don't have my vcds.
    Aug 2012
    Leicester
    9
    Any joy mate?
  1. Stereo help does not turn off with key!
    By JA50N in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th April 2012, 19:45
  2. lights not turning off!!! :@
    By audi-tk in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th September 2011, 23:25
  3. Service Light will not turn off
    By Boydie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th October 2010, 14:46
  4. Cooling fans,not turning off
    By evocos in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th April 2010, 15:29
  5. Brake lights not working? and front fogs wont turn off?
    By VTI_EG_DAN in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th February 2009, 18:34
