Sky InsuranceChris Nott
Page 1 of 6 123456 LastLast
Results 1 to 40 of 225
Like Tree17Likes
Thread: my DTM 'build' - story so far, hybrid K04 - custom FMIC
    olethalb's Avatar
    Aug 2012
    314
    when i joined i said i wasn't going to make a 'build' thread as not a lot was going to be done to this one, unlike my old bora.
    this is still the case but i had a little thread on uk-audis as a record of what has been done, but they've recently upated the site and i cannot get on with it at all so i'll transfer what i have done so far.
    spec - A4 TFSI permanent quattro DTM LTD edition made in 2006 to celebrate audis success in DTM racing
    as i bought it - 220bhp k03 turbo recaro half leathers and DTM specific carbon extras
    first things first - new fuel pump tappet and cam chain and tensioner to keep things sweet
    and after the work spruce the bay up a little
    olethalb's Avatar
    Aug 2012
    314
    after the engine had been treated it was time for wheels, these came up fairly cheap so snapped them up
    next was to 'joey' the headlights and de tango
    soon after the long awaited coils arrived
    and with 12mm spacers a little fitment
    also ebayed a leather arm rest
    olethalb's Avatar
    Aug 2012
    314
    more power was on the cards so started accumulating parts
    k04
    DV
    one stage cooler plugs
    s3 injectors
    with more to follow.....
    the DTM comes with 320mm front discs which aren't the best so upgraded to S4 345's
    aux belt tensioner started clicking so on with a new one
    olethalb's Avatar
    Aug 2012
    314
    the rotis came with tyres but size wasn't ideal so i changed them for 215/35's and tweaked the ride height a little
    and purchased a new reg from DVLA
    after having a lot of bits and bobs on order from UK and USA they started trickling through
    ATP 3" decat
    polybush snub mount
    milltek cat back system
    Autotech HPFP internals
    olethalb's Avatar
    Aug 2012
    314
    the day of exhaust fitting came
    when i removed the original cat the wastegate flap had disintegrated from vibration
    all i could do at that piont was weld the flap back to the arm....
    fitment of the milltek went well until it came to the tailpipes
    they stuck out far too much so had to trim an inch off each tailpipe trim
    they still didn't sit evenly in the cutouts in the bumper so i had to cut a bracket off that regulated the distance between the pipes and weld a correct sized rod in between
    the left pipe would not sit high enough no matter how much tweaking so i had to splice the tailpipe trim and reweld
    perfecto
    olethalb's Avatar
    Aug 2012
    314
    as i was gearing up for the K04 swap i spoke to MRC who advised FMIC - the kits i had seen weren't too impressive, either required bumper chopping or losing the crash bar, neither was an option
    i measured up and went for a core intended for another audi
    then set about mocking up custom hard boost pipes with a variety of ally bends
    mocked them all up to size and correct path making no contact and gave them to my ally welder
    also decided to weld the s3 dv flange to the boost pipe
    painted and fitted
    olethalb's Avatar
    Aug 2012
    314
    next was the modified k04
    tt225 outlet welded on
    downpipe bolts repostitioned and rethreaded
    test fitted
    bolted up
    intake with recirc inlet for DV
    front end slotted back on with no mods or trimming
    DIY heatshield box
    now it was all up and together next was MRC for mapping
    made 330bhp and 350 torque but had budget fuel and clutch was dying
    well fitted a new clutch yesterday, brimmed it with optimax and went to RR day today but was too low for the rollers
    olethalb's Avatar
    Aug 2012
    314
    oh one from Surrey RR day today - ignore the tit in the wifebeater
    few more pics - one from players
    one with new honeycomb satin grill
    and completed the de-chroming with some carbon fibre mirrors
    olethalb's Avatar
    Aug 2012
    314
    also fitted BSH PCV fix but will be making custom catch can set up
    refitted stock 'D' diverter valve
    near future mods include:
    better custom intake set up
    custom manifold / turbo heatshield
    better p/s fluid cooler
    WMI kit
    uprated intank pump
    make a new crash bar
    source 'open' grill or make my own
    remap (3rd time lucky)
    next year will be fbsw and some new wheels i think
    Jun 2011
    Manchester
    248
    Excellent write up and cracking looking car. Hats off to you sir.
    Did you wrap the chrome mirrors in Carbon or replace them completely?
    2005 B7 A4 2.0T in Moro Blue
    Interior, Number Plate & Sidelight LED's from T8ups, 18" 9 Spoke TT Wheels.
    BGB Engine Code.
    olethalb's Avatar
    Aug 2012
    314
    mancdan - thanks, i replaced the covers completely. got these ones from felondnb off edition38
    Jun 2011
    Manchester
    248
    whats edition 38?
    Also,dso you still have your chrome mirrors?
    BGB Engine Code.
    Macdoon's Avatar
    Essex
    1,564
    Quote Originally Posted by mancdan View Post
    whats edition 38?
    Here ye go fella
    Edition 38
    Mac
    A4 B8 (09) 2.0 TFSI (211)
    Black Gloss RS4 style mesh grille, Black Gloss fog grilles, Black Gloss splitter trim, Ice White fogs, Tints, Black A8 boot rings, Black Badges, Dynamik boot spoiler, LED interior, LED number plate lights, Brushed steel vinyl wrapped interior.
    stuiwhite's Avatar
    Jul 2012
    Bristol
    52
    Car looks awesome!
    Is that grille off eBay? - apologies if this offends!
    Just, I want one!
    Thanks,
    Stui
    Past fleet:
    2001 Saxo VTR (To bridge gap to A4!)
    1996 Toyota Starlet GlanzaV
    2001 Ibiza Cupra
    1996 Honda CRX Del Sol (B18C4 powered)
    2008 SEAT Ibiza
    1998 Peugeot 106
    http://www.audi-sport.net/vb/project-room/171641-stuiwhite-a4-b7-1-9-tdi-se-build.html#post1706798
    Nov 2012
    Norwich
    34
    Is that all you've done lol
    AudiB7Jay's Avatar
    Nov 2012
    370
    Soooo unfair! I wanted rotiform blq 19's on mine once lowered! You beat me too it :/ looks sweet too!
    Did you have to add spacers with them? What kind of alignment settings you running too? How far did you lower by also?
    So jealous right now lol sweet car
    chrisa4quat's Avatar
    Sep 2004
    897
    This is a great thread! Exactly what I want to be doing to mine!! Are the s4 pads and discs a straight fit?
    Imola Yellow A4 DTM. Retro fit cruise and arm rest.
    Contact Admin to advertise please
    ANDYTQ's Avatar
    Oct 2003
    Caerdydd, Cardiff, United Kingdom, United Kingdom
    942
    Looks stunning, i'll be the last to fit my ko4 at this rate lol,cheers Andy
    06 A4 AVANT QUATTRO 2.0T S-LINE SE,GARNET RED, RS4 REAR ARB,SPACERS ALLROUND,H & R SPRINGS,B5 PERCHES,A6 V8 RIMS.PORSCHE CAYENNE TURBO S SIX POTS .REVO ST2 MAP ,MILLTEK CATBACK EXHAUST,PANEL FILTER,034 INTAKE PIPE.
    Sep 2004
    897
    Doubtful Andy ill be one of the last! Lol
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    just about, right here!
    3,751
    easily the best DTM i have seen!
    well done fella!
    Sep 2004
    897
    Agreed!!!
    Dec 2010
    222
    That car looks mint mate credit to u fella I have a yellow one great car
    Jun 2012
    Newcastle uk
    79
    What a beaut! Do the s4 disks and pads just fit the original dtm callipers or would I need a fitting kit ? Cheers! ❤
    Sep 2004
    897
    I'm still waiting to see if they do too Jez. That would be my next mod if they do as I need brakes soon!
    Molnboman's Avatar
    Wow.....that's a lot of beer tokens spent on that! Amazing stuff and lots of ideas there too! Well done Sir.
    A
    BA4
    Jun 2012
    Ireland
    76
    really really nice car, best of luck with it
  28. #27
    Olly P's Avatar
    My other cars a mk2 Golf GTi
    Dec 2008
    Oxford
    686
    Awesome DTM, given me some ideas!
  29. #28
    olethalb's Avatar
    Aug 2012
    314
    wow - quite a response over the weekend :0
    mancdan - it's a vag forum. i think the covers got thrown out, it wasn't 'til i removed them i saw they were ebay copies.
    Macdoon - thanks
    Stui - yes ebay item, i was after the more open holes but it's only available from Australia at the mo with £145 postage
    Morgan46 - yes, not a lot in comparison with my last car
    AudiB7Jay - they have 12mm spacers on the rear, all allignment is stock but obviosly had to have tracking done. i didn't take measurements, just lowered it so the front and rear arch to tyre distance was even and there was no contact.
    P.S Roti's will be for sale next year
    Chris - i was told to fit S4 fronts all you need is discs pads and S4 carriers, i fitted the carriers to my DTM calipers and popped the discs and pads on but the very top and bottom of the caliper contacted the disc. i could have ground a bit out but i picked up the proper calipers for cheap enough and bolted them on.
    ANDY - thanks, i still have my dead one sat on the bench
    CHEZ - thats quite a compliment, thank you
    Sewell - thanks, do you have a thread? i'd like to see a yellow one
    Jez - see reply to chris above RE brakes
    Molnbowman - i had my last car 'show car' bora up for sale but decided to break it so when something sold i'd treat the A4.
    BA4 - thanks, i need some after my turbo died
    Olly - thanks, and thanks for spelling 'Olly' in the correct way
  30. #29
    ANDYTQ's Avatar
    Oct 2003
    942
    Pipework looks really neat,where did you source the front mount from?
  31. #30
    Jun 2012
    Newcastle uk
    79
    Cheers mate! One more quick question....
    Do you have a guide, or a link to the one you used to get rid of those awful orange reflectors?
    thanks ))
  32. #31
    Olly P's Avatar
    Dec 2008
    Oxford
    686
    Clear corner mod:
    DIY: CC (Clear Corner) Mod
    Replacement covers (can just leave them off):
    EURO CLEAR CORNER LENSES NOW AVAILABLE FOR PURCHASE!
  33. #32
    solaris's Avatar
    Slough, Berkshire
    404
    Well done, good to see another DTM with a KO4
    If it's not longitudinal and it's not Quattro..it's not an Audi
    VCDS (VAG-COM) HEX-CAN USB cable carrying member
    2005 A4 DTM 2.0 TFSi Quattro :364Bhp/477NM - Mapped by MRC Tuning
    Hybrid K04 Project ongoing (link to Build thread)
    DMFW + Clutch For Sale
  34. #33
    olethalb's Avatar
    Aug 2012
    314
    Jez - i just went at it i think i must have seperated and redone my bora headlights in different styles about 6 times.
    Olly - thanks, i just went for the leave them off with them chrome / orange bulbs
    Solaris - my turbo died a short time after my first MRC mapping session, so i went to turbo dynamics and bought a brand new item and had hybrid work so it should be the same spec as yours now. ordered a new K revision thrust sensor and RS4 pressure regulator yesterday, next will be uprated intank pump then WMI. i'm hoping to crack 400bhp with the hybrid.
    i'll also be making a tubular crash bar so i can expose the full fmic and will have to buy / make a more open grill - remove or reduce number plate plinth.
  35. #34
    olethalb's Avatar
    Aug 2012
    314
    ANDY - nearly missed you out :0 it's from an ebay kit for a B6, i looked at a lot of cores from jap to RS500 but this fitted my dimension needs best. the hard pipes, silicon joiners and clamps were all binned and custom pipework made up. the pipes that came with the kit were ridiculously narrow
  36. #35
    Golfedd's Avatar
    Nov 2012
    Surrey
    135
    looking good Olly man, Nice to see the full pics and the bits you've done! Didn't realise the level of love you gave this one (it comes as no surprise though) haha. Catch you soon no doubt for some A4 rolling times!
  37. #36
    olethalb's Avatar
    Aug 2012
    314
    i'll be happy when it's making good power with a decent map, you know i can't leave things alone. the bora was supposed to be my sensible car....
  38. #37
    stuiwhite's Avatar
    Jul 2012
    Bristol
    52
    Any build thread of this Bora you speak of - would be nice to see other pieces of art you have mastered!
    Really jealous of this one - wish i had the funds to buy such a gorgeous vehicle!
    Ill have to stick to me SE TDI!
    Past fleet:
    2001 Ibiza Cupra
    2008 SEAT Ibiza
    1998 Peugeot 106
  39. #38
    olethalb's Avatar
    Aug 2012
    314
    haha - there's one on ukmkivs but it's about 70 pages long.... here's the revised one for the US market
    VWVortex.com - UK white bora build
    from
    to
  40. #39
    stuiwhite's Avatar
    Jul 2012
    Bristol
    52
    WOW!
    Ill watch this thread with eager eyes!
    *Tail between legs* - Back to work I go!
    Past fleet:
    2001 Ibiza Cupra
    2008 SEAT Ibiza
    1998 Peugeot 106
  41. #40
    Dec 2010
    222
    All I can say is mint well done
  1. The Story So Far
    By karl88 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st September 2009, 11:02
  2. The 170 story so far....
    By thewallboy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th May 2008, 20:24
  3. A3/S3 Speaker Upgrade - Story so far
    By imported_maviceuk in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2004, 19:32
  4. My new A3 - the story so far... some pictures..
    By h5djr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th July 2004, 17:58
  5. My new A3 - the story so far...
    Last Post: 26th July 2004, 14:05
