Chris NottVolks Autos
Results 1 to 7 of 7
    jakeA42T's Avatar
    Oct 2011
    Gravesend
    90
    BOOT PROBLEMS (WONT OPEN FROM KEY OR DRIVERS DOOR)
    Not sure what happened maybe someone messed it up but now the boot wont open from the drivers door switch or the key, not hat bothered but it's a pain in the backside trying to open the boot with a key.
    Audi A4 2.0T Fsi S Line Multitronic
    Richardesty's Avatar
    loves quattro
    Oct 2008
    Louth
    753
    Sounds like you've lost power to the boot solenoid.
    When mine did this, after a couple of days or so I'd lost all lighting relating to the boot - ie numberplates, rear fogs etc.
    It's a common fault ironically caused by opening and closing your boot.
    There's a bank of wires that sit within a plastic protection tube which is strapped to the left hand hinge. Wires within here fray over time and eventually break.
    You need to strip the protective covering off, locate the broken wire and reconnect it.
    In my case it was the earth wire and I lost the lot.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,525
    as above i had the same
    thick brown wire was my problem.
    jakeA42T's Avatar
    Oct 2011
    Gravesend
    90
    It just failed it's MOT for no REG or fog light so it seems to be the same problem, cheers.
    loves quattro
    Oct 2008
    Louth
    753
    Quote Originally Posted by jakeA42T View Post
    You'll be hunting down the thick brown cable in that case...
    jakeA42T's Avatar
    Oct 2011
    Gravesend
    90
    Quick update, found the broken earth under the left hinge in the side wall of the boot, replaced broken section, heat shrinked, job done.
    Thanks for the help everyone!
    loves quattro
    Oct 2008
    Louth
    753
    Nice one Jake, pleased you're sorted
  1. Lock the car with key and drivers door opens again!!
    By jonnycraig in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th January 2011, 21:55
  2. Drivers door wont open from the outide?? Pics included.
    By SamiG in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th January 2011, 11:38
  3. A8 Flat battery, boot won't open with key
    By DaveA44 in forum A8/S8 forum
    Last Post: 13th May 2010, 07:51
  4. Problem with opening boot
    By Shug1874 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th September 2008, 16:43
  5. passenger door wont open from inside the car...
    By Pete69zx in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd January 2007, 02:22
