Badger5Volks Autos
Results 1 to 12 of 12
    Jul 2011
    Teesside
    327
    "Side lights" light on dash not coming on?
    OK guys, not sure if it ever did to be honest but I noticed this evening that the green "side light" light on my dash to tell you there on doesn't come on. The side lights are on just the dash lights don't show it. All the dial lights, interior bits and bobs ie the window switches, the buttons on my MFSW etc all come on just not the little green lights on the dash.
    Does anyone else have this? Are they ment to come on? I know they do on all other makes but Audi always make things different don't they.
    Could it be the fact I have aftermarket DRL headlights fitted? I don't seem to be able to remember if they came on when I had my standard headlights.
    All the other dash warning lights come on OK just the lights on ones don't.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,420
    mine only come on with full light's
    sides dont show anything only next to the headlight switch
    Jul 2011
    Teesside
    327
    They don't even work with the headlights on. Guess it's just one of those things. I was hoping it was a simple fuse or something. It baffles me how all the other warning lights around them work but not them. I wonder if it is because of the aftermarket lights?
    Oh well, its nothing I can't live with.
    bez101's Avatar
    Jul 2008
    8,420
    might be a dodgey bulb
    i know you cant change them easy
    but they can be done as i had an airbag light go on a b6
    Jul 2011
    Teesside
    327
    What is easy with an Audi
    Its not a major thing, i'll just have to put a lid on my OCD and not let it bug me til I finally give in and spend a fortune getting it fixed when really its nothing.
    Dec 2011
    Glasgow
    194
    As stated in a privious post there's no side lights indicator in the dash on my A4. There is a green symbol on the light switch to say the lights are on then with the lights on if you switch on the main beam a blue symbol comes on to tell you that the main beam is on
    I've never had anything different and was unaware that Audi put side light indicators in the dash could be wrong though
    But that's how its in my car for you
    Failing that if there should be a green light side light indicator then as stated the bulb probably has gone
    A4 B7 2.0ltr TDI Cabriolet
    Mods
    Puddle lights Illuminated cup holder Cd changer in glove box Interior lighting led upgraded
    Full VCDs
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    813
    I assume you mean the light in the centre of the dashboard directly behind the steering wheel and not the light directly above the headlight switch to the right of the steering column? If so this can be enabled via VAGCOM. Tired it with mine but in the end I didn't like the light there so I disabled it again. It's less than a 5 minute job if you know someone with VCDS. But by default (in the UK atleast) it's disabled from the factory.
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,184
    As Murphy says, they are disabled at factory for the UK. I reenabled mine in VCDS, dead quick.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,524
    Quote Originally Posted by JDM82 View Post
    The standard factory coding on the B7 doesn't enable the sidelight warning on the instruments (don't know why).
    It's easily changed with VCDS (I did it on my B7 RS4 within a month of getting it in 2006), see Audi A4 (8E) Instrument Cluster (8EC/8ED/8HE) - Ross-Tech Wiki
    The relevant line is this one:
    • 00??xxx: Options I
      • +00 = 1. K-Number (Europe/USA/Rest of World)
      • +01 = Smaller Fuel Tank Volume (All-Wheel-Drive)
      • +02 = Side Marker Lights Indicator Lamp inactive
      • +04 = 3. K-Number (Rental Cars)
      • +08 = 2. K-Number (Australia)
      • +16 = Clutch Pedal Switch Operation in FIS Display
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Jul 2011
    Teesside
    327
    Ah so there not ment to be on eh. Thats's good to know. Thanks guys
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    816
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    Does this light come on for sidelights, headlights or both?
    RMH1A4cab's Avatar
    I'm in Cruise control
    Jul 2010
    staffordshire
    524
    Both.
    F
    ULL VCDS HEX-USB-CAN Interface available in the staffordshire area pm me.
  1. Near side facelift rear light wanted
    By NineNails in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th July 2010, 22:47
  2. Battery light keeps flickering on dash????
    By codrock in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th November 2009, 21:16
  3. Driver's side map reading light
    By amimmortal in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 15th January 2009, 20:32
  4. intrior lighting not working.. dash not working.. please help
    By patrick swayze in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th September 2007, 12:16
  5. red lights flashing on the dash
    By tonywitney in forum Classic Audi Forum
    Last Post: 27th March 2007, 08:29
