Chris NottMonster Motorsport
Results 1 to 15 of 15
    Mar 2009
    254
    coding xenon headlamps
    hi i am fitting some xenon lights to my b7 at the weekend, got the kafatec cables, what do i need to change on the coding?
    any help would be greatful
    chrisa4quat's Avatar
    Sep 2004
    897
    Depends on spec of car if has rain light sensor etc. Tells you in coding section I think. Good luck! I'm still having issues with mine :-/.
    Imola Yellow A4 DTM. Retro fit cruise and arm rest.
    Contact Admin to advertise please
    Mar 2009
    254
    no auto lights, no rain sensors, just the basic realy mate
    26,762
    If you have vcds, then it tells you within the popup coding helper, what is represented with specific coding.
    Chris, come on lad, you should have that sorted by now.
    Mar 2009
    254
    thanks for replys, i dont know what control module to go to code them in tho, not used vcds much
    Sep 2004
    897
    I should mate. Ain't even had chance to look properly. Will get on it soon hopefully
    26,762
    Quote Originally Posted by marv View Post
    Well if you had levelling it would be module 55, but you also need to go into 09 to code the headlights to the car.
    Mar 2009
    254
    i dnt have auto leveling and i dont have washer jets either, i know the legal side of it as i am a mot tester lol, so just code the lights in 05?
    26,762
    So what is the legal side then?
    Sep 2004
    897
    I thought it has to have washer jets and possibly levelling.
    Nigel still ain't sorted my xenons. Too busy at work. Is there anyone in or near Leicester that you can recommend?
    26,762
    I'm back soon so I would be someone to sort for you if interested.
    Yeah manufacturers have to install systems from factory & afaik its needed for mots now, just wanted to see what he checks.
    Sep 2004
    897
    Definitely mate if you could let me know :-)
    Mar 2009
    254
    the legal side of it is the must have washer jets and auto leveling, if not any of these the they fail the mot
    26,762
    So as an mot tester, you've passed your car for mot illegally, thats a question, not an accusation.
    lenti's Avatar
    Sixth Gear
    Apr 2010
    Sweden
    74
    Quote Originally Posted by chrisa4quat View Post
    ohh man havent you fixed it yet :D thought ive helped to how to do few months ago from the links i gave you :P
    it is Very easy mate i promis u it will take a bout 40min work or less if the front bumper is off
    i did retro fit mine from halogen to bixenon,
    so what youre saying is.
    When you have the High beam does not work and you get a warning?
    if it is that then you have connected them wrong, or coded them wrong.
    the 2 small yellow pins must be connected rigth for the highbeam to work. and also the code must be right.
    use this code and dont change the thre first codes in VAG
    Euro Headlights & DRL
    Module 09 (Central Electrical), recode to ###21
    i think the origininal code for the halogen is 01012
    If u have the code 21 then the lights work but if not the hight beam then you have connected the small yellow pins wrong. i did it to after changing it it worked like a charm :D
    Very easy mate took my about 1hr the first time i did it :D
    You can also read this audizine forum post very easy :D
    DIY: Halogen to Bi-Xenon - Kufatec Interface
    Audi A4 2.0TDI 2007 B7 S-Line & Proline
    Bluefin Superchip
    218HP/443NM
    RS4 Rims
    _________
    For more pics visit my FB http://www.facebook.com/MR.Doberlluka
    For all my mods visit http://www.garaget.org/lenti
    and http://www.audizine.com/forum/member.php/73213-lenti look @ my started threads
  1. S3/S4/A4 Xenon Headlamps
    By marcuss3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th March 2011, 08:11
  2. Anyone Retro fitted Xenon headlamps?
    By Stepho in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 16th January 2010, 22:36
  3. Replace a3 headlamps with s3 xenon lamps
    By u654949 in forum The Welcome Section
    Last Post: 28th November 2009, 19:07
  4. Xenon headlamps
    By BigAlS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2008, 20:36
  5. Xenon headlamps
    By Pontio in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2005, 16:55
