Monster MotorsportChris Nott
Results 1 to 22 of 22
    Feb 2012
    58
    Hello there and a couple of easy questions to ask if I may?
    First of all Hello to everyone,
    I used to own a B6 Avant A4 and hope this is the right forum for my (soon to be)new car which is a 57 (08 reg) Audi A4 (170) re -mapped to 231bhp.
    Anyhow first thing is does this year and model have the electronic handbrake, is it worth keeping the DPF (I am aware of its function but there seem to be a lot of peeps having problems caused by the DPF) what other common faults does this model tend to have or is it pretty much the same as the B6?
    This car also comes with Sat Nav what is the @ cost of getting an updated disc, are they easily to purchase or is it a main dealer only?
    Thanks to anyone who answers my questions I hope to learn a lot from this forum as time goes on.
    Feb 2012
    West Wales
    161
    Cant help as new here myself but would like to know what mpg it is doing with the map. I planned on a 170 and having the dpf removed same time as mapping. Might change to 140 as it seems less problematic.
    Macdoon's Avatar
    Essex
    1,569
    Hello & welcome to ASN
    57 plate owner here, no electronic handbrake.
    Some have had issues with DPF, personally I haven't, currently @ 64k.
    Jump on the search button fella, you will find threads on DPF & other issues.
    Make sure it has had the recall for injectors & looms.
    All in all I'm very happy with my 170.
    Mac
    A4 B8 (09) 2.0 TFSI (211)
    Black Gloss RS4 style mesh grille, Black Gloss fog grilles, Black Gloss splitter trim, Ice White fogs, Tints, Black A8 boot rings, Black Badges, Dynamik boot spoiler, LED interior, LED number plate lights, Brushed steel vinyl wrapped interior.
    Feb 2012
    58
    Quote Originally Posted by Macdoon View Post
    Mac
    Injectors looms !!!!! WTF what have I missed ??? How do I get this sorted do I have to contact a main dealer and is a job that will take a long time etc etc (what I mean is I have a work 6 days per week and commute to work 30miles away!) Looks like I have majorly f up here
    Would someone be kind enough to explain the process I need to undertake if it hasnt had the required recall done, and how do I know if it hasnt will it appear on some service history ??
    Macdoon's Avatar
    Essex
    1,569
    Ring your local Audi stealer, give them the Reg number, they will be able to tell you if it has been done.
    Feb 2012
    West Wales
    161
    Macdoon - can I ask what MPGs your getting from your 170?
    What type of driving do you do - i.e. long journies rather than lots of short ones (the ones that apparently cause the DPF to play up)
    I've got a meeting with the dealer friend of mine this afternoon and I'm still unsure if I'm going to ask him to look for a 140 instead.
    Feb 2012
    Hay on Wye, Wales.
    24
    Quote Originally Posted by zollybosher View Post
    Re mapped to 231 and it still has the DPF in place? Are you sure? Is it PD or Common rail, 57(08) could be either?
    Tunes usually have to be quite mild with DPF still in place for a number of reasons. That seems a big increase without removal. If the tune is too much then you may be at risk of premature DPF blockage.
    Feb 2012
    West Wales
    161
    Met with my dealer friend and he's got a 170 for me. For better or worse the deed is done
    Lion - do you do mapping? Likely to be in for a DPF removal at some point.
    Jan 2004
    York
    1,657
    Quote Originally Posted by Lion Garage View Post
    Yup, I was going to query that as well. Usual safe states of tune for a 170 with DPF is about 210bhp tops.
    MY15 8V S3 Sportback with options
    Feb 2012
    West Wales
    161
    Can I ask a seperate question regarding the Sat Nav.
    If the car has the RNS-E Sat Nav system does that mean it has Bluetooth as well? My mothers has bluetooth and I would like the same. I know the car has Sat Nav but on the BCA website it didn't state Bluetooth.
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,534
    Quote Originally Posted by eddscott View Post
    No, the RNS-E and Bluetooth are separate options.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,534
    Around £200+ from any Audi dealer, but often on eBay for a lot less. But don't be tempted by a cheaper copied DVD, get a genuine one as copies can cause the laser in the DVD drive to overheat and fail. P.S. you can't play DVD videos in the drive in the sat nav.
    Feb 2012
    West Wales
    161
    If you update the disc will it read UK post codes?
    If my 170 doesn't have the Bluetooth module I assume its not a big issue to fit it?
    RMH1A4cab's Avatar
    I'm in Cruise control
    Jul 2010
    staffordshire
    524
    I got mine from here. (hope the link works)
    http://www.ebay.co.uk/itm/AUDI-Bluet...-/320699755870
    Several others on here have purchased from them too so we know they are a reputable seller, couple of hours to fit and code if you take your time.
    (Sent from eBay Mobile for Android)
    F
    ULL VCDS HEX-USB-CAN Interface available in the staffordshire area pm me.
    Feb 2012
    West Wales
    161
    Thanks for that.
    Its annoying because I don't know if the car has bluetooth. I've seen pics of it on the BCA website and I've looked through other listings and it only says Sat Nav, it doesn't specify if the car has Bluetooth already fitted. Its got rear parking sensors which my mothers SLine hasn't so perhaps the original purchaser wasn't too stingy with the options list.
    Already have a list of little mods:
    Rear RS4 ARB
    H&R Springs
    Black grille
    Carbon interior trim
    Front splitter
    EGR clean
    DPF removal and map
    Get Audi to check the injectors
    Fit Bluetooth if it hasn't already got it
    Monitors in the rear headrests would be cool too
    Rear parking camera looks cool
    Puddle lights front and rear
    Flat bottom steering wheel
    Maybe change the alloys but not actually sure which ones it has (I like the 5 spoke SLines rather than the RS mutli spoke type jobs) like LM reps but not sure I want the 19s if its too firm.
    Should keep me busy (and broke)
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    Thanks for that.
    As with BMW, Mercedes everything on the audi is an optional extra mine came with interior lighting pack and lots of other bits but no bluetooth which I've retro fitted as my last post, if it's oem fitted all you need to do is scan with your phones bluetooth to see if it's installed. Also the oem unit if fitted will be under the passenger seat, Retro fits like mine are on top of the glove box. HTH
    F
    drmole's Avatar
    Apr 2010
    Mountain Ash, Rhondda Cynon Taff, United Kingdom
    1,564
    Anyone having DPF issues click the link in my Sig for group buy thread there's a cracking cleaner on offer if you have concerns about removing it
    As for 231bhp with DPF still in don't seem right to me ill check with a member on here who dies remaps as said above I've only heard of 200-210 max with DPF
    My A4 Detailed and finished with Zymol Glasur
    http://www.audi-sport.net/vb/detaili...ol-glasur.html
    A4 S-Line SE 220BHp with full Black pack With black badge (rear one still to fit) two tone Leather, Bose, phone prep in centre arm rest, IPOD conection RS4 pedals suede gear knob handbrake and steering wheel R8 oil Cap
    Jul 2010
    Merthyr Tydfil, United Kingdom
    881
    It's in an A3 but the engine is the same; DPF firmly in place and has been for 10,000 remapped miles
    Give me a shout if you want the same treatment
    Now a happy owner of an A3 Sportback S Line 170 TDI
    My Posh Golf
    drmole's Avatar
    Apr 2010
    1,564
    dirty diesel lmfao love that! cheers Rhys
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    You're not going to get 230hp with a remap and DPF in place, at least not with the standard turbo setup.
    We can DPF remove and remap at the same time no problem.
    Rick
    ben.w93's Avatar
    Sep 2010
    Devon/Cardiff
    213
    Sat nav discs are cheap enough on Ebay, luckily I managed to use the disc our of dads R8 to update my RNS-E, mine updated with the 2010 disc but is still running on the 2006 disc, but now updated to 2010.
    2008 A5 3.0TDI
    Feb 2012
    Hay on Wye, Wales.
    24
    Hi, Sorry a bit slow getting back to you on this.
    Yes, We do mapping and DPF removal, very popular on a 170.
    Cheers.
    Steve.
  1. Couple of Questions...
    By Leachy in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 7th October 2011, 22:15
  2. A few silly and easy to answer questions
    By Grangey. in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th June 2011, 22:40
  3. couple of 1.8T questions
    By pablo in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th December 2007, 23:49
  4. A few easy questions if I may?
    By Blackadder in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd December 2007, 20:36
  5. A couple of questions??
    By Tolmie18 in forum Detailing
    Last Post: 23rd February 2007, 00:03
