EM TuningAH Fabrications
Results 1 to 28 of 28
    stapo69's Avatar
    All hail the mighty quattro!
    Mar 2007
    966
    Opinions-carbon bonnet
    Thinking ahead, just thought i'd see what folks thought.
    Found this pic of a carbon bonnet with painted outer edges.
    Not liking the painted grill, thinking leaving the standard silver, or maybe satin black? But do like the painted outer edges along the original bonnet lines.
    I have the RS4 front bumper on the way. Also I have the RS4 grill already, along with carbon mirror caps and b-pillars fitted so thinking this may be next on the list?
    What do you guys think?
    MRC-Powerflex-Hotchkis-Porsche-Compomtive-Vredestein-034-JHM-Apikol-EBC-FK-Labree-Vibrant-Recaro
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,691
    Well, stealth would be straight out the window!
    Mo power, mo problems
    Oct 2007
    2,597
    I like it, but don't like bonnet pins, which CF bonnets need.
    Oct 2007
    2,597
    Then there's also the issue of UV damage over time.
    B-pillar and mirror caps are ok.
    But a bonnet, being such a large area, and horizontal to the sun, it'll go brown in time.
    Fraser's Avatar
    Aug 2003
    the north
    586
    i don't really dig the carbon bonnet thing
    i much prefer noggy blue...
    stapo69's Avatar
    Mar 2007
    966
    I had read that they can change colour over time, Seibon are supposed to be a good make that coat theirs with UV reflective coating, supposedly reducing the fade over time, but still inevitable over time i guess. Needs to be kept well clean and looked after too. Pray for good old **** British weather!
    And again I'm with you on bonnet pins, doesn't seem to be much of a way around it, even with the standard bonnet latch being used, the corners lift, even though you'd think it'd be stronger! There is the option of some decent quality flush fitting items, but still spoil the lines a wee bit.
    Hmmmmmm
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    <<<< goes looking for a standerd RS4 bonnet.
    mine needs spraying any ways so i mite as well spray a beefy 1!!
    Now to many mods to list! Lots of power, torque and Leather!
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,824
    The RS4 bonnet is the same as the A4's no difference at all and no they are not made of ally as some people thought.
    I like it but as stated you will need bonnet pin's I dont like them hence why I have never gone down this route. As for going brown if it does just paint the whole thing Noggy job done oh and the heat of the enginee will help turn it brown too.
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,309
    looks excellent and I like the sprayed edges, but I agree pins and colour coded grill spoil the look
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,309
    wonder if there would be a way of using bonded metal plates on the under side and magnetic lock, probably something similar to those used on fire doors so with electric switches, that way they can be on when running to keep bonnet down tight and off when engine off to save power and not be needed then as the standard bonnet catch keeps it locked??
    2001 S3 (AMK)
    Z82
    Apr 2006
    Inverness, Scotland.
    453
    Quote Originally Posted by g60leigh View Post
    Not a bad idea that and you can get them in 12v DC
    7. 2003 B6 Nogaro Blue S4 v8 quattro
    Gone but not forgotten:
    6. 1996 B5 Casablanca White A4 2.6 v6 quattro Sport
    5. 1989 B3 Maroon Coupe 2.0E
    4. 1986 B2 Red Coupe 2.2E Limited Edition
    3. 1985 B2 Red 80 Sport
    2. 1983 B2 Black 80 Sport
    1. 1984 B2 Silver 80 Sport
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    Colour coded aero catches dont look too bad , got a friend with a R33 with them , they was carbon to match bonnet then painted bonnet and colour coded , you can hardly notice them..... well alot less anyway
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    Bushen's Avatar
    Driving with style
    Oct 2007
    Taunton
    52
    Defo like the look..
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    Quote Originally Posted by docurley View Post
    oh...
    i thought they were made of ali. i learn yet another b5 fact!
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,933
    Counts me as well I always thought the bonnet was aluminium. Better touch in those two stone chips then
    Life begins at 140mph
    www.passionford.com
    Road Razor's Avatar
    Tyne & Wear
    390
    I prefer it fully painted in noggy blue. I don't like the bonnet pins either but one company states that their A4 bonnet come with OEM latch. How effective they are I don't know.
    A4 2.4 V6 2000.
    Apr 2004
    Swansea, South Wales
    528
    two words: why bother?
    1999 S4, MIJ Performance exhaust with 100 cell cats
    Apr 2004
    528
    Sorry, a bit harsh, but what does a carbon fibre bonnet bring to the party?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,929
    less weight over the nose i presume is the main benefit
    TD5 Land Rover Defender build
    Apr 2004
    528
    But how much weight? Sod all compared to the overall weight, I bet.
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    i like it.i think the main reason for doing it is that the carbon looks nice.carbon pannels and doors would be nice so inconsiderate arse holes dont dent the sides of the car as well.
    Phantom_A4's Avatar
    Jan 2006
    Southwater, United Kingdom
    562
    Seibon do make bonnets that use the original latch, and don't require bonnet pins, just like the picture above. Personally if i was going to buy a carbon bonnet i would leave some area uncovered, and i like the way he's done this on the pic. The only major difference is weight, but cosmetic looks as well....Why do people change most things on the car? Mostly cosmetic looks, like the rs4 grille etc.....does nothing extra but looks better!
    Oct 2007
    2,597
    Phantom, a guy over on Audi World bought a CF bonnet, that the manufacturer's claimed had a reinforced section to fit the factory pin / catch to.
    Said it didn't need aftermarket pins.
    The bonnet burst oped at speed, and the guy spent time in hospital, as his screen broke too, and his face was a mess! (Both airbags went off).
    Do a search on there, there are pictures of the damage - both to the car, as well as his face.
    I wouldn't trust a CF without aftermarket pins, and as I don't like the pin-look, I'd pass.
    I had a similar scenario back in 2001 - my Sport Quattro fibreglass bonnet (part of the Rieger GTO Competition kit on my RS2-engined B2 Coupe Quattro blew off on the A2.
    Luckily, my damage was limited to my roof and scuttle, my screen and face were fine.
    Just food for thought.
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,044
    well ive had my carbon bonnet now for around a year without using bonnet pins, and is fully secure i do check every so often for stress and cracks
    the bonnet i use is a fiber images from the states
    my bonnet is fully carbon and not a two peace like sebon which uses a glassfiber frame and carbon top skin.
    As long as the clear coat has a UV protector its unlikey that the bonnet will go brown, its a clear coat just like on your own cars paint work.
    TopGear Stockport / Longlife Exhausts /
    www.TopGearStockport.co.uk
    stapo69's Avatar
    Mar 2007
    966
    Billybravo, can you get hold of these bonnets? What sort of price would I be looking at?
    Mithdons's Avatar
    Jun 2006
    26
    It looks awesome, i think theyve done it jsut right not too in your face but will get ppl wondering.
  28. #27
    jcb
    Sep 2005
    uk
    4,070
    if I was going to do that I would go for a whole composite lift off front end for strength and weight.
    I am not going on a diet anytime soon and they are waaaay pricey for a decent one (and by that I mean one with UV block finish and original latch fitting.
    I looked at a kevlar front end for my Mk2 golf when I was going all anorexic track day beast...costly and gettting a decent fit was an issue
  29. #28
    stapo69's Avatar
    Mar 2007
    966
    Seibon do them with a good UV protection and use of the original bonnet latch too. But as pointed out earlier, is it worth trusting just that? In a car that'll do easily 150+, no that I drive at that speed of course......
    The best option I've found for bonnet pins/catches are these, nice and flush and can easily be colour coded. They do ones that mount from the top, and ones that mount from underneath, which would look great if there was a way of fitting them without having the bolts coming through the bonnet, and leaving just the latches. But I can't think how it could be done, except bonding them on from underneath, but I can't see that being strong enough?
    http://www.aerocatch.com/
