Sky InsuranceAH Fabrications
Results 1 to 8 of 8
    Jun 2006
    melton mowbray leics
    22
    which injectors?
    hi i have a 96 a41.8t aeb with a amd remap cat bypass samco hoses and milltech exaust pushing 201bhp i just aquired a ko4 15 and was wondering what size fuel injectors would be needed to get the most out of this unit?
    and will the ecu need remapping and would you recomend amd now that they have moved to big boys toys any help would be greatly appeciated thanks.mike
    robbie5's Avatar
    NEVER ENOUGH
    Nov 2007
    98
    If you're adding a new turbo you'll need your car remapped, not sure about injectors – Siena would know that answer.
    Take your car to MRC they're the dogs B***ox. www.mrctuning.co.uk
    S4 AVANT(325BHP & 370lb/ft)
    MRC remap > Miltek Cat Back > 19" split rims > RS4 grill > RS4 silver rails > Silver mirrors > Full Cream leather Recaros > B6 steering wheel > RS4 gear knob > Eibach springs > K&N filter
    RS4 (standard at the moment)
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,357
    I didnt think we needed injectors with the K04-15 as we have a 4 bar FRP fitted
    macca's Avatar
    Sep 2006
    Sussex.
    525
    i thought we had 3bar? i'm probably wrong,. best way is to get a custom map with the work done, you are probably just within the limit of the stock injectors. they will be able to tell you when mapping the car if the injector pule lengths are too long and require a greater flow. you maybe able to get away with an adjustable fuel pressure regulator and up the pressure slightly more.
    1998 A4 1.8T Sport - For Saturdays
    2003 VW Golf MKIV R32 - For Sundays
    2000 Peugeot 406 HDi - For when it's raining
    1996 Kawasaki ZX7R - For when I'm late for work!
    Mods- Forge Dump Valve, The Engine Shop Power Plus based Engine (Low Comp. Forged pistons, Arrow H-Section Rods, Newman fast road cams, polished & ported head), 19" wheels, B&M Short Shifter, Greddy Turbo Timer, RS4 Grill, Weitec GTN coilovers, HKS modified air filter, Autobahn88 FMIC, ChippedUK custom map. Some Turbo mods ongoing.
    Apr 2004
    12,357
    Mine is deffo a 4 bar, look on the side it will say.Its the VW family that seem to get the 3 bar???
    Jun 2006
    22
    cheers boys looks like mrc are way to go then
    robbie5's Avatar
    NEVER ENOUGH
    Nov 2007
    98
    Quote Originally Posted by mike1234
    Doug is your man he's the owner
    jcb
    Sep 2005
    uk
    4,070
    go with 440cc injectors, but to be honest the map you get will determine the FPR or injector size.
    Custom or not, they are based on prescribed compnents.
    I would always go for bigger injectors than a higher rated FPR though
