Badger5EM Tuning
Results 1 to 13 of 13
    Z82
    Apr 2006
    Inverness, Scotland.
    453
    Sprint Booster???
    Anyone heard of these?
    Came across it HERE
    Also, does my car have Fly-By-Wire Technology?
    7. 2003 B6 Nogaro Blue S4 v8 quattro
    Gone but not forgotten:
    6. 1996 B5 Casablanca White A4 2.6 v6 quattro Sport
    5. 1989 B3 Maroon Coupe 2.0E
    4. 1986 B2 Red Coupe 2.2E Limited Edition
    3. 1985 B2 Red 80 Sport
    2. 1983 B2 Black 80 Sport
    1. 1984 B2 Silver 80 Sport
    GSB1's Avatar
    May 2006
    UK
    273
    Visit GSB1's Youtube Channel
    Heard of them.
    Good product so long as you feel your car has a DBW throttle lag.
    I personally don't feel my S4 does and driving on part throttle in peak boost is already an art.
    However some cars have really bad DBW throttlel ag - pretty much any modern Mercedes for instance. I wanted a device like this when I have one but they were not around, if they had I would have jumped at it. The Mercedes forums rave over them.
    Present: Ice silver B8 S4 s-tronic saloon (standard)
    Past: Agate grey B5 S4 saloon (MRC tuned)
    Hers: Volcano red 8P A3 Sportback 2.0 TDI CR 170 sport quattro
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,294
    Great product and we sell quite a few. They are available for your car aswell!
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Aug 2007
    Brisbane, Australia
    19
    ehe, might seem newb but i also have no idea if im DBW or not :|
    pre-facelift b5.
    wonder, reading some places in aussie (ie: APR) wont chip a 1.8T audi motor pre-facelift... in 97 did all a4's get an ecu upgrade or something?
    '96 1.8T A4 Quattro, chipped & show off valve @ 197bhp
    Z82
    Apr 2006
    453
    OK cool, am I likely to see a noticable gain on my car if I fit one and is my car FBWT?
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    Z82 you are not DBW but NDBW so no good to you and that also goes the same for Fermented as you both have a cable attached the throttlel.
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    As doc sais above your cars are too old to have DBW
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/a4-s4-forum-b5-chassis/43296-bit-project-going.html
    If you think my post had a usefull purpose please say thanks
    Z82
    Apr 2006
    453
    Ahh right ok didnt realise it was a case of cable or no cable, cheers guys, looks like the only engine mod my car will see will be a K&N Panel filter till I can afford my S4 (I wish)
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    Quote Originally Posted by Z82
    You can chip your cars, you may just have to order a chip for your ECU's and have it fitted by a Pro or better still ....
    Every car (apart from some very new ones) can be 'chipped' by soldering/socketing new chips onto the ECU, this is the way all remapping used to happen.
    Fitting 'socket/s' for the chips in your ECU is very worthwhile, as if you do not like your 'remap', you can just put the original chip/s back into your new socket, or swap chips or flash new maps (depending on chip type).
    The later type ECU's have flashable chips, and can also use the less invasive OBD flashing, or serial write without any soldering.
    For a 97 'AFN' engine, if you remove the black plastic cover for the ECU, and the metal ECU body looks like this (probably all silver on an AUDI, not black):
    You 'most likely' have a board mounted MAP sensor with a tube going to it, and 2 'plcc32' chips like this (bit out of focus/dodgy phone macro):
    This image has been resized. Click this bar to view the full image. The original image is sized 800x600 and weights 101KB.
    If so, simply use a good 'micro-electronic engineer' / microsoldering service to install the plcc32 sockets (mine cost 20):
    This image has been resized. Click this bar to view the full image. The original image is sized 640x480 and weights 144KB.
    If you want to solder in the sockets yourself, this link explains how. They do not really need 'Hot air' soldering, and can be done by a competent hobbyist, but it is too fine for my soldering 'ability'.
    http://www.elecauto.com/plcc.htm
    If you have the later type ECU body (with remote MAP sensor), like this:
    You can use the less invasive non-soldering type remap, or if you wish install sockets (if none are present).
    Aug 2007
    Brisbane, Australia
    19
    right, so the 97 onward thing is just remapping?
    i've got to find somewhere that'll solder in a chip?
    Z82
    Apr 2006
    453
    Yeah I was thinking, remap (theres a local guy that will do mine for 175) & exhaust but if Im selling the car early next year theres no real point so I'll prob just get a panel filter at next service (soon) and leave the rest for my next A4
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    Keep the car and drop a VR6 in
    Z82
    Apr 2006
    453
    LOL yep sounds the danglies
