Sky InsuranceJMB Retrofits
    Jul 2007
    341
    Oil Leak (1.8T AJL)
    Whilst under the car at the weekend I noticed that the sump is oily again on the drivers side. I cleaned it off after changing the oil a week or so prior. It doesnt look to be a bad leak, but I want to sort it out.
    Before I start hunting it down, are there any common leaks that I should be looking for down the drivers side? I.e. rocker cover, sump, oil drain from turbo etc?
    1999 Audi A4 1.8TQS (Standard)
    2003 VW Golf GT TDi
    2002 Audi S8 4.2 SOLD
    2004 Alfa 156 2.4JTD 20V Veloce SOLD
    2000 Audi A4 2.8 Quattro tiptronic (Electric heated seats, winter pack, lowered on H&R Springs & 18" A8 sport wheels) SOLD
    1999 Audi A4 1.9TDI 110hp (with full Audi Sports kit) SOLD
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    all of the above
    Start at the top and work down i guess!
    TD5 Land Rover Defender build
    Jul 2007
    341
    Ok! Was hoping there would be a common leak.
    Will give it a good clean then see where it re-emerges from.
    2003 VW Golf GT TDi
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Camshaft seal also check the one behind position sensor, rocker cover gasket, headgasket also check the timing belt tensioner damper as these can leak.
  1. Oil Leaked
    By langtonr in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2006, 23:48
  2. OIl Leak - Help Please
    By cbass in forum General Technical / How To
    Last Post: 20th September 2004, 20:29
  3. Oil Leak 4 days after i bought car
    By imported_andrew74 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2004, 12:28
  4. Oil leak found after having car at dealers
    By ianburtney in forum General Technical / How To
    Last Post: 14th June 2004, 08:19
  5. Oil Leak found after having car at dealer
    By ianburtney in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th June 2004, 08:16
