- Joined
- Nov 24, 2010
- Messages
- 15,084
- Reaction score
- 1,131
- Points
- 113
- Location
- Plymouth
- Website
- wheelsnwires.blogspot.com
Why are you thinking of fitting one Scott?
tony
Good thinking!
Not sure where you'd put one though,maybe on the bulkhead?
tony
Remove the coolant tank theres probably enough room under there and its only 3x pozi screws to remove it !!
Why not just setup an oil seperator and pipe it back to the sump? That way, the blowby gasses are "filtered" and the oil drops out of suspension and runs back to the engine, and theres nothing to empty.
Back thru the crankcase breather hole?
wouldn't a vent to atmo lead to oil dripping onto the road though?
tony
tony
If I remember rightly.some older fords(poss mk1 fiesta) had a seperater on the crankcase breather,which would split the oil from the gases
tony
Is there any sort of useable bracket under there or you making one ??
