ABS sensor
mihogal12
NULL
Hi all,
Im in need of a rear abs sensor and the sleeve that holds it in place for my B5 quattro tdi.
Ive searched on ebay and all I can find is a 2.5 V6 one.
Does anyone know if these are interchangable, or any ideas where to buy a new one other than the stealers.
Many thanks
actual quattro rear sensors are impossible to find other than at the dealer.
You can either buy a FWD rear sensor (they're about £10-15 on ebay) then tweak the positions of the rubber boots to suit, or buy a front sensor, cut the cable off and splice it into the original cable to the rear sensor.
The brass sleeve is dealer only.
i got rears OK from GSF
proper bolt in ones
Mine are the click in type.
I've trawled through the net but all i van find on ebay are 2.5 ones. not sure if they fit/not. I imagine not!
I must try the front one and see how that works out.
I suppose dealer ones are £100+++
think I got two for under £30 posted IIRC!
just got two front ones that are sitting here that were defo less than £30 for two so assume the rears were the same
Use a FWD rear if they're push-ins, the wires a better length etc.
Hey jut a quick update on this.
Located a spare FWD sensor I had and have ordered a brass collar from my local audi dealer.
Outta curosity i priced the ABS sensor too. A whopping €198+23% vat.That a grand total of about £194.55.
Brass sleve working out at €15=Vat Works out at about £15.
Thought id let people know how audi Ireland earn a nice xmas bonous.
796
20
27
4K
707
788
