Volks AutosAH Fabrications
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Bradderz_1988
Thread: Help plz!! Removing concert stereo from my 2000 1.8t and running amp wire from batter
    Jan 2012
    41
    Can anyone help me in a way to remove concert stereo to replace with After market one ? Is there a easy way to remove without proper keys as haven't got them? Also is there a hole for a amp wire to go through from battery under the bonnet ? Any help would be great
    many thanks
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,866
    Radio will only come out with ease with the right tool dont try with anything else as you will butcher the clips then when you cant get it out and use the correct tool that wont work either, as for amp wire theres a hole on the drivers side in the ecu holder/box which is perfect for your needs or anything else like a boost gauge or similar.
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Sep 2011
    Sunny Bangor. N.Wales.
    287
    i put both my 2G power cables through the ECU gromets, nice snug fit too
    2000, A4 2.5Tdi Quattro.
    Tinted, 3600WATTSLoud
    TrisLC's Avatar
    Feb 2013
    Cheshire
    333
    Thread resurrection,
    can anybody offer some advice?
    ive waited all week for some Audi stereo removal keys to come. Slotted them in today and only one side of the radio will pull out. It looks like the clip is broke, so my question is..
    how do I remove this now with out destroying the unit?
    cheers
    B5 1.8T Quattro
    Oct 2013
    9
    Anyone else know how to remove a stuck radio the same thing has happened to me .One side stuck
    Aug 2010
    2,866
    You need a really thin pick or screwdriver wedge it in and flick the retaining clip and pull the radio with the other side, helps if you remove the fascia trim to pry it free.
    CHRISBURNS75 likes this.
    Oct 2013
    9
    Thanks I will try this tomorrow
    Quote Originally Posted by Bradderz_1988 View Post
  1. removing audi concert stereo??
    By killa_z in forum In-Car Entertainment
    Last Post: 15th October 2007, 00:02
  2. Removal of concert stereo help
    By Layerz in forum In-Car Entertainment
    Last Post: 17th March 2007, 21:28
  3. Audi concert stereo safe mode! Help!!
    By petephoenix in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th November 2006, 19:32
  4. A3 Concert Stereo help please!!!
    By god_thats_quick in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th September 2006, 23:38
  5. Concert Stereo removal keys
    By Naresh in forum In-Car Entertainment
    Last Post: 28th January 2005, 08:48
