EM TuningSky Insurance
Results 1 to 10 of 10
    Jun 2012
    Essex
    55
    indicators not working
    Hi,
    my indicators have stopped working as well as the hazard lights, from the posts i`ve seen on here i suspect the relay/hazard light switch needs replacing but as i can hear a single click if i indicate left or right i thought i would check before i pay out for a new one.
    many thanks in advance
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,926
    fuses ?
    arm
    hazard switch
    Jun 2012
    Essex
    55
    Hi, fuses are fine and i can hear a single click coming from the relay
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,633
    Hazard switch most probably. B5's are quite common for them
    Currently rolling in a SKODA!!!
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,871
    Quote Originally Posted by Arrkon View Post
    All audis are common for them lol
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Arrkon's Avatar
    Oct 2010
    1,633
    Quote Originally Posted by Bradderz_1988 View Post
    Lol, yeh that's true....
    Oct 2009
    188
    Did you find out what it was? Mine has started to play up occasionally it'll indicate most of the time though the indicator just stays on like a light and won't flash.
    Aug 2010
    2,871
    Hazard relay switch everytime !!
    Oct 2009
    188
    Is there any difference between pre/facelift switches?
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,918
    iirc you can swap the back switch part but need to change the button part.
    Life begins at 140mph
    www.passionford.com
  1. A3 8L facelift, indicators suddenly not working
    By Dark Knight in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2012, 13:37
  2. Indicators Not Working - Relay or Stalk?
    By metricspaces in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th August 2009, 16:10
  3. Indicators not working properly
    By clcollins in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th April 2009, 08:51
  4. a4 2000 indicators not working
    By s3_kev in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th May 2008, 22:12
  5. Indicators not working
    By Bula_82 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd March 2008, 21:30
