DPMEM Tuning
Results 1 to 13 of 13
    Biodiesel Purrrr
    Jun 2011
    London
    81
    Post Thanks / Like
    TDi remap - '98 1.9
    Hi all,
    after reading many posts about remaps for the TDi I'm ready to get this done -
    well, once the timing belt is changed i think...
    read good things about CCtuning over on TDiSport form but not seen them mentioned here.
    Seems they do 'dyno diagnostic and custom maps' at a very reasonable price.
    ['98 A4 TDi AFN engine]
    I'm after a very driveable and smooth map with low RPM torque and not peak BHP -
    any experience of good mappers for this?
    thanks in advance for info!
    TDi Biodiesel sippin' A4 Avant - EGR blanked
    "Cars are good but Jeremy Clarkson is a dick."
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,274
    Post Thanks / Like
    Blog Entries
    Are they remapping your AFN engine or chipping it?
    I've been told many times that our ECUs (I got the same motor as you) have to be chipped as they can't be mapped through the ODB port.
    Biodiesel Purrrr
    Jun 2011
    London
    81
    Post Thanks / Like
    Thanks for that info Scott, I did not know this...
    I have been enquiring at a handful of companies but not been told it will need a new chip - I'll double check that.
    P)
    "Stick a V8 in it!"
    Cleveleys, Lancashire
    11,839
    Post Thanks / Like
    Most B5's need chipped, even if its generally called a remap these days.
    For Sale: Breaking B5 A4 - Check my eBay page!
    Wanted: Facelift A4 Front Bumper with Headlight Washers.
    2000 A4 1.8T Sport Quattro Avant, Beere Pearl, TT Carriers and B6 312mm Disks.
    2000 A4 1.8T Sport Quattro Saloon, Black-ish, Now Running!
    1997 S4 - PPC £999 Challenge Track Car Build starting soon!
    Audi V8 powered Land Rover Defender build in progress.
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,274
    Post Thanks / Like
    Blog Entries
    Any idea why a R reg 8L can be remapped?
    Any views on tunning boxes over Remaps?
    Biodiesel Purrrr
    Jun 2011
    London
    81
    Post Thanks / Like
    Just heard back from CCtuning - does this sound right, Scott?
    "You don't need a new ecu fitting lol, you just have to recodify the eproms which are soldiered to the pcb.I have done loads before, in actual fact before remapping was available this is how we used to alter all the cars"
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,274
    Post Thanks / Like
    Blog Entries
    Quote Originally Posted by TeKnodriver View Post
    yup, 100%.
    New ECU? who said that?
    They de-solder your current chip, solder in a chip holder and push a new chip in to the holder.
    Biodiesel Purrrr
    Jun 2011
    London
    81
    Post Thanks / Like
    got tuning box at the mo and defo does something - how much I can't measure.
    I'm working on the assumption that remap will provide better gains, MPG and driveability but I guess this is not always the case?
    I do get flashing glow-plug light and "fuel quantity adjuster fault - intermittent" when the box is turned up
    thinking proper remap will not do this!
    Biodiesel Purrrr
    Jun 2011
    London
    81
    Post Thanks / Like
    ok, sorry Scott think I mis-read your post!!
    however, he says 'recodify' you say 'de-solder'... I'm a little worried about this now
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,274
    Post Thanks / Like
    Blog Entries
    No idea but it would be interesting to know about the difference.
    I know two people with two different cars that had tunning boxes and both of them never seen or felt a difference.
    They was second hand boxes.
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,274
    Post Thanks / Like
    Blog Entries
    He might mean the same thing, unless you can remap the ECU chip with out taking it out.
    I have all ways been told you need to remove the original chip (de-solder) and add a chip holder so you can add the new remapped chip.
    TDIPOWARRR
    Jul 2010
    Scarborough
    613
    Post Thanks / Like
    Yeah totally right buddy, had my old B5 done and that's what they did.
    2003 Audi A4 Avant-tdi 130-Remapped, Allard EGR Pipe, Smooth airbox, HIDS, Flyeye kit, de-chrome grill, de-badged.
    Coming soon-18s or 19s
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    He means reprogram.
    If you want to tune the car, you need to modify the mapping on the internal EEPROM (memory chip).
    Its exactly the same procedure as remapping, but older ECU's dont have an internal facility to reprogram the chip, and thus the chip needs to be removed (de-soldered) and reprogrammed externally.
    On a newer ECU, it has built in routines which allow the reprogramming to happen over the diagnostic port, and so the need to desolder the chip died out.
    Ofcourse you can if you want still desolder the chip and program it externally on a newer car, but its sort of pointless!
  1. 1.6 tdi remap
    By plezz in forum Tuning
    Last Post: 2nd February 2012, 09:12
  2. 2.0 TDI remap
    By stew 944 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 11th July 2011, 20:59
  3. TDI Remap ??
    By NineNails in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th June 2008, 21:25
  4. Who to go with for TDI remap?
    By sibby in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd March 2008, 08:42
  5. A3 2.0 TDI remap
    By disco_stu01 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th June 2006, 19:31
