VAG CheckEM Tuning
Results 1 to 30 of 30
Like Tree2Likes
  • 1 Post By Jason.s
  • 1 Post By aragorn
Thread: Do I need to grow up?????
    Apr 2006
    A, A
    209
    Post Thanks / Like
    Silly question but it's got to be asked. Do people still fit dump valves and is it too cheesey to have one fitted to a S4 B5 (mine). Love the sound of the m especially a discrete one that sounds nice (not in ya face).
    Feed back please as this is a poll that will decide the outcome.
    Alsie's Avatar
    Sep 2011
    133
    Post Thanks / Like
    I have a forge dump valve on the scooby, and yea it is cheesy and makes fuel consumption worse, thought Audi's like VW's didnt respond well to dump valves unless they were recirculating (silent) type
    1998 A4 Estate 1.8 Turbo Sport in Imola Yellow
    1998 A4 Estate 1.9 TD in Paradise Green (Broken sob)
    2004 Subaru Impreza WRX STi Type Uk PPP (The Doctor replica)
    1994 Honda CBR900RRR Urban Tiger Fireblade.
    Apr 2006
    A, A
    209
    Post Thanks / Like
    Don't know buddy, I have 770 diverter valves fitted, god if fuel consumption got any worse I won't go anywhere. I also had them on my STI RA and loved it but the Audi is more conservative isn't it?
    VW/Audi parts advisor
    May 2010
    Bedford
    1,220
    Post Thanks / Like
    With an open filter and a better diverter valve like a forge 007p it's pretty loud without the need for a proper dump valve. Especially when mapped.
    Laser Red 98 A4 1.8T - B7 A4 17" wheels, Weitec GTN coilovers, Front strut brace, Custom rear dual strutbrace, Custom rear floor brace, RS4 front lower subrame brace, Neuspeed rear Antiroll bar, Shortshift with lever extension, Silicone TIP, Jetex cone, Forge 007p, Jetex 2.5" catback exhaust, THS 3" Decat, Custom downpipe, 312mm Front brakes, RS4 Engine Mounts, RS4 Snub mount, Audi 80 TDI solid flywheel, Audi S2 3B clutch kit, Rtech mapped
    199bhp 221ft-lbs
    Apr 2006
    A, A
    209
    Post Thanks / Like
    Just been looking at the specs of the car and it has Hyperboost DV valve fitted what ever them are?
    floyd 1.8 turbo's Avatar
    Mirror, Signal, Outmanoeuvre
    Apr 2008
    Bracknell, Berks
    630
    Post Thanks / Like
    Do what you wanna do! If you like it go for it, I've got a k+n air filter on my 18t and it's been mapped, no dump/diverter valve and I still get that fluttering type whooshy sort of sound that you'd get from a d/v.
    It's a controllable too when changing gear, ease off the throttle slightly just before changing gear and it's pretty much silent or leave your foot planted till the last second and you've got your noise......best of both worlds!!!
    White B5 1.8 turbo sport
  8. Likes Der_Techniker liked this post
  9. #7
    May 2010
    Bedford
    1,220
    Post Thanks / Like
    If its fluttering is knackered lol
    floyd 1.8 turbo likes this.
    199bhp 221ft-lbs
  10. #8
    Apr 2006
    A, A
    209
    Post Thanks / Like
    I just want a bit of noise but nowt chavtastic. Need to see what diverter valves I have 1st. I see you can get uprated springs for the forge 007p. What would suit my engine, it's running at 352 at the fly and boosts at 1 bar.
  11. #9
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,274
    Post Thanks / Like
    Blog Entries
    No techy knowledge about them but there is something cool about them.
    Don't care how chavy or cheesy they are, they noise just makes me giggle like a school boy.
    Bit like hammond in the noble. lol
  12. #10
    Alsie's Avatar
    Sep 2011
    133
    Post Thanks / Like
    i had the "flutter-chatter" noise when i fitted an induction kit to the Scoob, wastegate chatter its called i think, but it messed the fueling bigtime and caused it to run lean on bank 3 , potentially fatal for scoobys...
    but it made a better noise than the dump valve
  13. #11
    Bradderz_1988's Avatar
    The only way is ..... German !
    Aug 2010
    Greater Manchester
    1,065
    Post Thanks / Like
    When my diverter valve vac line split it sound more like compressor stall which sounded like what some people call wastegate chatter so if you can hear this noise get it done quickly as there is a risk of snapping the turbine shaft luckily I was literally round the corner from my house after my evening commute home from work !!!
    Stick with a diverter as with these cars if you have a baileys etc that dumps to atmosphere it cocks the fuelling up !! As the maf as told the ecu the amount of air it intakes to allow for the correct amount of fuel so if you dump the air you mess things up, we had a mk4 golf gti in work the other day and it sounded ok but as the bonnet was up I just blipped the throttle with my hand to here the DV and wot do you no the car started to replicate a slight misfire and it put me right of as I quite liked it lol each to there own tho !!!
    1999 Audi A4 1.8T Quattro Sport - Volcano Black - Frankenturbo'd
    Wanted - S4 Skirt/Wing trims, S4 side skirt brackets.
  14. #12
    "Stick a V8 in it!"
    Cleveleys, Lancashire
    11,839
    Post Thanks / Like
    My old 710 caused proper ace compressor stall. I found myself randomly going FullThrottle-Lift every time i passed a bus stop with young folks in it, or kiddies with their corsas and saxos and the like.
    When i finally replaced it with a new 710N the noise went away
    I think i may be forced to install a Forge with a stiff spring so i can get my "check me, i have a turbo" noise back!
    For Sale: Breaking B5 A4 - Check my eBay page!
    Wanted: Facelift A4 Front Bumper with Headlight Washers.
    2000 A4 1.8T Sport Quattro Avant, Beere Pearl, TT Carriers and B6 312mm Disks.
    2000 A4 1.8T Sport Quattro Saloon, Black-ish, Now Running!
    1997 S4 - PPC £999 Challenge Track Car Build starting soon!
    Audi V8 powered Land Rover Defender build in progress.
  15. Likes Der_Techniker liked this post
  16. #13
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,274
    Post Thanks / Like
    Blog Entries
    You big bloody kid.
    Lol
  17. #14
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,308
    Post Thanks / Like
    Quote Originally Posted by Alsie View Post
    There's no such thing as wastegate chatter, blame dopey media types for that one. The sound is nothing more than the compressed air having nowhere to go once the throttle butterfly closes and the air seeping back through the turbo the wrong way, in effect beng chopped by the blades of the compressor wheel.
    This is my old Fiesta RS Turbo chattering like a goodun
    Fiesta RS Turbo chatter - YouTube
    Fiesta RS Turbo Chatter II - YouTube
    I'm running a Forge 007 recirc on my A4 and it's brilliant. However a mate of mine has given me an HKS SQV for helping him out so I'm going to fit it for a laugh and see how it goes. I know it will balls teh fueling a bit but sometimes you have to just roll with these things. lol
    Life begins at 140mph
    www.passionford.com
  18. Thanks warren_S3 thanked for this post
  19. #15
    Apr 2006
    A, A
    209
    Post Thanks / Like
    My mate has some 007p's I can try if I want but what spring should be fitted for my mapped engine. Specs above and thanks for all the replys, I thought it would bring alot of attention and it was Hammond in the Noble that set me off again. lol
  20. #16
    Aug 2010
    Greater Manchester
    1,065
    Post Thanks / Like
    This is what forge list on there spring kit on ebay
    Green** -*** 6-8 PSI
    Yellow**-*** 10-12 PSI
    Blue**** -*** 14-16 PSI
    Red***** -****18-20 PSI
    Please Note:
    The quoted spring pressure (Psi) relates to the un-assisted clamping force of the spring and should NOT be taken as an equivalent to boost pressure when determining suitability. Once a valve is fitted to a car it is subjected to various pressures that act upon the diaphragm or piston to aid its respective ability to seal or hold boost. An example of this, would be when using a FMCL007P valve on a 1.8T engine as found in the TT 225hp. The boost pressure on a "chipped" car can peak at 26psi. The recommended spring would be the Green or Yellow
  21. #17
    May 2010
    Bedford
    1,220
    Post Thanks / Like
    They`re rated higher than that in each colour for sure. Green is up to 14psi atleast. The yellow is more as Welly runs a yellow spring in his 400+ S3 lol.
    199bhp 221ft-lbs
  22. #18
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    well thats what it says in the text underneath.
    The valve should in theory stay closed at 30psi even with the weakest spring fitted, as both sides of the valve are pressurised to the same level. One side is connected to the Inlet manifold and the other to the boost pipework. The reason for the stronger springs is to overcome transients. IE the fat pipe feeding the valve will typically reach 30psi much faster than the little vacuum hose, so the valve could pop open before things reach a steady state.
    The Spring is there to help out, but as you make the spring stiffer the valve simply wont open at low boost pressures. So you could build up say 9psi of boost, lift off and it wouldnt dump, you'd just get some nice compressor stall. Clearly what you want is the softest spring possible, that will stop the valve opening at unwanted times, which is why they suggest a mapped TT making 26psi should be on a green or yellow.
  23. #19
    Der_Techniker's Avatar
    Foursprung Duck Technique
    Oct 2010
    Coventry, West Midlands
    991
    Post Thanks / Like
    I still do
    2000 Silver Audi A4 1.8T Sport, With added Carbon Goodness
    "Arguing with an engineer is a lot like wrestling in the mud with a pig. After a few hours, you realize that he likes it."
  24. #20
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    Because you have a broken DV? Or a Forgey with a stiff spring?
  25. #21
    Oct 2010
    991
    Post Thanks / Like
    haha, probably an iffy DV. i generally get the "TSSSSSSSSHHHH" but occasionally i get a flutter
  26. #22
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    Yeh, my new DV is basically silent in operation, i havent really heard it at all. The old one could be made to flutter quite readily, so i assume it was fubar.
  27. #23
    Aug 2010
    Greater Manchester
    1,065
    Post Thanks / Like
    My old dv was fubar and didnt hear it unless I was at high revs as the wastegate was totally fubar and only making 6psi of boost as it was rattling and causing gases to go past !!
    When I removed it you could blow straight through the diaphragm on boost port side !!
  28. #24
    slepy's Avatar
    Sep 2009
    MK
    572
    Post Thanks / Like
    Is anyone here using a hybrid recirc/blow off like this one from forge?
    Forge Motorsport | Alloy Fabrication
    2001 Focus 1.8 TDdi GONE
    1994 BMW 318IS GONE
    2003 Mondeo 2.0TDCI
    Zetec S GONE
    2002 A4 1.9 T
    DI in silver, with blue interior and RS4 style alloys. GONE
    2006 VW Touareg 2.5 TDI SE in sky blue GONE
    2007 A4 S-Line Special Edition Quattro 2.0 TDI 170 in silve
    r GONE
    2007 Seat Leon FR Tdi in yellow :D
  29. #25
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,308
    Post Thanks / Like
    I assume that's the same as the SplitR valves I've heard mentioned
    www.passionford.com
  30. #26
    Aug 2010
    Greater Manchester
    1,065
    Post Thanks / Like
    I've ran it with one of them before with the knackerd turbo and replaced it for the 007p as thought it was fubar but it was the cause of the wastegate not closing flush to the turbine housing why boost was only 6psi. Wish I would of still had it now, as running the right boost
  31. #27
    Alsie's Avatar
    Sep 2011
    133
    Post Thanks / Like
    Don't forget a dump valve should only be actioned as you pass alongside another car, not before or after the drivers window..lol!
  32. Likes Der_Techniker liked this post
  33. #28
    Apr 2006
    A, A
    209
    Post Thanks / Like
    Why else would you have one??? lol
  34. #29
    Mar 2009
    Scotland
    174
    Post Thanks / Like
    I have a Forge Splitr on my 1.8TQS. Yes there is something a little childish about having the noise and using it at certain points, like bus stops, schools etc but I thought what is the point in having a turbo if you can't hear it. It isn't too in your face like scoobys etc but is still nicely audible
  35. #30
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,611
    Post Thanks / Like
    Quote Originally Posted by AB5QTS View Post
    Nothing wrong, if you have a Turbo, flaunt it!!!! lol
    Get some vids up thou!
    Project RS28 build
  1. Help Grow AudiDIY Submit your DIY Today!
    By Audidiy in forum Classic Audi Forum
    Last Post: 25th February 2007, 20:32
  2. Don`t you just love it when people grow out of thier max power phase!
    By imported_Yaseen in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th April 2005, 17:32
