DPMDNA Tuning
Results 1 to 43 of 43
Like Tree1Likes
  • 1 Post By aragorn
Thread: a6 2.7t.... help needed (s4 engine)
    audi-a6's Avatar
    Aug 2011
    christchurch
    174
    Post Thanks / Like
    Hey.......
    i have an a6 2.7t, same engine as the s4, did originally post this in the a6 forum, but they recommend posting here.....
    okay, straight to the point....... 1st ptoblem, when im driving normally i take my foot off the pedal and the car feels like some has just drove up my A$se! Like a shunt. Does it all the time(except for the first 5 minutes from cold) any ideas??
    2nd problem, sometimes my boost drops, mostly to 0.3/0.4 bar (currently running 1.1 from a re-map) it does under NO specific load, sometimes if i floor it, sometimes i can be just driving under load (apx .8 bar) then all of a suddeni can hear the bovs dump and it will drop to 0 and get the shunt back, as if i took my foot off the pedal.
    any help would be great
    Bradderz_1988's Avatar
    The only way is ..... German !
    Aug 2010
    Greater Manchester
    1,065
    Post Thanks / Like
    Failing maf possibly ??
    Or if when you let off check the tranny mounts if these have seen there days the you may have some slack in the tranny causing it to shunt when letting off !!
    1999 Audi A4 1.8T Quattro Sport - Volcano Black - Frankenturbo'd
    Wanted - S4 Skirt/Wing trims, S4 side skirt brackets.
    audi-a6's Avatar
    Aug 2011
    christchurch
    174
    Post Thanks / Like
    na, cant be mounts, as does not do it when cold
    maf? iv never know a maf to do that
    Aug 2010
    Greater Manchester
    1,065
    Post Thanks / Like
    If a maf suddenly cuts the fuel it will cause the car to shunt.
    You scanned it with vagcom ??
    audi-a6's Avatar
    Aug 2011
    christchurch
    174
    Post Thanks / Like
    Quote Originally Posted by audi-a6 View Post
    had it scanned a while ago, nothing came up
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,597
    Post Thanks / Like
    I have s shunt like this. I've changed virtually everything and still not solved it. New flywheel, new engine mounts, new gearbox mounts, snub mount, DTS and a centre diff.
    Next thing is to change the gearbox and rear diff.
    Mo power, mo problems
    audi-a6's Avatar
    Aug 2011
    christchurch
    174
    Post Thanks / Like
    did you have boost problems as well?
    audi-a6's Avatar
    Aug 2011
    christchurch
    174
    Post Thanks / Like
    Also why have you only changed mechanical parts and not electronic ??
    "Stick a V8 in it!"
    Cleveleys, Lancashire
    11,839
    Post Thanks / Like
    The boost dumping means the ECU thinks something is wrong. That may be due to a crappy remap, or it may be due to leak or a faulty sensor. Vagcom scan (not some ****ty code reader, use vagcom) should be the first port of call.
    Every B5 i've owned has eventually developed a shunt like you describe. I notice it most at motorway speeds, and i found that you let off the throttle, and there would be a momentary delay then a thunk. I always imagined it felt like a large heavy steel ball was rolling around the boot and had come up hard against the back of the seats.
    Its most commongly caused by the engine mountings (and possibly prop or rear diff mountings on a quattro). Under load the engine obviously twists against its mounts and when you remove load the mounts relax, then you transition into overrun and the mounts twist up the other direction. When the mounts wear out, they become slack, allowing the engine to effectively flop loosely between the two extremes, and this floppyness exhibits as a shunt feeling as the engine/transmission assembly comes up hard against the end of the floppyness.
    The mounts in the missus Quattro are really bad and it will do it both when lifting off and reapplying power again.
    Worst case it could be play in the Prop/CV's or Diffs themselves, but as most of these cars are pushing on a bit now, i'd defo look at getting the mountings replaced and see how that goes.
    For Sale: Breaking B5 A4 - Check my eBay page!
    Wanted: Facelift A4 Front Bumper with Headlight Washers.
    2000 A4 1.8T Sport Quattro Avant, Beere Pearl, TT Carriers and B6 312mm Disks.
    2000 A4 1.8T Sport Quattro Saloon, Black-ish, Now Running!
    1997 S4 - PPC £999 Challenge Track Car Build starting soon!
    Audi V8 powered Land Rover Defender build in progress.
    audi-a6's Avatar
    Aug 2011
    christchurch
    174
    Post Thanks / Like
    I know it's not the mounts or anything like that as it will shunt if I'm not under load. Eg, going down a road at 30mph constant speed, then just take my foot off to slow down, it shunts it's got to be electronic related....... So if any one has a vag com and are local to Bournemouth, it would be a great help
    audi-a6's Avatar
    Aug 2011
    christchurch
    174
    Post Thanks / Like
    also, if i take my foot off super quickly, it wont do it, the slower i take my foot off the harder it shunts, its like the engine tries to run on, then quickly changing its mind.....
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    122
    Post Thanks / Like
    Does sound very similar to mounts, though not a 2.7 mine would do the exact same thing, if i had my hand on the gear lever I could feel the whole drive line move what felt about an inch, replaced snub mount and both engine mounts and it improved dramatically, will be replacing all the rest of the mounts now as car is off the road at the moment.
    audi-a6's Avatar
    Aug 2011
    christchurch
    174
    Post Thanks / Like
    I have no movement atall in my gear stick
    Dec 2011
    Wirral uk
    12
    Post Thanks / Like
    i`d get that sorted asap !!!
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    Perhaps stick your query over on the B5 S4 section of AudiSRS.com theres a lot more 2.7T owners over there, so a bit more knowledge floating around.
    audi-a6's Avatar
    Aug 2011
    christchurch
    174
    Post Thanks / Like
    Yeah will give a try, the other reason why I don't think it's mounts is because it don't do it when cold :-s
    Feb 2007
    Liverpool
    1,597
    Post Thanks / Like
    No boost problems on mine. Electrical faults couldn't cause the shunt in mine. It is definitely mechanical.
    audi-a6's Avatar
    Aug 2011
    christchurch
    174
    Post Thanks / Like
    Quote Originally Posted by Blue_Thunder View Post
    Does yours do it from cold?
    Feb 2007
    Liverpool
    1,597
    Post Thanks / Like
    All the time.
    audi-a6's Avatar
    Aug 2011
    christchurch
    174
    Post Thanks / Like
    See, mine don't do it when cold, another reason I don't think it's mounts, I'm starting to wounder if the boost problem and the shunt problem are linked to the same part :-s
    Feb 2007
    Liverpool
    1,597
    Post Thanks / Like
    I tell a lie... Mine doesn't do it when cold either! I've had this problem for as long as I can remember and I'd never noticed!
    I guess after a while I've adapted the way I drive to minimise the effect.
    The only other person I wa aware of that had the same problems on the forum had his gearbox replaced and it got rid of his 'kangarooing'.
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    If its transmission related, perhaps the thicker (cold) oil has a dampening effect?
    audi-a6's Avatar
    Aug 2011
    christchurch
    174
    Post Thanks / Like
    mmm, i see what you mean........... but i just cant put it down to that.......... as like i said above, the slower i take my foot off the harder it will shunt....... where if it was mounts, box ect it would do the opposite ie take your foot of quickly it would shunt, but this is not the case
    audi-a6's Avatar
    Aug 2011
    christchurch
    174
    Post Thanks / Like
    what about flywheel. Could that cause the shunt?
    Also any one got any ideas for my other problem with the boost, as it has got worse, if im in 6th gear doing say around 70mph and i put the throttle on about 50% the boost drops to 0 and does the shunt as described above, then wont boost over 0.4bar untill i turn the engine off then back on again.
    Feb 2007
    Liverpool
    1,597
    Post Thanks / Like
    Sounds like you've got a bad boost leak. Get it tested.
    I thought a knackered flywheel could have been the culprit, but as mentioned, I swapped mine for a new LWFW and it's still just as bad.
    Aug 2010
    Greater Manchester
    1,065
    Post Thanks / Like
    Have you checked for any fault codes with vagcom as that will put you in some sort of direction as to where to look at and also using measuring blocks to see what the maf is reading when faulting ?? Your boosting fault is more than likely electrical and your shunt may also be electrical as when I had a failing maf when the maf was cutting fuel it would appear as if I had just hit a brick wall !!
  28. #27
    audi-a6's Avatar
    Aug 2011
    christchurch
    174
    Post Thanks / Like
    that would make a lot of sense, will order a vagcom today,
  29. #28
    audi-a6's Avatar
    Aug 2011
    christchurch
    174
    Post Thanks / Like
    okay, so 5 weeks on and many pounds spent, still no joy, had another remap done on a new ecu, got new thermostat and cambelt, full service, plus other bits inc n75 valve, but still no joy and still throwing code 17963 but all my limits have been removed, so how can it throw this code, it mainly does it at higher speed, ie accelerating from 60 in 6th gear, take foot of gentley and then boost cuts, have checked for boost leaks, so could it be map or maf sensor?
  30. #29
    Apr 2006
    A, A
    209
    Post Thanks / Like
    code 17963 = Maximun charge
    So the car is over boosting and going into limp mode.
    Now on the TDI Golfs this problem happens alot as the turbos have Variable Geometry Turbo (VGT) which get jammed causing it to over boost. I have repaired many of these but not sure if your turbo has the same set up. Have you checked your actuators?
  31. #30
    audi-a6's Avatar
    Aug 2011
    christchurch
    174
    Post Thanks / Like
    no not yet, but according to my gauge i never over boost and even if i was, it shouldnt matter as i have no limits set in the ecu
  32. #31
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    You've still not had a boost leak test have you?
    Moreover, you've obviously not taken it anywhere competent to have the remap done either, or it would have been sorted then, rather than them just turning off the safety features. Luckily for you, it seems the ECU is smarter than whoever has been pissing around with it.
    adidasandy likes this.
  33. #32
    audi-a6's Avatar
    Aug 2011
    christchurch
    174
    Post Thanks / Like
    what do you mean? i have tested for leaks and done a new map and removed limits to see if it still does the problem, which it does, also tried a standard ecu and still does it, therefore its not the map, thats why i think its a dodgy sensor
  34. #33
    Banned
    Aug 2010
    1,043
    Post Thanks / Like
    that code is Boost Pressure Control: Upper Limit Exceeded.
    as you yourself pointed out..... if theyve mapped no limits into it how can it come up with this code?
    boosting in the higher gears midrange i bet its hitting the fuel cut, or opening the recirc valves too early as you come off the throttle. take it elsewhere for the map.
  35. #34
    audi-a6's Avatar
    Aug 2011
    christchurch
    174
    Post Thanks / Like
    but the guy who done my car has done loads of these with out no problems.......... and obviously i dont want to spend more money on another re-map to find it still does the same
  36. #35
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    My point is simple: if the guy actually knows what he was doing, he wouldnt have sent you away with a broken car.
  37. #36
    audi-a6's Avatar
    Aug 2011
    christchurch
    174
    Post Thanks / Like
    yeah, i see where your coming from, but what if it was broken before. i was only running .4 bar, there for not boosting high enough to cause the fault and with saying that, the car had been mapped before i got it, as the map file was encrypted, yet was running low boost, so there must have been a fault before this guy touched it............... i got work from something, so would you say its unlikely to be maf or map sensor?
  38. #37
    audi-a6's Avatar
    Aug 2011
    christchurch
    174
    Post Thanks / Like
    also, dont know if its the same problem, but also SOMETIMES throws code 17965 and ross tech states for both codes "Charger Pressure Control defective"
  39. #38
    audi-a6's Avatar
    Aug 2011
    christchurch
    174
    Post Thanks / Like
    still got this problem, change maf, map and n75, no boost leaks, tested my ecu in another car and it doesnt do it, its really puzzled me, what else could it be, just to re-cap, the codes are 17964 and 17965 one is negative deviation the other is positive deviation???
  40. #39
    audi-a6's Avatar
    Aug 2011
    christchurch
    174
    Post Thanks / Like
    im at whits end now, i can not solve this problem, its really starting to do my head in, i think im coming to the point where i have to sell, as this is 1 of 3 problems now, that i can not fix or find out even what is causing the problems.... :-(
  41. #40
    audi-a6's Avatar
    Aug 2011
    christchurch
    174
    Post Thanks / Like
    could it be this
    charge pressure controll hose?
  42. #41
    Feb 2007
    Liverpool
    1,597
    Post Thanks / Like
    A pressure test would reveal a leak in that hose.
    Do you still think the shunt isn't mechanical? As mentioned, it does sound like mine. I'm swapping my gearbox out the lsat week in May. Will report back then.
  43. #42
    Feb 2007
    Liverpool
    1,597
    Post Thanks / Like
    Have you checked your DV's are holding pressure?
  44. #43
    audi-a6's Avatar
    Aug 2011
    christchurch
    174
    Post Thanks / Like
    boost leak test doen, all was fine, dv's are fine and i think the shunting is my rear diff as if i pull away quickly while turning it sounds like a load of chains rattling around............ also my mate done a vag com run and said all looked okay apart from the vag com was reading a different temp to what the dash gauge was running and said, although im hitting a full 1.2 bar of boost, the torque is quite flat in some gears, he said it feels like its holding back???
  1. Engine needed
    By belfastone in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th January 2012, 14:09
  2. 1.8T engine needed
    By Bong Water in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th August 2008, 21:53
  3. NEW ENGINE - ADVISE NEEDED!
    By CharlieT in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2008, 13:40
  4. Replies: 8
    Last Post: 21st November 2007, 02:40
  5. A4 1.8 V5 engine needed
    By dsl1975 in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th September 2004, 18:31
