EM TuningChris Nott
Results 1 to 18 of 18
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    Bridgend, South Wales
    617
    B5 Avant Rear brake caliper guide pins....do they need lubricating?
    I've got an issue with my car which I'm beginning to think might be of my own making......
    Every 6 months or so I'm finding that the rear pads appear to be sticking slightly on (usually given away by the smell!) and when I remove the pads I find that 1 or more of each guide pin that the caliper is supposed to float/slide on is well and truly seized in the caliper carrier!
    Now, in the past I've just unbolted the caliper, removed the guide pins , cleaned them thoroughly and after lightly greasing them, put them back into the caliper carrier.........
    Now, I don't think my calipers are sticking (famous last words I know), but I'm now wondering if the act of greasing these guide pins (with a small amount of copper grease) is whats causing the problem?
    Over time, I'm theorising that this grease is becoming a solid gunk (the discs/pads do get pretty hot don't they) and it is this that is causing the caliper no longer to slide effectively.
    The guide pin is very tight into the caliper carrier at the best of times, so the amount of grease applied is very minimal, but now I'm wondering if the whole guide pin/caliper carrier assembly should just be totally clean , devoid of any lubricant?
    The Haynes mentions nothing about the guide pins really (other than to use new guide pin bolts), the same goes for Elsawin.
    Can anyone advise me about these pins?
    I've got a plan on the weekend to get both rear wheels off and totally degrease these caliper guide pins,to save potential future hassle but I'd be a lot happier knowing whether they should be lubricated or not..........
    Thanks!
    '99 Ming Blue A4 Avant TDi SE 110 + Dragon Performance Tuning Box
    Factory sunroof / Cruise / Aircon + Climate / Royale Blue leather
    '72 1302LS Karmann Beetle Cabrio Silbermetallic
    '63 Karmann Ghia Sunroof Coupe Pacific Blue
    AndyC's Avatar
    Apr 2003
    Dorset
    716
    I use Moly lube for mine, and have the same problem...
    I think they are just a high service item..
    I even had a new one a new months back and that is now squeaking a little.
    I would always use lube.... but swamp it, so there is loads on there..
    Andy
    there is no such thing as bad weather, just the wrong clothes!!
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    617
    Quote Originally Posted by AndyC View Post
    Andy
    Thanks for the reply, but the pin (even when cleaned off etc) is a very cosy fit into the caliper carrier so its very hard (unless you're using something very runny like Molyslip) to get much grease in there.......
    That's why I think that the thin layer of grease that I do get in there soon gets cooked and effectively causes the pin to seize?
    I can't help think that running the pins dry is better than having this issue every few months?
    I've got some powdered graphite here in a tube for easy dispensing , so am wondering if cleaned pins and caliper carriers + graphite might be the solution?
    Cheers.
    a3tdi2001's Avatar
    437
    Might be worth cleaning out the carrier orifice and guide pin and then lubing it with silicone grease: SILICONE MULTI PURPOSE GREASE PLASTIC RUBBER CARLUBE | eBay
    From a bike thread but gives you some information: Don't use copper grease on caliper sliding pins [Archive] - SV650.org - SV650 & Gladius 650 Forum
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    617
    Quote Originally Posted by a3tdi2001 View Post
    Cheers, funnily enough I did one side of the car this afternoon as that appeared to be sticking the most (need car for a meeting tomorrow so some emergency maintenance was essential) and used some silicone grease that I had lying around that I bought to lubricate my sunroof runners (its great stuff).
    I'm still more inclined to clean both sides out though and either run them dry or with powdered graphite...at least I know I'm not alone!
    a3tdi2001's Avatar
    437
    Wouldn't run them dry with the heat that is in the area. Think how an alloy wheel welds itself to the brake disc if you don't put a smear of grease on the mating face. I'd stick to the silicone grease. I've been two years now without any grief.
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    617
    Thanks, that's making me think twice now about running them dry!
    The odd thing is though, have had this car for almost 6 years and its only in the last 18 months that I've had issues with these pins ...very odd!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,345
    Yeh, i've had the same issue a few times, and i think its down to using copper grease or LM instead of the proper stuff.
    The OEM grease for sliders is white, so i presume its silicone grease as mentioned above. I used silicone stuff the last time and the caliper immediately felt much "freer" in the carrier than when using copper or LM grease.
    TD5 Land Rover Defender build
    a3tdi2001's Avatar
    437
    Using copper or moly grease near rubber or plastic is not advisable as it swells the rubber and causes friction.
    I use silicone grease anywhere that has rubber or plastic eg, caliper pistons, sliders, even works well on bootlid and bonnet struts. Really noticed the difference recently when I thought my mountain bike forks were knackered but changed from moly to silicone grease on the stanchions and they're as good as new again.
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    617
    As an update, I've sorted out the issue.....
    Turns out that the caliper handbrake mechanism was sticking, so even when the brake was fully released the pads were still partially binding on the disc.
    This was causing this particular wheel to slightly overheat and so the grease on the guide pin was becoming cooked!
    I had been wondering why my fuel economy hadn't been as good recently....!
    A replacement caliper later , along with new rear pads and all is well again.
    Am now using silicone grease on the pins, so touch wood there'll be no more trouble.....
    AndyC's Avatar
    Apr 2003
    Dorset
    716
    I will be honest.... I have Moly grease on mine and I pulled them apart after about 6 months and they were perfect. Even on the original caliper
    I had exactly the same problem with my calipers with the handbrake mech seizing....
    Glad you got it sorted.
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Beware of these sliders!
    I just had two brand new calipers put on the back of my S4 as they had 'seized' on.
    I took the new ones off this weekend as we did the rear bearings to find that the garage that had fitted them had not lubed the pins back up again and were bone dry/brown with rust dust and one had seized on again!
    As you can imagine, I was less than impressed.
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
    "Stick a V8 in it!"
    15,345
    And this is why my car never goes near a garage.
    We discovered when we did craigs reshell that the garage that changed the wheel bearing on the rear of his S4 had clamped the stainless braided brake hose with a pair of mole grips.
    No idea why, as you dont need to touch the hydraulic circuit to remove the upright, but surely everyone knows you dont use bloody mole grips on a stainless brake line ffs.
    AndyC's Avatar
    Apr 2003
    Dorset
    716
    Fecking hell, what a bunch of "yeee haaaaaar"
    I have hose ends I use for braided hoses as of course you cant clamp the damn things!! JESUS!
    "Stick a V8 in it!"
    15,345
    yeh. mole grips on a rubber hose works, but even thats a bit harsh tbh. Something you might do in a pinch when DIYing it but not something you'd expect from a garage.
    AndyC's Avatar
    Apr 2003
    Dorset
    716
    proper hose clamps are better than molies
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    617
    Looking into the lubrication issue again, I noticed on my ancient PC-installed copy of an electonic parts catalogue (is its name still banned on here?,lol?) that there was an item listed G 000 650 described as 'lubrication paste' on the same page as the rear caliper and carrier.
    Google brought up the info that it was a very high temperature grease for the sliders , and that there is an equivalent Febi-Bilstein product too (have mislaid the part number though).
    Looking on Ebay USA though it was full of 'ultra disc brake lube' made by Permatex amongst others, which appears to be exactly what we need ie very high temp grease for brake calipers, sadly there don't currently appear to be any European suppliers..
    In the meantime I still continue to run silicone grease on my sliders, but as it was primarily designed for sunroof track lubrication I worry about how durable its going to be.....
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    i tend to use a smidge of copper and then moly, works for me. RRG is for lubing rubber parts, i have used it on pistons and the like as it supposed to be for
  1. Front caliper slide pins.What tool to remove them?
    By mike-a in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th July 2011, 20:52
  2. Rear Brake caliper
    By gav in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2011, 20:27
  3. S3 front brake guide pins same as A3 2.0t?
    By emeraldA3guy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th October 2010, 02:12
  4. rear brake caliper
    By pafranky in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th February 2009, 20:13
  5. S6 Rear brake caliper..help!
    By crispin in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd August 2007, 13:06
