Sky InsuranceJMB Retrofits
    East Berkshire
    178
    turbo inlet oil pipe?
    1.8T AJB engine . Is the oil inlet pipe the one that comes out of the back of the block, runs along the side of the head ( on drivers side) and into the top of the turbo?
    Thanks.
    ChrisG
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Yep correct.
    East Berkshire
    178
    Thanks.
    It sits above the turbo with a thin tin plate type of heat shield.... open along the side ( to the turbo). Thought I could usefully provide much better protection from both turbo and the exhaust -- but didn't wish to seal heat in !
    On the other side it looks as if I could help shield the airbox area from radiant heat as well.
    You are lucky to have those Recaros in yours.... ticked some boxes on ours (hers really) but wish that Xenons and Recaros had been ticked as well .... but was running up the price too much and at the time (May 1999) didn't realise how good both items are !!
    ChrisG
    Aug 2010
    3,138
    Yes I no ive only seen like 5 with them that have been up for sale on eBay and Autotrader since I got the car.
    I wouldn't think you would need to shield it from any heat as when your driving I'd say the airflow is cool enough in the engine bay and the airbox aswell.
  1. A3 2.0L TDI Turbo Inlet pipe upgrade?
    By Herbsta1c in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th July 2011, 18:08
  2. Forge Motorsport Turbo Inlet Pipe - 1.8T S3 210/225 & TT 225
    By JamJay in forum For Sale/Wanted - Audi Parts
    Last Post: 21st May 2011, 19:13
  3. Red hose from turbo to inlet pipe.... should it have heat wrap???!!!
    By AWDMk1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th August 2010, 06:25
  4. nuespeed Turbo inlet pipe
    By kenny_boon in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th July 2006, 14:53
  5. Turbo inlet pipe for s-line (190bhp)
    Last Post: 24th February 2006, 17:34
