Results 1 to 11 of 11
    Kostas's Avatar
    104
    How big of a problem is this?
    while changing oil and filltes ect spoted this:
    can sameone point me to the wright direction what is it? how expensive? is it related with a biger problem? is it a DIY job? and maybe a part number?
    Aug 2009
    833
    what are we looking at.
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    dirt? not much as it can be de-greased and washed off,
    can you say more what the problem is?
    Kostas's Avatar
    104
    it looks like valve covered in oil
    Kostas's Avatar
    104
    I think it's actualy leaking oil all side of air filter box is covered in oil
    Turkster's Avatar
    Dec 2007
    2,723
    the elbow pipe looks loose to me, its not snug into as it should be, if the valve has gone then its about 100 for a new one (ebay for a 2nd hand unit about 50), is the sucker pipe connected to it sucking as to activate the gate inside it?
    Kostas's Avatar
    104
    Quote Originally Posted by Turkster View Post
    how can i check that?
    howdy quattro's Avatar
    Dec 2007
    boston, lincs
    318
    Do you feel a lack of power?? The first thing i'd do is wash it off as you can't see exactly where the oil is coming from and just monitor it, your not losing masses of oil and if its not affecting the performance then it couldn't hurt to give it a run here and there just so you can start to trace exactly where and hopefully why its leaking.
    Audi A4 S-line Avant 2.0T FSI
    Mar 2009
    Stevenage
    289
    Is it not just oil being taken up inlet as turbo cars do this(oil vapour build up). Then there is the vacuum operated valve on top that may just be puttuing the vapour out and made to look worse by dirt sticking. I had a year old B7 diesel that look similar but not as much. just give it a clean up and keep an eye on it as you say you noticed only when doing service. That old saying....If its not broke...dont fix it
    If it's got t*ts or wheels, it's TROUBLE!
    Kostas's Avatar
    104
    Quote Originally Posted by TorqueTerrorist View Post
    I'll do a little clean up and take it from there thanks for replys
    foolish3uk's Avatar
    Aug 2004
    in middle of nowhere
    458
    that the throttle cut off valve to give a diesel a crispier cut off, what you are seeing is the oil coming out of the boosted side of the intake system, audi oil is very thin so over time it can get out of the seals around this valve, or you may be looking at a turbo letting excessive oil into the boost system, as it is at the moment i would not get too worried about it, as at about 50-100 k this tends to develop due to perishing seals etc. if it get any worse then replace the valve! you cant get repair kits for them!
