Page 1 of 3 123 LastLast
Results 1 to 40 of 93
Like Tree2Likes
Thread: Glovebox Hinge Repair
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,704
    As we all know this is a common failure on the A4 - caused by the damper becoming stiff over time and placing extra strain on the hinge. A new glovebox is in the region of 150, but the hinge can be repaired.
    Firstly remove glovebox consists of three bolts along the top, and two underneath, and then disconnect light at plug - No pics sorry but it's a doddle!
    The removed glovebox will look like this:
    Turn the glovebox upside down and remove these pins. This is infact ridiculously hard! It took me ages to wiggle them free using molegrips and a screwdriver as leverage. It is possible to mend the hinge without removing the lid, but I wanted to make sure I had good access to do it as strongly as possible:
    It chews up the pin and surrounding area a bit, it looks bad here but can be tidied up, and the whole area is out of sight anyway:
    And this is the broken hinge:
    I made a bracket from an old kitchen door hinge, but any suitable piece of metal will do. Its a bit fiddly to bend it the exact shape, but worth persevering:
    I chose to glue it and screw it to be sure:
    Glovebox refitted:
    The culprit behind all this is this damper, the pictures show it in position both closed and extended.
    I chose to take the damper barrel apart and inside is an O ring which governs the resistance inside the barrel. Using a Stanley knife I trimmed about 2mm from all round the outside. This allows it slide much easier but still offer some resistance. At the very least ensure it's been well lubricated (Credit to Marc1 for that tip).
    therat and Audiholic like this.
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    Should make this a Sticky judging by the amount that have suffered it.
    Good post James
    Dec 2010
    Lincolnshire, UK
    29
    Yes i realise this is an old thread. bumping it others to see. This has happened to me today, so glad ive found this and dont have to buy a new glovebox!
    Shaun
    183
    Doesn't look the best I have to say, I did it a different way:
    Then filled the top of the hole with black silicone and it doesn't stand out as much :P
    Mar 2008
    Dorset
    13,704
    Quote Originally Posted by mlody View Post
    Doesn't look the best I have to say.
    Thanks very much.
    183
    Thanks very much.
    Don't get me wrong, but should have done something to make it look a little genuine, well it's still definitely better than getting a new glovebox for like 150 quid or whatever they are
    26,734
    Its also an issue for 8P's, infact allot of them, both my 8P's had to have a repair done, I used epoxy & some nails drilled in to both pieces to hold it in position as such, some grease inside the braking element (barrel) does the trick with maybe the addition of rubbing the rubber seal inside the barrel with some say 4-800 grade sandpaper to make it less tight.
    Mar 2008
    Dorset
    13,704
    Its worth following the advice detailed here:
    http://www.audi-sport.net/vb/a4-a4-c...over-150.html
    If I had done that then I wouldn't have needed to offend mlody with my untidy hinge repair.
    Avant4me's Avatar
    The're Graphite not black!!
    Mar 2010
    Bristol
    257
    And nobody wants an untidy hinge!!!!
    Official Fan Club member No 001!!
    26,734
    As long as its not too hairy or smells of fish then all good
    Jan 2011
    durham
    256
    thanks james! been waiting months for a black glovebox for mine from my local audi vw scrapyard! they want 45 when they get one in!!! not anymore tho thanks to you! be doing it myself! as for not looking genuine does anybody really give a **** what the inside of your glovebox looks like???
    Mar 2008
    Dorset
    13,704
    Ah - someone else who doesn't drive around with their glovebox down!
    A4 b6 TDI V6 Quattro Sport
    Nov 2010
    West london
    150
    That's three of us then hahaha it's fixed it works JOB DONE.
    Lancaster
    1,629
    Cheers James, mine went the other week. Need to sort it.
    To do: None yet.
    Mar 2011
    East Mids
    452
    Agree I would consider making this sticky
    B6 S4 4.2 V8 SILVER SALOON - BEIGE ALCANTARA - BOSE SYMPHONY - DRILLED/GROOVED FRONT DISCS
    FOR SALE: £6750ono
    Previous Cars
    .:R32 MKIV 3DR Pearl Black (Awesome car), Lexus RX300, Lexus LS400, Mitsubishi Shogun Sport V6, Audi TT Roadster 225, Range Rover Vogue 4.6 V8, Mazda RX8 231, Peugeot 307 CC 180, Subaru Impreza WRX 2.5, BMW520i, Lexus IS200,Golf GTi MKV, Audi A4 1.9TDi 130
    Mar 2008
    Dorset
    13,704
    Its is in the stickies, see here:
    Housekeeping
    Mar 2011
    S E Kent
    218
    I am looking to repair mine on an '06 B7 Cab but it appears to have wires running through the hinge- any thoughts
    Mar 2008
    Dorset
    13,704
    Its the switch for the internal light, it's built into the damper.
    26,734
    Yeah remove wires 1st
    Mar 2011
    S E Kent
    218
    Yes i see that but mine also has 2 wires passing therough the actual hinge
    26,734
    Got a pic?
    Maybe someone has added the glovebox handle illumination mod by a germany company, cause thats how I did my own.
    Mar 2011
    S E Kent
    218
    Got a pic?
    Mar 2011
    S E Kent
    218
    Ok these are a little clearer
    See the red and green wires below the poston
    Mar 2008
    Dorset
    13,704
    Hmm that is a bit strange! All I can think of is the illumination mod as mentioned by NHN. Does the handle light up at all?
    Mar 2011
    S E Kent
    218
    No I dont think so
    26,734
    Yeah thats very weird, as I cant see anything in the wiring or parts to indicate another circuit, whats that yellowy plastic thing below the wires & behind the hinge.
  28. #27
    Mar 2011
    S E Kent
    218
    Thats what the wires plug into. Defo not lit up
    I have the glovebox pass airbag switch- anything to do with that?
  29. #28
    26,734
    Huh, can you get any side views/closeups of that part?
  30. #29
    Mar 2011
    S E Kent
    218
    Ok here goes- not too easy to get into(as above I do have a 2006 B7)Hope i am ok posting off forum as it were.
    It is wired off the original loom- all looks original not a retro fit
  31. #30
    26,734
    Its strange cause it says in etka brake element with lid light, remind me where the light is in the B6/7 glovebox as I cant remember, if you unplug it does the light stop working?
  32. #31
    Mar 2011
    S E Kent
    218
    Yes light still works (ins in the roof of the glovebox r/h side towards the back)
  33. #32
    26,734
    Thats definitely oem as I recognise the connector, but whats it connected to, got me intrigued now, gonna go check wiring schematics.
  34. #33
    Mar 2011
    S E Kent
    218
    Ok ta.
    this has really scuppered my idea of a DIY fix for the hinge.
  35. #34
    26,734
    Do those 2 wires go to the glovebox 12 pin connector thats behind the glovebox & if so which pin numbers?
  36. #35
    Mar 2011
    S E Kent
    218
    Cant see as of yet have not had the whole box out.
    If I took it out what would I ned to do about the Passenger air bag switch, this is intergral on my glovebox
    Only had the car 1 week the good lady's not too keen on me ripping it apart
  37. #36
    Jan 2011
    661
    Im guessing if its not glovebox interior light it could be the footwell light ?
    2003 A4 Cab 2.4 V6 Manual / 43k miles genuine woohoo (on a 10 year old car lol) / Ebony Black Metallic / Full Grey Leather / Fully Electric Seats / Heated Seats / Interior Light Pack / Cruise / Wood / Bose Symphony II / Black roof
  38. #37
    26,734
    I was also thinking its linked to the passenger footwell light, but nothing shows this in elsa, if you can remove the glovebox & tell us where the wires goto then I can certain trace these in elsa.
    I still reckon you can fix the hinge, glovebox has to come out anyway.
  39. #38
    Mar 2011
    S E Kent
    218
    I dont have footwell lights.
    I will take the glovebox out but what about the passenger air bag switch?
    Bit worried I will cause a fault if I dont know what I am doing.
    Going to se a friend of Thursday whou owns a car radio shop locally- hope he may have a fix
  40. #39
    26,734
    Unless you disconnect the connector then the airbag light wont come on, so just tell us where wires goto etc & pin numbers along with pics would be good.
  41. #40
    Mar 2011
    S E Kent
    218
    I would really need to disconnect the wire as the switch is an intergral part of the glovebox
