Results 1 to 23 of 23
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Auto dimming rear view mirror
    I have the option of one from a B7, but it looks like that is mounted to the roof not bonded to the screen like mine, can anyone confirm?
    Anyone done this? Reading up it appears the auto mirror was only available as part of the pack with the auto lights, so I'm not sure if it would work as a standalone feature....
    Jan 2004
    York
    1,657
    It's bonded to the glass with a cover that hides the wiring. If it's a proper one it'll have wiring for the auto wipers/side mirror dimmer as well. If not, it's an aftermarket one.
    MY15 8V S3 Sportback with options
    s-line stu's Avatar
    West Midlands
    183
    James,
    Just been down to the car park to get something out of the car so had a quick look how mine is fixed (it's a B7 with auto lights). It looks like its bonded to the screen but there is a slim bit that goes up the screen and into the headlining which I assume is just ducting for the wiring.
    I can't load a picture at the moment as I have restricted internet access at work but if you want I can take a quick snap with my phone when I get home and upload it for you.
    Mar 2008
    Dorset
    13,856
    Thanks Stu that would be great. Mine is bonded to the screen but not an auto so I doubt that wiring will be present, but I will go and double check
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,850
    This should help, and by the sound of it the loom might be already there.
    http://www.audizine.com/forum/showth...t=Auto+dimming
    no_idea's Avatar
    Sep 2008
    Norfolk
    168
    Careful James as I believe the B7 mirror mount is a different diameter (larger). If you know a friendly windscreen fitter he may be able to change it for you, but there is always a danger of cracking the screen getting the old one off. Apart from that you will have to have your screen changed to a later one. On a screen which is meant for an auto dim mirror there is an outline that hides the wiring.
    You can fit just the mirror and not worry about coming home lights, auto wipers or auto lights. There are at least two different mirrors depending on what you want to fit. There is one without the other sensors built in, but if you are going to fit one you may as well have everything as we all know we are always looking to add more goodies.
    If you fit just the auto dim mirror it is quite straight forward I believe. It depends if you want the mirror to 'un-dim' when you put the car in reverse.
    I am looking at adding the mirror, I have already bought a pair of auto dimming door mirrors. These can be connected up so they all work together.
    I don't think any of the wiring is already there.
    Have a look at this link it is pretty good.
    http://www.audiforum.us/c5-platform/...-function.html
    A4 3.0 quattro sport avant B6
    s-line stu's Avatar
    West Midlands
    183
    James,
    Here are the photo's - I'm afraid the camera on my phone isn't very good (HTC Touch 3G) but hopefully they might help:
    s-line stu's Avatar
    West Midlands
    183
    There's a fixing kit shown at this link:
    http://www.parkingsensoronline.co.uk...7u8ki5u8qqtej3
    Mar 2008
    Dorset
    13,856
    Thanks all, I will read those links tomorrow.
    In all honesty it's looking like more trouble than it's worth! I drive with my rear blind up all the time anyway so I rarely if ever even dip the mirror. I had the chance to add a B7 mirror for not much money so thought it would be agood novelty - maybe that adapter will still allow me to do that.....?
    I'm certainly not going to go the effort of changing my windscreen for it.
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,850
    Quote Originally Posted by no_idea View Post
    B7 mirrors will bolt straight on and so will the RS4 B7 mirrors.
    Mar 2008
    Dorset
    13,856
    Quote Originally Posted by docurley View Post
    Just confirm You're referring to door mirrors and not rear view interior mirrors?
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,850
    Door mirrors and I would see no reason why the inside one would not fit either.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    I retro-fitted an auto-dimming rear view mirror to my B6 a couple of years ago. It's the easiest thing in the world to do. I bought one of these on Ebay. Gentex is the manufacturer of OEM units; this item is identical in operation, it just doesn't have the bulky plastic moulding attaching to the screen that you get with factory-fit.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Mar 2008
    Dorset
    13,856
    Quote Originally Posted by jdp1962 View Post
    Thanks for that, the link doesn't work but is it one of these?
    How did you get on with the electric then? Is the wiring already in place?
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Sorry about the broken link, Quattrojames, I'll try & re-post it in a minute. That is what I am referring to, but what I bought, and what is on sale in the (missing) link, was a mirror, with the adapter, and the wiring, all in one fell swoop.
    The existing mirror twists off the button, then the new mirror screws to the button using the adapter. The wiring is simple. One end plugs into the mirror housing, then the wire (very slim) can be tucked out of sight behind the leading edge between the head-lining and the windscreen, and then down the driver's door pillar into fuse box area for connecting to a suitable live and earth.
    Give me a minute or two to find those Ebay links
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Quattrojames, you have PM.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    This is the thread from 2007 in which I posted details of my self-installed GENK2 auto-dimming mirror, including pics. Just page down and you'll find them eventually. There's even a link to the installation instructions in there somewhere
    Mar 2008
    Dorset
    13,856
    Thanks Jeff
    no_idea's Avatar
    Sep 2008
    Norfolk
    168
    Door mirrors yes definitely straight swap, but I am fairly sure the interior mirror fixing changed. I stand corrected if this is not the case.
    henry74's Avatar
    Feb 2007
    Verwood, Dorset
    115
    Wink
    Like a bloke covered in Tipp-Ex!!
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    948
    I retro-fitted a B6 Auto-Dipping Mirror - purchased the mirror from the stealers ~115 inc VAT (2 years ago). Made up my own wiring loom and plug - now know I could have got the plug too with a little bit more research. All works fine including the reverse signal which was the hardest signal to source!
    I was going to purchase the "revised" mirror with the on/off switch which also has capability to feed the light sensor signal to your Power Control module to enable the "Auto lights" and "Coming Home lights" - but I decided against this as would have to purchase a new Power Control Module, Light Switch, Additional coming home switch, etc. and alot more changes to the wiring.
    The mirror wiring is straight forward however the one signal I had trouble finding was the reverse signal. On a manual this can be picked up in the n/s passenger footwell a-pillar connectiion rack BUT with an Auto (Tiptronic) I eventually found it in the Plenum chamber under the ECU and Transmission CU. Tapped in a feed here.
    Auto Dipping Wing mirrors would be nice to add but the glass is around 160 per side! The signals are there on the internal Auto Mirror to feed to the doors. Not sure if there is a cheaper source for this external glass?
    Kufatec do a wiring harness for the B6 mirror B6 Link Here and the B7 mirror B7 Link Here - they are the same part numbers!
    B6 Mirror Wires (no switch on mirror, no light sensor feed for additional features):
    Pin 1 = White = +12v (from Fuse S231)
    Pin 2 = Black = 0v
    Pin 3 = Grey = Reverse Signal (Mirror goes clear if you engage reverse)
    Pin 4 = Yellow = Wing Mirror Signal 1
    Pin 5 = Brown = Wing Mirror Signal 2
    Pin 6 = Interior Light (W1) will require addition of diode (Mirror goes clear if the interior light goes on - did not do this mod!)
    On the later B6 mirror, with switch, and light sensor for other features,
    Pin 1 = +12v from power control unit
    Pin 3 = goes to power control unit (This is used for light sensor output)
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
    V6 Quatt's Avatar
    Feb 2008
    783
    Intresting post, Have one in my V6 Audi
    Torque the Torque
    andyccr's Avatar
    2003 1.8T Sport Ebony Black A4 Cabriolet
    Jan 2007
    Chelmsford, Essex
    440
    Did the conversion, took the B6 and B7 mirrors apart and mounted the B7mirror housing onto the B6 mount. Not a quick job but all done and wired up to work properly and it also dims my wing mirror glass -
    This is NOT a job for beginners, and in my B6 cab there was NO wiring in the headlining
    Andy
    B6 1.8T Sport Cabriolet - Ebony Black & Red Sports Leather-19" Sportec Mono10s-Bootlip spoiler-One touch roof module-Green Cotton filter-Forge 007 - 2007 rear lamps-2007 OEM interior dimming compass mirror-OEM S4 heated, elec folding, dimming aluminium door mirrors-2007 RS4 cabriolet exhaust-2007 RS4 Carbon trim-2007 RS4 starter button-2007 RS4 inner door handles- A4 DTM carbon front splitter
    1994 UK MX5 in rare Laguna Blue
    2003 Yamaha R1 (5PW) Tech Silver - not standard !
