Hi
I have 02 Audi A4 TDi it is constantly needing new bulbs in brake lights and now the headlights (dipped) have started to go as well - has anyone else had this problem and how can I fix it??
buy better quality bulbs?
My local factors does proper "Ring" bulbs and i've never had a problem with them. Cheap crap will last about 10 minutes.
What you need is the sort of double filament bulbs that are the Audi OE fitment, these absorb mechanical and temperature shocks much better than the standard Halfrauds stuff so they last longer.Tried that mate. tried some bulbs costing 20 quid for a pair, dunno what it was called, some performance ones (im not that into car performance and upgrade as you can tell lol).
"Performance" bulbs are LESS reliable than standard ones - since the filaments are run at a higher temperature and become more brittle.
If it were over-voltage how come it affects more than one OP? Short bulb life is a widespread problem on B6/B7s.
IMHO it's using cheap single wound filament bulbs that cannot cope with the vibration and temperature variations (don't foget B6/B7 headlights are prone to having moisture ingress which makes the conditions harsher than most car headllights).
