alarm beep help? vag-com?
vw754
vorsprung Durch Technik
U.K
HOW do i set my alarm so it bleeps when doors are locked ???
A4 TDI (B6) 2001
Also which version of vag-com will do it?
Cheers,now thats done,how can i make the windows go up when i lock the doors via remote?
You can't make them automatically go up when you lock the door but you can control them using the remote by holding down either the lock button (close windows) or the unlock button (open windows).
To do this it's a two step process.
You need to check adaptation channel 62 of the Central Convenience module (module 46). Make sure the correct bits are set high or set to a value of 1. See the Ross-tech link I provided above.
Then once you know the bits are set high for the features you want then you can recode the Central Convenience module. You will need to add a decimal value of 64 to your control module coding. You can start here and do this first and see if it works since by default the adaptation channel 62 should have all the bits set high already but this may not be the case outside of the USA.
456
466
768
855
800
