Like Tree1Likes
  • 1 Post By LucyT
Thread: Door wiring harness problems
    LucyT's Avatar
    Feb 2014
    Hi, last week I lost all controls and central locking to the drivers door. Have stripped it down and found that the wires between the body and the door are broken/ split. This May seem an odd question but are all the wires meant to be attached, I don't have elec rear windows.
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,612
    Hi and welcome.
    If you have a wire coming from the plug that has been cut/snapped then yes it should have a partner. It's possible the remaining wire has been pulled/fallen back through so it may not be visible. Have a good feel around for the loose ends.
    Rejoin the wires with solder if possible and cover with heat shrink to help protect the joins.
    Dan
    2002 2.5 V6 Quattro
    LucyT's Avatar
    Feb 2014
    Ok thanks Dan. I've taken it apart and my husband can do the repairing the wires are so tight I had a little look for the matching halves but gave up when it started raining again. Is there anywhere I can find a diagram of the harness? have googled but found nothing.
    S4_dan's Avatar
    Jan 2006
    1,612
    You will have to ask someone who has ETKA and they should be able to get wiring diagrams.
    You may have to extend the wires anyway to join them.
    Dan
    2002 2.5 V6 Quattro
    LucyT's Avatar
    Feb 2014
    All soldered and fixed, I now like my car again
    S4_dan likes this.
  1. Coilpack Wiring Harness
    By mnadeem1984 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th March 2007, 06:20
  2. Airbag wiring harness (1.8T quattro Avant 04)
    By DJ in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th December 2006, 17:54
  3. Call to action!! Anybody who has/had door lock sensor problems
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th October 2005, 18:03
  4. Attn: Anyone who has/had door lock sensor problems!
    By VAGMAN1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th September 2005, 21:23
  5. s3 door speakers - depth problem
    By A4Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd June 2004, 09:49
