Chris NottVolks Autos
Results 1 to 20 of 20
Like Tree2Likes
  • 1 Post By adamss24
  • 1 Post By quattrojames
Thread: Pre-cat removal 2.5 & Exhaust options
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,596
    Just bought a fully gutted pre-cat for a massive sum of £1.70! £6 postage so not all bad :-)
    Why not gut my own? Well I'd rather keep one in good shape in case of future problems/issues/MOT's etc etc. And at £1.70!!!!
    So, I know access is easy at the turbo end but the other end? Is it access from under car or do I need to drop the full system to swap it out?
    I'm hoping it may alleviate the lack of torque/power issue on my 2.5.
    I know there are two more cats a bit further along and will look at having them removed in the future.
    Am I right in saying that after the cats is one silencer where the pipes split and lead to the rear boxes on each side?
    If so, has anyone removed the middle box and left the two rear boxes
    or
    Leave the middle box and removed the rear boxes?
    Cheers,
    Dan
    2002 2.5 V6 Quattro
    Jul 2007
    London
    3,235
    It does not make that much effect to be honest ! I still run mine...but no main cats though !
    FOR SALE:
    Oct 2013
    181
    I guess the engine management system limits any big differences but in the past on other cars I've generally noticed the turbo spools up / kicks in a little sooner.
    S4_dan's Avatar
    Jan 2006
    1,596
    Quote Originally Posted by adamss24 View Post
    What did you replace the main cats with Chris? Something homemade or a purchased pipe?
    2002 2.5 V6 Quattro
    S4_dan's Avatar
    Jan 2006
    1,596
    Quote Originally Posted by MooLard View Post
    Fingers crossed it might help my no torque issue below 2000 rpm then.
    2002 2.5 V6 Quattro
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,152
    I have no cats in mine, passes its MOT every time.
    I have a full stainless system, with two silencers either side on the rear tail-pipes.
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
    S4_dan's Avatar
    Jan 2006
    1,596
    Quote Originally Posted by AlexGSi2000 View Post
    Do you still have the pre cat in?
    What does your sound like then? Any videos?
    2002 2.5 V6 Quattro
    Feb 2012
    Liverpool
    1,152
    Quote Originally Posted by S4_dan View Post
    Pre-cat pipe is still there but the innards have been removed.
    It sounds really good to be fair, I have a few more recent videos which I can upload, this one is fairly old - it sounds a little different now due to the engine running properly. (a lot of turbo blow-off noise in this, its a lot less now!)
    - Weitec GT
    VagCabby's Avatar
    Apr 2012
    Crawley, West Sussex
    224
    I gutted my pre cat and main cat last week on the 2.5tdi 163. The diffence is amazing car is alot more responsive and suprisingly smokes less!
    I did the pre cat first and it made bugger all difference so I did the main cat a day later and that made the difference.
    to remove the pre cat the easiest way is
    1. Unbolt the 3 bolts holding the pre cat to the turbo and loosen off the pre cat from the turbo
    2. Get under the car and remove the drive shaft guard above your nsf drive shaft
    3. Unbolt the front exhaust mount (held on by two bolts) this allows the access to a pita bolt!
    4. Rach up from under the car and unbolt the 3 bolts secueing the pre cat to the exhaust
    5. Pull the pre cat out from the top of the engine bay.
    once you have done it once it takes about 10 mins to remove
    Audi A4 Cabriolet 2.5TDI 163 Sport
    Full Interior Lighting Pack - Puddle Lights, Footwell Lights, Door Markers, Handle Ambient Lights, Air Vent Illumination, Armrest Illumination, Roof Ambient Lights. Auto Dim Rear View Mirror, Cruise Control, Full DIS, Genuine 6 Disc CD Changer in Glovebox, RNSE, Remote Windows, Parrot Bluetooth, Storage Pack, Full Leather, Heated Mirrors.
    S4_dan's Avatar
    Jan 2006
    1,596
    Good info there VagCabby.
    Cheers, I'll have a go as soon as I get chance. Do you only have one main cat on your system? Mine has two I'm led to believe. Not looked under the car at the front yet.
    Cheers.
    2002 2.5 V6 Quattro
    S4_dan's Avatar
    Jan 2006
    1,596
    Sounds good. What causes the blow off noise then? Did you turbo whistle a little before doing the exhaust?
    Dan
    2002 2.5 V6 Quattro
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Or, buy my system with it's lovely shiny stainless tips and gut away to your hearts content, and then keep your system perfect to replace when you sell it
    S4_dan's Avatar
    Jan 2006
    1,596
    Is that a standard system James?
    2002 2.5 V6 Quattro
    Jul 2007
    London
    3,235
    It was a custom made 3" downpipe splitting into 2x 2.25" twin exhaust branches.
    FOR SALE:
    S4_dan's Avatar
    Jan 2006
    1,596
    Looks sweet! Does she sound good?
    2002 2.5 V6 Quattro
    Mar 2008
    Dorset
    13,856
    Yep.
    Jul 2007
    London
    3,235
    If you're talking about mine (!), it sounds lovely on idle- nice burble on tick-over and gets bit throaty as the revs increase but no drone on long motorway runs ! One of the best exhausts i've heard in a long time...
    S4_dan likes this.
    FOR SALE:
    VagCabby's Avatar
    Apr 2012
    224
    Cheers.
    no worries
    mine goes from the pre cat into a very big main cat the a long single pipe into a large silencer which splits into 2 and goes to 2 back boxes I think yours will split after the pre cat due to being a quattro, mine is FWD
    S4_dan's Avatar
    Jan 2006
    1,596
    Yep.
    If it was a custom system I may have been tempted James. Looking for a bit of growling under throttle plus free flow in the hope I could restore my no torque issue before 2k rpm. At least that's what I keep telling myself. Lol
    2002 2.5 V6 Quattro
    Mar 2008
    Dorset
    13,856
    No problem, I'll be ebaying my standard system soon and just wondered if it was any use for you to gut the cats etc off the car whilst still keeping your original set up in one piece.
    S4_dan likes this.
  1. 2.0TFSI Pre-Cat Removal
    By jb0o in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th March 2014, 22:52
  2. Pre cat and cat/dpf removal 2.5tdi
    By DAZ1985 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd December 2011, 14:38
  3. pre made boxes/enclosures for amps etc
    By mordz in forum In-Car Entertainment
    Last Post: 1st April 2007, 20:21
  4. A4 Quattro S/S Exhaust Options
    By naefeart_A4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st October 2006, 18:26
  5. audi v8 4cam cat removal?
    By sssammm in forum Tuning
    Last Post: 11th March 2004, 17:33
