    glenandem's Avatar
    Sep 2012
    manchester
    529
    B5 engine mount on b6 1.9 tdi
    Anyone replaced the drivers engine mount on they're b6 a4 with a b5 s4 mount, seen some febi ones on eBay for £30 as opposed to £90 for the correct part no one from tps, I only have the passenger side which has the sensor on and have read on other forums that some guys have replaced they're b6 mounts with b5 s4 mounts as they think they're slightly stiffer, I'm only looking to fit one of these as they're cheaper!
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,348
    Fairly sure they're the same across the b6/b7/b8 range, either way best to go aftermarket with the amount of mount's not holding up... maybe it's wear and tear but there's been a fair few broken (mine included) but surely you'd expect them to last the life of the car.
    2,178
    All depends on what you classify as the life of a car. (I'm sure I read that audi say the life of a car is 10 years and 200K miles) on one of my B5's I replaced the mounts after 13 years & 270K, but I've seen them go on cars with less than 100K. I guess it's all down to the manufacture who made the mount and if they were cutting corners to keep the costs down, and the guy who made the mount, was it a Friday afternoon special.
    glenandem's Avatar
    Sep 2012
    manchester
    529
    yeah mine looks original but has the purple ooze at the bottom of it!
    ive replaced the ns due to giving the fault code they give but the os doesnt have the sensor in and ive read that alot of people replace them with the 034 or b5 s4 mounts so im gonna fit the s4 mount as theyre quite cheap on ebay and theyre febi ones which are supposed to be ok.
    Sep 2013
    33
    I've replaced mine with B5 rubber of standard A4 saloon. They fit fine.
    glenandem's Avatar
    Sep 2012
    manchester
    529
    Quote Originally Posted by Google44 View Post
    yup your right, I recieved it in the post this morning and went straight out to fit it, very easy to do took about ten mins to do!
    took me much longer replacing the anti roll bar links I had!
    definately feels less movement in gearstick now and when I use to rev the engine you could feel it rock the car, now it's hardly noticeable!
    just need to take it on mway now see if its done anything for my vibration issue?
  1. 1.9 tdi engine mount fault code on vcds
    By glenandem in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th February 2013, 20:35
  2. checking 1.9 tdi fwd engine mounts and bad vibration
    Last Post: 30th January 2013, 19:57
  3. Changing an engine mount on a 2.5 TDI
    By Turkster in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd April 2012, 00:03
  4. 2.5 v6 tdi engine mount swap
    By swarcup in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th September 2011, 21:47
  5. 2.0 TDI engine mount failure
    By pioneer181 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th February 2010, 15:27
