Volks AutosEM Tuning
Results 1 to 26 of 26
    May 2013
    47
    Visit _adam_'s Instagram Channel
    Long time lurker with problem that's driving me bonkers - central locking
    Hi,
    Not really a VAG man but I've owned my A4 for a few months now and slowly been changing things to get it to a standard that I'm happy with but I've got a locking issue that's got me stumped.
    Ive been browsing threads to try and solve it but to no avail, basically the car keeps locking itself every 30secs but could be as long as 15min until the battery's flat over a couple of days. Also the car won't sleep as the warning triangle pulses constantly when it's locked.
    What I've done
    1. Checked door looms and removed and repaired both front ones
    2. Inspected CCM and alls dry with no sign of water ingress.
    3. Swapped drivers door module
    4. New battery
    5. Gone mad
    6. Vagcom showed no comm with drivers door but loom repair sorted that. All doors report shut and locked
    Any ideas???
    Heres the offending possessed car
    Jul 2007
    770
    Vagcom should reveal the fault which could be the door lock which is not registering shut when it should.However I have experienced Vagcom failing and that's when problems really start
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    2. Inspected CCM and alls dry with sign of water ingress
    could still be this causeing the problem if it was wet at one time.
    May 2013
    47
    Apoligies typing error on my part theres NO sign of water anyhere it all dry as a bone including the bulkhead.
    Im gaggin to get the car mapped and a exhaust chucked on but this needs solving first before i put the car on the road
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,152
    Deffo a wiring issue this.
    If it keeps locking after 30 seconds then the control module isnt registering that a door has been opened. (accidental unlock safety feature)
    Have you repaired the rear door looms? the same issue happens here, I need to do mine.
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
    May 2013
    47
    A door has been opened ?
    It locks as the car is stood with the doors shut and alarm armed. I've inspected the rear looms and all seem ok one tiny split in a wire but that was it. I think i might strip them out completetly like i did the fronts.
    The locks cycling is very random it cound be 30 sec could be 10sec could be 10 mins if you see what i mean. Just sits there randomly locking the doors.
    Dec 2006
    barnsley
    1,016
    the hazard warning light on my seat leon started doing this and cycling the central locking and flashing the lights as if the alarm was getting an indication to go off
    in the end i changed the hazard warning switch and all was well
    im aware its not the same car but is it possible to remove the hazard switch and see if it still does it ???
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    May 2013
    47
    Quote Originally Posted by dualmono21 View Post
    Never really thought it could be that but i'll try it tonight. Cheers for the heads up.
    Oct 2012
    429
    had a hazard switch prob on an a3 one time caused a lot of wierdness, recently my passat has had water in the ccm (under thre passenger carpet dumb place to put it imo) that caused the left side indicators to come on permanently thus flat battery, after 3 hrs worth of solder and a re program with vcds the car seems touch wood to behave
    May 2013
    47
    Just tried the hazard switch disconnected still locks itself. Weird thing is when it locks itself it doesn't arm the alarm system just locks the doors.
    Dec 2006
    barnsley
    1,016
    do you have anyone local who you can temporarily swap the part for theres ?
    May 2013
    47
    Would be nice to try a ccm on the car before I start chasing wiring faults I'm in chesterfield Derbyshire if anyone's local an up for it. I don't mind buying one if I know I'm spending £200 to cure it !!
    May 2013
    47
    So as I was given an hour off I decided to put my mind to rest about water ingress I decided to get the hose and blast the bulk head and make sure it is draining properly.
    Water was draining nicely from the centre so I decided to give the cabin filter area ALOT of water to see if any made it through, to be fair for the amount of water I blasted at it only a minimal amount made it through.
    I stripped out the ccm and double checked for any damaged and it clean as it could be. I even opened it up to check the pcb for dry joints etc and it looks perfect.
    I even stripped the loom back to the bulkhead to look for any corrosion and no sign at all, so I'm back to square one and off to strip the rear door looms out next to see if I can find a fault
    crazy88's Avatar
    Loving the anonymity
    West Yorkshire
    4,806
    Yeah, i'd say that CCM has not had water ingress, looks perfect inside. And no obvious blown components on the PCB?
    Hope you find the issue mate, it's an odd one!
    bez101's Avatar
    Jul 2008
    8,491
    anymore codes come up ?
    May 2013
    47
    Not scanned it recently ill drop it on again tomorrow.
    Nothing obvious on the pcb and the water only made it down there cos I forced it down there. Could do with someone that's a bit handy with vagcom as I'm only really looking at the basics if anyone's local ish and fancies some beer tokens (Derbyshire)
    bez101's Avatar
    Jul 2008
    8,491
    im in sheffield if you want me to plug it in and have a look
    May 2013
    47
    That'd be great if you could, I could pop up whenever suits you I'm only in chesterfield. If you could pm me your number and ill get in touch.
    bez101's Avatar
    Jul 2008
    8,491
    07552111073
    txt me tmoro and ill meet up with you
    lee.
    May 2013
    47
    Will do cheers.
    bez101's Avatar
    Jul 2008
    8,491
    had adam over tonight only code is 01336 - Data Bus for Comfort System: Single-Wire Operation
    all moduals etc seem to be ok
    what the car does is when the door doors are shut left unlocked.
    around 30 seconds when the clocks and light shut down the doors lock (alarm does not arm)
    then around every 30 seconds it locks again (never unlocks)
    als when locked with fob alarm arms then relocks again and again
    any ideas ? NHN think this is in your field ?
    Dec 2006
    barnsley
    1,016
    bez
    just checked my records and that fault code seems familiar
    i had 01336-37-10 faulty intermittant
    turned out it was one of the coding settings on the instrument cluster which had basically forgotten what it should be
    i recoded it and all was fine from there onwards
    hope this helps mate
    May 2013
    47
    Ive isolated this to the passenger front door last night after disconnecting door looms and then try to arm the alarm. With the passenger front disconnected the car goes to sleep and doesnt try locking!!! Happy isn't the word!
    I'll pull the door to pieces and go from there.
    bez101's Avatar
    Jul 2008
    8,491
    nice 1 glad its just about sorted
    hopeyou can fix the loom and not need to buy new.
    May 2013
    47
    Scratch that it's not isolated to that door
    Carry on head scratching, so lee if you can source a ccm for me to try it would be great
    bez101's Avatar
    Jul 2008
    8,491
    ill get onto it sfter the weekend
  1. Long Time Lurker
    By Skaylesh in forum The Welcome Section
    Last Post: 15th May 2012, 22:04
  2. Drive side intermittent central locking
    By m3tin in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th November 2011, 08:16
  3. Long time to start - hunting with misfire
    By salad.dodger in forum General Technical / How To
    Last Post: 18th June 2011, 12:45
  4. Replies: 4
    Last Post: 10th March 2005, 23:04
  5. How long from build week to on my drive?
    By JSportback in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th November 2004, 00:23
