Chris NottEM Tuning
Results 1 to 17 of 17
    pauldazzle's Avatar
    Cardiff
    621
    PD 130 Injector problem
    My A4 threw a code today 17669 cylinder 1 maximum range exceeded.
    Been logging my injectors this afternoon on VCDS, & injectors 1 & 4 are reading 127 all the time. It's had a new injector loom last year so I doubt that's the problem.
    Anyone got any experience with PD injectors?
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat, 165bhp remap, EGR delete, K&N panel, Dunlop SP Sport Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
    dale86's Avatar
    Oct 2012
    354
    I had this on mine it slightly idles a bit lumpy very slightly on start up but touch the accelerator and it goes I too ahd an injector loom fitted to no avail still did it then the mechanic exsplained that he was a trained audi tech and that there was sum kind of problem on the 02 plate a4s snd it was gna cost too much to fix so i just deal with it .
    Audi Doodah's Avatar
    Sep 2012
    Swindon
    371
    When you say 127 do you mean 1.27mg/st. General consesus is over +/- 1.0 suggests an issue even though VCDS suggests +/- 2.5. Check cam lobes for signs of wear and run some diesel purge through them then check for any improvement.
    I've linked to a recent thread on that other forum describing a very similar issue to yours!
    A4 Avant 1.9 TDi Sport GmbH
    pauldazzle's Avatar
    Cardiff
    621
    Well I disconnected my Van Aarken smart box, & got a totally different set of readings in measuring blocks 013, & 023. Engine was at idle with the occasional blip of the accelerator.
    I can't work out whether I have 3 problem injectors (1,2,&4) or just 1 on injector 3.
    Can anyone shed any light?
    Wednesday 8 May 2013 12:17:17
    038 906 019 LJ 1.9l R4 EDC G400SG 4910
    Group A: 013 Group B: 018 Group C: 023
    Cyl 1 Cyl 2 Cyl 3 Cyl 4 Cyl 1 Cyl 2 Cyl 3 Cyl 4 (no units) (no units) (no units) (no units)
    TIME -2.8 to +2.8 mg/H -2.8 to +2.8 mg/H -2.8 to +2.8 mg/H -2.8 to +2.8 mg/H TIME 0 0 0 0 TIME
    Marker STAMP mg/str mg/str mg/str mg/str STAMP STAMP
    0.7 -0.28 -0.26 0.61 -0.09 0.01 0 0 0 0 0.32 12 9 -19 20
    1.87 -0.24 -0.21 0.56 -0.14 1.08 0 0 0 0 1.46 9 9 -17 19
    3.03 -0.26 -0.14 0.52 -0.12 2.25 0 0 0 0 2.64 3 13 -12 16
    4.22 -0.21 -0.16 0.49 -0.09 3.42 0 0 0 0 3.83 5 9 -16 17
    5.38 -0.21 -0.14 0.45 -0.12 4.6 0 0 0 0 5.01 9 12 -14 20
    6.54 -0.21 -0.12 0.4 -0.09 5.78 0 0 0 0 6.16 8 10 -13 19
    7.72 -0.24 -0.12 0.42 -0.07 6.95 0 0 0 0 7.34 7 13 -16 21
    8.9 -0.26 -0.21 0.52 -0.05 8.12 0 0 0 0 8.5 11 13 -17 24
    10.02 -0.26 -0.19 0.52 -0.05 9.28 0 0 0 0 9.66 10 10 -14 22
    11.09 -0.24 -0.24 0.54 -0.07 10.38 0 0 0 0 10.73 8 13 -15 23
    12.17 -0.26 -0.24 0.54 -0.05 11.45 0 0 0 0 11.82 8 12 -15 20
    13.37 -0.28 -0.26 0.54 0 12.55 0 0 0 0 12.95 10 15 -15 19
    14.56 -0.31 -0.28 0.54 0 13.77 0 0 0 0 14.17 8 12 -13 18
    15.74 -0.31 -0.26 0.59 0 14.95 0 0 0 0 15.34 10 9 -20 22
    16.92 -0.35 -0.19 0.52 0 16.14 0 0 0 0 16.52 14 10 -16 18
    18.08 -0.35 -0.21 0.54 0 17.3 0 0 0 0 17.7 5 14 -11 14
    19.23 -0.28 -0.19 0.52 -0.12 18.48 0 0 0 0 18.86 10 11 -17 15
    20.32 -0.28 -0.19 0.52 -0.12 19.6 0 0 4 0 19.96 -3 -3 -45 -12
    21.43 -0.26 -0.16 0.56 -0.07 20.68 4 4 4 4 21.05 -3 -3 -45 -12
    22.6 -0.42 -0.52 0.87 0.05 21.81 0 0 0 0 22.2 5 8 -17 9
    23.74 -0.45 -0.42 0.82 0 22.98 0 0 0 0 23.38 9 9 -15 17
    24.92 -0.38 -0.35 0.82 -0.07 24.12 0 0 0 0 24.52 11 14 -15 14
    26.08 -0.33 -0.26 0.75 -0.12 25.3 0 0 0 0 25.7 13 15 -17 14
    27.28 -0.38 -0.26 0.73 -0.09 26.49 0 0 0 0 26.88 12 11 -14 22
    28.46 -0.42 -0.26 0.78 -0.07 27.68 0 0 0 0 28.06 10 8 -20 20
    29.62 -0.42 -0.26 0.75 -0.07 28.84 0 0 0 0 29.24 12 16 -14 22
    30.78 -0.42 -0.33 0.8 -0.07 30.02 0 0 0 0 30.4 8 13 -17 20
    31.96 -0.4 -0.31 0.78 -0.07 31.18 0 0 0 0 31.56 9 14 -14 21
    33.12 -0.4 -0.31 0.8 -0.09 32.36 0 0 0 0 32.74 6 13 -36 8
    34.19 -0.4 -0.31 0.8 -0.09 33.47 0 0 0 0 33.83 -10 -7 -43 2
    35.27 -0.4 -0.31 0.8 -0.09 34.55 4 4 4 4 34.91 -10 -7 -43 2
    36.4 -0.4 -0.31 0.8 -0.09 35.64 0 0 0 0 36.01 -4 4 -30 -8
    37.61 -0.4 -0.31 0.8 -0.09 36.81 4 4 4 4 37.21 -16 -21 -39 0
    38.78 -0.4 -0.31 0.8 -0.09 38 4 4 4 4 38.4 -16 -21 -39 0
    39.96 -0.42 -0.14 0.78 -0.19 39.18 4 0 4 0 39.56 -4 -4 -21 7
    41.12 -0.4 -0.09 0.68 -0.19 40.34 0 0 0 0 40.74 6 2 -16 14
    42.3 -0.47 -0.14 0.78 -0.16 41.52 0 0 0 0 41.9 6 5 -13 18
    43.37 -0.4 -0.07 0.68 -0.21 42.66 0 0 0 0 43.02 12 8 -16 15
    44.49 -0.38 -0.07 0.73 -0.28 43.74 0 0 0 0 44.1 12 8 -15 23
    45.66 -0.42 -0.07 0.75 -0.26 44.87 0 0 0 0 45.26 12 11 -21 21
    46.82 -0.38 -0.05 0.73 -0.33 46.04 0 0 0 0 46.43 8 13 -17 22
    47.93 -0.42 -0.12 0.8 -0.21 47.2 0 0 0 0 47.55 14 16 -15 19
    49.11 -0.49 -0.21 0.87 -0.16 48.33 0 0 0 0 48.7 15 14 -17 16
    50.26 -0.52 -0.28 0.96 -0.16 49.48 0 0 0 0 49.88 17 11 -19 22
    51.44 -0.49 -0.33 1.04 -0.21 50.66 0 0 0 0 51.04 15 10 -16 18
    52.6 -0.42 -0.33 1.04 -0.31 51.82 0 0 0 0 52.2 10 12 -18 21
    53.76 -0.38 -0.33 1.04 -0.35 52.98 0 0 0 0 53.38 13 10 -15 11
    54.95 -0.31 -0.26 0.99 -0.45 54.16 0 0 0 0 54.54 5 11 -18 19
    56.1 -0.28 -0.21 0.94 -0.45 55.32 0 0 0 0 55.72 10 9 -17 17
    57.21 -0.42 -0.26 1.01 -0.28 56.5 0 0 0 0 56.85 8 7 -14 14
    58.29 -0.59 -0.16 0.92 -0.16 57.57 0 0 0 0 57.93 6 10 -10 19
    59.38 -0.52 0 0.73 -0.26 58.65 0 0 0 0 59.01 6 11 -12 18
    60.56 -0.35 -0.12 0.85 -0.38 59.78 0 0 0 0 60.16 13 12 -15 19
    61.74 -0.31 -0.12 0.85 -0.42 60.96 0 0 0 0 61.36 8 8 -16 22
    62.9 -0.31 -0.05 0.78 -0.42 62.12 0 0 0 0 62.52 7 12 -12 19
    64.08 -0.31 0 0.75 -0.42 63.3 0 0 0 0 63.68 10 8 -16 22
    65.24 -0.38 0.02 0.71 -0.38 64.46 0 0 0 0 64.86 13 9 -17 22
    66.38 -0.47 -0.09 0.8 -0.26 65.64 0 0 0 0 66.01 10 14 -14 22
    67.49 -0.49 -0.09 0.82 -0.26 66.73 0 0 0 0 67.1 13 12 -16 20
    68.63 -0.45 -0.07 0.78 -0.33 67.87 0 0 0 0 68.26 11 17 -15 15
    69.78 -0.45 -0.07 0.78 -0.33 69.02 4 4 4 4 69.4 0 -3 -46 -3
    70.91 -0.42 -0.05 0.8 -0.33 70.18 4 4 4 4 70.56 0 -3 -46 -3
    72.04 -0.33 -0.07 0.8 -0.42 71.28 0 0 0 0 71.66 6 10 -23 8
    73.22 -0.28 -0.28 0.99 -0.38 72.44 0 0 0 0 72.82 10 9 -17 14
    74.42 -0.42 -0.33 0.96 -0.24 73.62 0 0 0 0 74.02 10 10 -16 13
    75.62 -0.45 -0.26 0.87 -0.16 74.82 0 0 0 0 75.22 9 8 -16 17
    76.78 -0.35 -0.33 0.89 -0.24 76 0 0 0 0 76.4 6 9 -12 17
    pauldazzle's Avatar
    Cardiff
    621
    Quote Originally Posted by Audi Doodah View Post
    In measuring block 023 injectors 1 & 4 read 127 continuously, which changes cylinder depending where the jumpers are in the Van Aarken smart box. So as I mentioned in my last post I removed the VA smart box completely, & logged again. It now looks like injector 3 is constantly reading minus. I guess that could be because the other 3 are overfueling?
    Sep 2012
    Swindon
    371
    Doesn't look to be anything wrong with those figures. The four numbers in block 13 should add up to approximately 0, which yours do. See here
    And going off what's said here it looks like it's your smart box causing problems in blocks 18 and 23
    Just took reading of mine, cold engine & no revs - +0.6, -0.8, +0.2, +0.0 mg/st. These have been my approximate figures over the 7 months I've had the car and with and without my remap. My engine has never missed a beat and has never thrown up any fault codes.
    pauldazzle's Avatar
    Cardiff
    621
    Do you get any minus readings in block 023?
    Sep 2012
    Swindon
    371
    Didn't look on mine but the link I gave you shows a range of +/-0.25 ms. If the car runs fine and doesn't throw fault codes without the box installed then it's clear where the problem lies.
    I got a blacksmoke remap and a dodgy lead for £65 and get better quoted gains than your £350 box of resistors.
    pauldazzle's Avatar
    Cardiff
    621
    The car has always felt a bit sluggish compared to other PD 130 VW's that I've owned. It has moments when it goes like stink, with or without the VA box then just goes back to normal.
    The VA box has been on for months without any issues, & makes a big difference to performance & mpg.
    It's not one of those cheap tell the ECU the engine is cold jobbies, it actually plugs into the injector harness. New it cost over £400 but only cost me £50, & it's saved me that & more in fuel costs. I'm not defending tuning boxes against remaps as I've had all of my past VAG (7)cars mapped.
    I've been suspecting an injector issue for a while, & I think the VA box is just exaggerating the issue.
    The car only just scraped through emissions on its MOT last month (without the VA box connected)
    Thanks for that link by the way.
    Sep 2012
    Swindon
    371
    Just out of interest, have you checked your timing? Look for synchro angle in engine measuring blocks. I forget which block but it should be 0
    pauldazzle's Avatar
    Cardiff
    621
    Yeah synchro reads between 0.5 to 1.0.
    pauldazzle's Avatar
    Cardiff
    621
    Ok I adjusted the injector lash on Friday, they were all out spec especially 1 & 3. & it's made a big difference to performance. The cam lobes looked good so fingers crossed on that. However injector 3 still reads minus figures in block 023 all the time. so it looks like injector 3 has a problem so I'm going to swap it out & see what happens.
    Sep 2012
    Swindon
    371
    Be interested to see if you find any further issues. Just checked my and i get values between -5 and +25 in block 23 that vary constantly.
    What do you mean by injector lash?
    pauldazzle's Avatar
    Cardiff
    621
    Sep 2012
    Swindon
    371
    Ah, was familiar with the procedure but never heard it called lash before.
    Every day is a learning day!
    pauldazzle's Avatar
    Cardiff
    621
    Put a new injector in 3 this morning & no more minus figures in mb 023
    pauldazzle's Avatar
    Cardiff
    621
    It would appear that injector 3 was goosed when I bought the car, but must of fallen off the cliff recently. Car is running absolutely great now.
  1. Injector Problems Help!
    By O'Shea in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th June 2008, 16:21
  2. 1.9TDI PD 130 boost problem
    By sonix in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 27th March 2008, 17:11
  3. A4 1.9 TDI (130) engine problems - please help
    By Cue_Ball in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th March 2008, 14:28
  4. Tdi 130 hesitation problem
    By Burtney in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th March 2008, 02:03
  5. no1 injector problem on 1.9 tdi
    By tp7n in forum Diesel forum
    Last Post: 31st July 2005, 10:47
