EM TuningAH Fabrications
Results 1 to 15 of 15
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    439
    1.9tdi awx boost gauge help
    I'm after a boost gauge for my 1.9tdi
    just wondering where's tues best place to feed to boost pressure from ?
    i was going to buy a egr delete pipe from dark side developments and drill and tap a hose connector into it and run it from there?
    Failing this somewhere near the intercooler
    cherrs
    matty
    03 Mig blue 1.9tdi 130 saloon:- GMBH front, dark tints all round, fk coilovers,
    BMW TIGERCLAWS 19" 9j front + 10j rear, debadged rear. HIDs 6k, egr delete
    cominig soon:- votex rear,front end respray, parrot kit, remap, full paint correction
    Audi Doodah's Avatar
    Sep 2012
    Swindon
    371
    Allard egr deletes are pre-fabricated with a boost gauge tap-off.
    A4 Avant 1.9 TDi Sport GmbH
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    439
    Ah well that's made my job easier. I seem it before on other pd engines
    thanks mate. I think il just do that
    Sep 2012
    Swindon
    371
    Your welcome!
    Perhaps you could explain the need for a boost gauge to me then? As I see it, accelerator pressed & RPM 2000+ equals boost....accelerator not pressed equals no boost
    As an alternative, there are some "dongles" available nowadays that plug in to the diagnostics port and bluetooth engine data to your smartphone. Don't have any links but surely a "boost gauge" for the 21st century!?
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    439
    Over the last few month I have a few boost issues and limp mode. I got Paul with the black avant on here to vcds it and clear the codes.
    been relatively fine since. But I like to know what my engine is doing. Lol plus I can get one cheap, and I'm looking into a few engine mods soon.
    Sep 2012
    Swindon
    371
    Sounds like you need the Mr Muscle treatment. Ollie_B's thread is a good one and there's one or two others knocking around too. Failing that, a new N75 (boost pressure control valve). Was the fault code 17965 by any chance?
    What about getting VCDS for yourself? £20 ish for a "test lead" from ebay and a free download of VCDS-Lite (trial) from Ross Tech allows you to carry engine data logs which with give so much more information than just a boost reading. I've invested £68 to register my version of VCDS-Lite so I can now do auto-scans, coding and adaption...particularly useful if you're planning future mods and for about the same cost as an egr delete kit and boost gauge.
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    439
    I've got the lite version just need a lead.
    Also did the mr muscle clean thanks to ollie.
    i blanked the egr off and clean the turbo at the same time. I think it made a difference.
    Might actually remove the turbo and inlet one day and do it more thoroughly.
    I don't like the idea of adapting via vagcom. Not confident enough.
    Yeah I agree with the accuracy aswell. Just though the gauge could be a nice little touch aswell.
    Il probably buy a lead at some point. Just I'm more focused on other jobs on the car ATM.
    the boost gauge idea was just a quick cheap mod to help with day to day monitoring. Wether I get round to but one is a different story haha
    Sep 2012
    Swindon
    371
    If it's had a clean already then I'd be looking at the vacuum hose condition then. A small split could become more of a problem as the weather warms up and expands the rubber hoses ever so slightly.
    Found this excellent turbo clean how to on my internet travels, if you really want to get hands on.
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    439
    I seen some silicone replacement vacuum hose on eBay.
    Samco style, for cheap.
    Might have another look.
    thanks for your advice anyway
    not much experience with turbos an especially diesels
    Sep 2012
    Swindon
    371
    Ha, me neither but I'm an internet geek!
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    439
    That's what I'm doing now.
    getting my geek on! Haha
    Mentaldogmark's Avatar
    Jan 2014
    Newton Aycliffe, NE England
    20
    Follow Mentaldogmark On Twitter
    Quote Originally Posted by mattyb6 View Post
    cherrs
    matty
    I have used a pressure guage to see what is happening to my boost I just tapped it off the ecu pipe I got under 1bar but this didn't show properly ontil I was up to 4-4.5k rpm. An old boost guage might suggest you have leaks or weak turbo as I suspect I have in mine I have a spare turbo to be tested and if ok swap it out and sort out vac pipes etc. going to do this on mine first before I spend money on remapping, I also intend to pull out ecu and make sure the sensor for bossy preasure is functioning / clean first if you do the ecu bit be aware I have been informed the pipe on the sensor is very fragile.
    Jan 2014
    20
    My home made pressure gauge made from redundant parts at work, gave me an indication of what my turbo is up to didn't boost until 4000rpm, note hand written amendment done by engineers being funny at work.
    Jan 2014
    20
    Can I have the link for the turbo clean
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    439
    It's in the stickies mate
    And that's quite clever
    I forgot about this thread until now too
    Still haven't git one yet
  1. Boost gauge fitting help
    By millsy75 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th March 2013, 18:59
  2. boost gauge help
    By derek84 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th April 2012, 21:05
  3. Boost Gauge help please...
    By MarkTweedley in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th September 2011, 21:07
  4. Boost Gauge Fitting Help Needed...
    By tonya4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th May 2011, 21:37
  5. Digital boost gauge
    By Mo-S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th May 2003, 23:42
