Dan TheMan Welburn
I posted recently about having my lower arms replaced and still having a wobble, well put it back on the ramp today and had a little feel around, and there is massive amounts of play in my o/s inner driver shaft it seems if at least one of the bearings has collapsed, im told that the inner part is not replaceable?
Obviously dont wanna spend over £200+ on a new driveshaft, looking around at used and there are obviously different part numbers, checked on vagcat the the part number listed for my engine code is 8E0407272S, but this is apparently compatible for all the following engine codes too....
So can i use them off these codes? or am i best looking for a good one from same car, 2002 1.9tdi awx 5 speed??
drive shaft with constant velocity joints right / ASN,AWX,BBJ, AVB,AVF,AMM, BDV |
