Volks AutosMonster Motorsport
Results 1 to 8 of 8
    glenandem's Avatar
    Sep 2012
    manchester
    528
    1.9 tdi engine mount fault code on vcds
    hi guys,getting the int fault code on engine mount on my vcds and it wont clear, ive checked the mount with the plug on it quickly and no leaks but has a buldge in the rubber holding the fluid in, couldnt see the other mounting on drivers side as it was too wet to get underneath but will check it, now im getting a bad vibration when setting off and best way to stop it is to slip the clutch with high revs and im getting a monster vibration at mway speed, could this be due to a engine mount or could it be the dmf, the engine doesnt idle bad neither does it shake the car bad either unless setting off or on mway.
    im just not sure which to go for,if the drivers side mount isnt leaking am i right in thinking dmf and thats causing the engine mount fault code but then again the code wont clear even when im stationary so no had time to rattle the engine again to set it off????
    confuseddddddd!!!!
    May 2012
    RETFORD, NOTTS
    1,753
    Im not too sure but these engine mounts stiffen up at speed, and slack at idle to reduce vibrations i think i read this somewhere. If the mount is bulging and you have a fault code, id replace it!
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    glenandem's Avatar
    Sep 2012
    manchester
    528
    jacked the engine up today while i was fitting my s line lower and the drivers engine mount looked spot on and was still together after trying to gently jack the engine up so its not separated!
    cant understand why im getting the fault when it all seems ok,no leaks etc?
    Jun 2012
    Teesside
    448
    Have you checked the passenger side? thats the side that has gone on mine, i will get round to it one of these days, but wont pay tps price of 100quid for a new one, german ebay however do sell them new at half the price
    Mods done: interior: Light to dark conversion, To Do: Carbon trim, carpet to be replaced, rear window retrofit. Exterior: Resprayed in Skoda's Rallye Green, 18" RS4 reps fitted, xenons, LED sidelights/NumberPlate lights, B Pillars wrapped in carbon. To Do: Lowering 35mm all round, tints, Tuning: Yet to do exhaust/remap/ egr delete etc..
    glenandem's Avatar
    Sep 2012
    manchester
    528
    hi mate,checked that yesterday as you can pretty much see that by looking in engine bay but did have look underneath and there wasnt any red fluid or any sort of wetness as i thought thats what makes them go faulty?
    crazy88's Avatar
    Loving the anonymity
    West Yorkshire
    4,806
    Re: 1.9 tdi engine mount fault code on vcds
    It's not just a wiring fault is it? Checked the cables are all ok?
    glenandem's Avatar
    Sep 2012
    manchester
    528
    yeah ive not checked the wiring loom or plug yet, just checked for leaks splits etc but next thing to do!
    Jan 2012
    KERNOW
    107
    I changed both of the engine mounts on my b7 as i was getting a really bad vibration at 1750rpm. When i had them out i could not see anything wrong with them compared to the new ones but it did cure my problem.
  1. a3 2.0 tdi BKD 8P fault codes after remap!!! worried!!!
    By chrisy t in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd April 2012, 18:24
  2. 2.5 v6 tdi engine mount swap
    By swarcup in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th September 2011, 21:47
  3. A6 1.9 TDI engine management ? - diagnostic codes
    By oxford_hippo in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 18th May 2010, 23:15
  4. 2.0 TDI engine mount failure
    By pioneer181 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th February 2010, 15:27
  5. 2005 A3 TDI - pile of fault codes
    By timcoupe in forum VCDS (formerly VAG-COM) forum
    Last Post: 18th September 2009, 12:46
