Hi guys I've got a vagcom so I can code my transponder but need the skc which I believe dealers can't even get anymore as it comes from Germany so I believe vagtacho is my best shot but will it work with my b6 1.9tdi 03 ecu?
Hi there,vag tacho should be able to retrieve the skc from your dash as I've done it on my mkiv golf.You will need a newer version than 2.5 as I was unable to retreive it frommy 53 plate A4 using 2.5.
hth M
