Volks AutosChris Nott
    7
    Drivers door lock will not unlock with key - HELP
    Audi A4 2004 1.9tdi avant
    I had a major issue last night whereby the remote key fob shorted out or something and stopped working altogether, which was bad enough, but ony then did I discover that the only lock on the car wasn't working !
    The drivers side door lock will lock if I use the key (turning anti clockwise) but if I turn it clockwise - Nothing ....
    In the end the AA man turned up and managed to get in (by powering up the ignition (after removing the engine under tray / sump guard, and connecting his external power source to the wiring loom at some point in the underside of the engine bay) and then jamming the door open far enough to use a rod to lower the electric window)
    He reckoned that its not an uncommon fault for a microswitch / chip in the locking mechanism to fail and cause this sort of thing. I'm taking it into Audi tomorrow, but does anyone have experience of similar issues, and have a guess at how much its gong to cost to fix ??
    **Incidently ... After having the key in teh ignition with the engine running for a few minutes, it came back to life and appears to be working perfectly again ! Still need to get that lock fixed though in case it ever happens again ...**
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,713
    new micro switch could be mega money unless you have a friend like me with a box of 2nd hand parts..........
  1. Door Lock/Unlock button replace
    By paul_e88 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th February 2012, 20:46
  2. Lock the car with key and drivers door opens again!!
    By jonnycraig in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th January 2011, 21:55
  3. Key Fob Just Stopped Working Lock/Unlock not working
    By tomgreen78 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th March 2010, 23:53
  4. a4 drivers door lock
    By MIDCO in forum Diesel forum
    Last Post: 5th December 2006, 12:50
  5. Key/Alarm/Lock-unlock question.
    By pipewerkz in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th November 2004, 22:50
