Monster MotorsportChris Nott
Results 1 to 15 of 15
    biyitch's Avatar
    Chocolate? It's doo-doo, baby!
    Southampton
    300
    RNS-D to RNS-E...Again
    I've bought an RNS-E for my S4 but I want to make sure I'm getting the right cables.
    I considered an eBay special but I'm worried it'll be a waste of money if it isn't compatible with my CD changer and Bose sub and amp.
    On the other hand, Kufatec do an RNS-D to RNS-E upgrade kit, although £70 + shipping is way overpriced.
    Doe anyone have a recommendation please?
    Audi S4 Avant (B6, 2004) in Goodwood Green.
    Jul 2011
    Cornwall
    205
    biyitch's Avatar
    Southampton
    300
    Ah, see the couple I found were in the vehicle parts section. I didn't think I'd need to look in 'consumer electronics'.
    Do you know if that'll cover everything? I keep hearing about this 'Bose wire'.
    Jul 2011
    Cornwall
    205
    Not 100% sure on that, someone will come along and advise.
    biyitch's Avatar
    Southampton
    300
    OK, I gave it a go and I got the thing powered up.
    Only radio though. I didn't try an SD card but it didn't recognise the CD changer. I have a 'C' model so I might need to buy a 'D' model.
    I was left with one old connector with no home. Does anyone know what it's for?
    There was a similar sized 32-pin socket in the back of the RNS-E but it didn't seem to fit (although I might have had the lock handle in the wrong position).
    The only other concern is Bose - I can see an empty Bose pin hole on adapter harness I got from eBay but I don't know where it would be coming from in the car's wiring.
    Lancaster
    1,623
    Did you have TV or anything extra on the D?
    To do: None yet.
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    946
    That 26 pin connector carries the CAN-BUS-L(26) & H(13) signals and a few others - this connector is unique to the RNS-D unit.
    Here is a link to wiring from RNS-D to RNS-E.
    CD may not work if you have not coded the RNS-E to tell it to look for the respective add-on units. Look here for coding information.
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
    biyitch's Avatar
    Southampton
    300
    Quote Originally Posted by Woorlord View Post
    That's very interesting.
    I'm still perplexed about the Bose wiring though - I've no idea what I need to do.
    Is that table saying I have to ground RNS-E pin B/7 and vehicle pin 10, then connect RNS-E pin D/14 to a 'large brown single-pin connector'?
    I've been told the changer doesn't need coding but I was gonna get it checked anyway.
    Perhaps with the use of SD cards there will be no need for a CD changer anyway but it would be nice to have it working without having to spend any extra money.
    Woorlord's Avatar
    Dec 2007
    Tiptree, Essex
    946
    RNS-E D/14 can stay disconnected - it is on my loom. (I went from Concert II to RNS-E). My alarm works fine and I get no errors on scanning.
    RNS-E pin B/7 to Connector III/Pin 1 - (this can also stay disconnected and the Bose will still work if all the other connections are made for pre-amp signals and amp power on etc.). I have got a feeling that my loom did not have this wire added as it was non-Bose - I recall adding two pre-amp wires signal. I have full control of Bass/Treble etc. on the RNS-E. My RNS-E is software coded to tell it I have BOSE - my coding is 0309752 have TV input and Aux input and BT phone - the 9 tells it I have Bose, changing this to 1 would be a non-Bose set-up. I have no external CDC.
    You can purchase repair wires from Audi and insert missing ones into the plug housings. I was sold a non-Bose adaptor loom by mistake, and added them to make it work, i.e. added the Rear pre-amp signals for the Bose amp - 2 wires, (LR & RR). All repair wires can be identified here.
    CD Changer may or not need coding, but if it is not working suggest you check all wiring for it - can you eject and insert CD's?
    Can you see the CDC option in the source menu?
    Not using a CDC myself as utilised Video input for i-pod sound and video.
    There is a lot that needs to be checked for 100% correct coding and adaption - including getting instruments unit (Module 17) recoded to show Nav instructions, etc.
    It all depends on what the donor vehicle had fitted and what this RNS-E was matched too.
    biyitch's Avatar
    Southampton
    300
    Oh, OK.
    I saw that reference in one of your other posts:
    RNS-E Coding is required......
    Coding
    • 0?xxxxx: Model
      • 1 = Lamborghini
      • 2 = Audi A3 (8P)
      • 3 = Audi A4 (8E)
      • 4 = Audi A4 Cabriolet (8H)
      • 5 = Audi A6 (4B)
      • 6 = Audi TT (8J)
      • 7 = Audi R8 (42)
    • 0x?xxxx: Treble Speaker Monitoring inactive
      • 0 = Front Treble Speaker Monitoring inactive active (NOT Audi A4 Cabriolet)
      • 1 = Front Treble Speaker Monitoring inactive inactive (ONLY Audi A4 Cabriolet)
    • 0xx?xxx: Sound Characteristic...
    Can you tell me what the red bit means please?
    Also, what does this mean?
    Channel 007: Options
    Channel 008: Volume Characteristic
    I went down and put the RNS-E back in and I left it installed this time since the SD cards work fine and the sub/amp is working.
    As for the changer, it powers up and I can eject/load discs but it's not a source option on the RNS-E.
    I'll pop into my garage next week and get them to code it properly.
    There is another unidentified connector. The black bit of plastic swivels around to keep it in place:
    Here's the unplugged connector:
    Lancaster
    1,623
    Looks like the GPS antenna connection.
    To do: None yet.
    Woorlord's Avatar
    Dec 2007
    Tiptree, Essex
    946
    Quote Originally Posted by biyitch View Post
    Oh, OK.
    Text you highlighted in red - Not sure, but by explanation you set to 0 for Saloon or Avant and 1 if Cabriolet.
    refers to settings stored from within RNS-E settings menu,
    +01: Distance in miles
    +02: Speed in mph
    +04: Time in am/pm
    +08: Date in MM:TT;JJJJ
    +16: Repeat Voice Commands
    not necessary to set this with VCDS - just use the RNS-E menu to set.
    refers to GALA setting as follows,
    000: Speed dependent volume control (GALA) OFF
    001: Characteristic 1
    002:
    003:
    004:
    005: Characteristic 5
    255: GALA via Mic (Bose AudioPilot)
    Set this to 255 if you have the new MIC activated BOSE (post 2004), otherwise selectable via RNS-E menus
    biyitch's Avatar
    Southampton
    300
    Thanks.
    Is that where the volume changes with road noise? Mine does that. The registration date on mine is January 2004.
    biyitch's Avatar
    Southampton
    300
    Quote Originally Posted by BlackQuat View Post
    Sounds about right. Cheers.
    biyitch's Avatar
    Southampton
    300
    Job done!
    You can see details of the resolution here.
  1. Upgrade BNS 5.0 / RNS-Low with RNS-E
    By markhaines in forum In-Car Entertainment
    Last Post: 29th January 2012, 21:41
  2. Replies: 9
    Last Post: 13th August 2011, 13:12
  3. Replies: 1
    Last Post: 11th August 2011, 17:17
  4. RNS-D to RNS-E, now glovebox cd changer doesn't work......
    By Az in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th August 2011, 16:36
  5. RNS-D to RNS-E upgrade, old stuff I know but help needed in Technophobe speak please
    By Bluevane in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st May 2010, 09:41
