EM TuningKowalski
Results 1 to 9 of 9
    Sep 2011
    strabane
    11
    Post Thanks / Like
    help... i have a 01375 code coming up on the computer for my 02 2.5tdi quattro...
    does any1 kno anything about this code i kno its something to do with engine or valve mounts but i kno nothing about them.. what do they effect and were are they located in order to be fixed?? any info wud be much appreciated thanks..
    quattrojames's Avatar
    Mar 2008
    Dorset
    10,962
    Post Thanks / Like
    It refers to the engine mounts, it's a common issue.
    Have you checked the Ross-Tech Wiki?
    01375 - Ross-Tech Wiki
    If you search on here there are several threads discussing the issue and the costs to resolve it.
    Have a browse of rule 4 too when you get 5 minutes please. Thanks
    Audi-Sport.net Rules & Usage Guidelines
    2003 A4 Avant 2.5TDi quattro
    To do: Joey-mod headlights - Twin Exit Exhaust Conversion - Puddle light and Footwell light retrofit - Rear roof spoiler.
    WANTED: Unpainted standard front & rear lower valance (with twin exhaust cut outs) - from someone who's doing an S-Line upgrade.
    audigeezA4's Avatar
    Mar 2011
    104
    Post Thanks / Like
    lol......sorry i meant to say laugh out loud!!!
    Sep 2011
    strabane
    11
    Post Thanks / Like
    'laugh out loud' i do apoligise it just becomes habit unfortanately but many thanks and il check out ross tech wiki many thanks
    Aug 2011
    116
    Post Thanks / Like
    Sep 2011
    strabane
    11
    Post Thanks / Like
    thanks people i have a better understanding now although i would never have noticed other than plugging it in is there any other symtoms that this problem causes? or tell tale signs?
    Mar 2008
    Dorset
    10,962
    Post Thanks / Like
    I've had my car nearly five years, for the last three years it's showed this fault code, I've never noticed the car behaving any different. I'll do it one day.
    Sep 2011
    strabane
    11
    Post Thanks / Like
    When i was flicking threw a few different threads i noticed a few people say that it effects gear change and rattles and that, i then when listening carefully noticed a ticking or rattling noise every time i accelerated and was wondering if they would have been connected? i thought it sounded like a pulley at first but i only replaced all the pulleys and timing belt around 4000 miles ago?
    Aug 2011
    116
    Post Thanks / Like
    Mine comes up with the same fault, clear it and it comes back. I notice a small movement in the gear stick when I let off the power. It's their and will get done in summer. Doesn't seen to effect the car otherwise as far I can see is ok
  1. Code needed for egr shutoff on A4 2.5Tdi Quatt
    By Mackers in forum VCDS (formerly VAG-COM) forum
    Last Post: 17th December 2011, 13:44
  2. 01375 fault code ??
    By DAZ1985 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd October 2011, 19:23
  3. 2.5tdi engines code
    By willieigs in forum Diesel forum
    Last Post: 19th April 2011, 01:22
  4. 2.5Tdi dash swap skc code needed!
    By cheezeberger in forum A6/S6/Allroad forum (C5 & C6 Chassis)
    Last Post: 14th January 2009, 14:46
  5. help!!! 2002 2.5tdi in silver paint code
    By davidsmith110 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th January 2008, 15:02
Click Here To Chat Live
