JMB RetrofitsSky Insurance
Results 1 to 32 of 32
    Louis Cronin's Avatar
    Apr 2010
    67
    Cab radio signal...
    Hello people,
    I hear this is a common problem with cabs, the wire which runs to the boot throught the right side tubing stretches and breaks.
    Has anyone fixed theirs?
    itsmeagain's Avatar
    1.8T Sport Cabriolet
    Mar 2010
    West Midlands
    435
    My radio reception is the same, sometimes it works other times its shocking. I have been meaning to sort it out but keep putting it off.
    Audi A4 1.8t sport convertible, Full Grey Leather Interior, Ambient Light Pack, Polished Forge FMCL007P Diverter valve, Green Cotton Filter, 100mm Tail pipes, Rear RS4 ARB, Interior Xenon White LED's bulbs, Xenon White LED number plate bulbs and side lights, JBS Auto Designs stage 1 remap, RNS-E and OEM Bluetooth, Remote roof module, OEM Wind Deflector, B7 rear lights, HID lights.
    Apr 2010
    67
    I've tried hitting it but that didnt work. Im fresh out of ideas now... anyone?
    Aug 2009
    16
    Mine was doing the same, opening and shutting the boot made it worse!. The cable from the signal amplifier runs in the loom on the left hand side of the boot - this is usually where the cable work hardens and breaks. Managed to fix mine by buying a replacent cable from my local audio shop and spliced it on to the existing cable on the car body side of the loom. Works fine now and is easy to replace if it fails again.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,492
    as above you can get the repair wire from audi
    you can cut and join but iv always replaced the full wire
    hours job quite easy
    Gabsy1972's Avatar
    Mar 2011
    15
    does anyone have a pictures of how, and where the wire is? i would really appreciate it. Carl
    Mar 2009
    470
    Quote Originally Posted by Gabsy1972 View Post
    I would greatly appreciate a few pics too to give me a bit of a start and a couple of pointers to do this fix aswell.
    If anyone can, please.
    B6 S4 4.2L V8 Cabriolet Black Manual Quad Milltek Non Res
    bez101's Avatar
    Jul 2008
    8,492
    just take the boot liner off look on your left the amp is there and its the wire with the blue plug
    follow where it goes its realy simple
    Mar 2009
    470
    Bez, thanks for reply, is the boot liner in the boot lid or is it some trim around the boot floor or sides. Sorry if question sounds stupid.
    bez101's Avatar
    Jul 2008
    8,492
    sorry yeah its in the boot lid
    if you remove that take a pic and ill point out the wire for you
    Mar 2009
    470
    Ok mate, will do.
    Mar 2011
    19
    Hi, I've got this problem too. Couple of numpty questions, is it Cab specific or does it affect all B6's? I've got a saloon, and my radio reception has suddenly gone.
    Also, how the hell do you remove the boot lid liner? I gave it a good yank and thought I was going to bust it (so left it)
    cheers,
    bez101's Avatar
    Jul 2008
    8,492
    on the b6 its not in the boot its in the back window trim
    search it on google theres a few how to's
    Jul 2011
    Buckinghamshire
    55
    hi mate did you get Picture taken of boot problem? need to do mine now got the same problem!
    thanks
    Mar 2009
    470
    I haven't had any time to look at it yet, sorry. Will prob be a while before i get chance to.
    Mar 2009
    470
    Bez, were you referring to saloon and avants only or do you know if the cab is the same.
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,582
    I've found a few links with google searches, but nothing that great - if people find any really good guides (for the saloon in my case), then please feel free to share.
    Do you really just pull the headlining down above the back window?
    LostBok/BahnStormer77
    Jan 2009
    150
    I have this problem aswell, no radio reception at all. Ive had the boot lid liner off and cant see any thing in there. Does anyone know exactly where I need to be looking on a b6 saloon?
    BahnStormer
    Feb 2009
    Surrey
    2,582
    I think it's inside the cabin, in the headliniing, above the back window..... but I'm not tryign to pull that stuff off until I know wha ti'll need to put it all back together again!
    Jan 2009
    150
    Think this will help, shows all locations of all audio components
    http://www.audicrazy.com/B6A4/Bentle...4_B6_Radio.pdf
    BahnStormer
    Feb 2009
    Surrey
    2,582
    nice work on this one Gaz!!
    Quote Originally Posted by Gaz! View Post
    BahnStormer
    Feb 2009
    Surrey
    2,582
    Anybody know if you can tell which part you'll need BEFORE you pull the headlining apart?
    I can see literally dozens of part numbers in VAGcat, mostly starting with: 8E5035225.
    Also: since my RNS-E was retro-fitted, should I be trying to match the aerial booster to one of the "for systems with navigation" boosters or just match the original?
    I'm guessing there's not that much difference, since they only seem to specify a different one for the Avant, not the Sedan, but there's also a naggging feeling of whether it was the upgrade that caused the booster to fail in the first place, so I'd rather make sure I got the right one.
    Jan 2009
    150
    I have wipped the head linning off and found my amplifier and the reason for failure.
    It has a crack running along it that I can only assume has happend through temperture fluctuations. The part number is 8E5 035 225 D.
    I have done some research and found it to be a common fault.
    Found here in this post, Anyone know why the antenna booster cracks and breaks? Been searching and it's common.. - AudiWorld Forums I have exactly the same problem and have found lots of others have the same.
    I have also found that the part number is supercedded to 8E5 035 225 S, this is beefed up and shouldnt fail.
    The cost from Audi, £140....... for a piece of printed circuit board.
    reggieroo's Avatar
    Worcestershire
    260
    We have the same problem with an A4 Cab, no radio at all.
    Audi S6 Avant 4.2 V8 Quattro 340bhp, 19" OEM RS6 alloys, running on LPG.
    Jul 2011
    Buckinghamshire
    55
    Have a quick Chat with NHN he knows a little about this problem fixed my A4 CAB few days ago I was having the same problem
    27,099
    I will check those pics Carl, for cracks, didnt notice any mate huh.
  28. #27
    Jul 2011
    Buckinghamshire
    55
    hi mate.... happy with it as it stands all good still waiting for steering wheel? aqny joy on ampire DVB-T....do I need anything else to go with it?
  29. #28
    Aug 2012
    I have a 2005 Audi A4 cab and live in New Jersey, USA. I need help finding an audio technician who is familiar with doing this repair. I took it to one shop where we accessed the module with the three wires. Even with the length of wire (previously covered by the rubber tubing) exposed, we could not find the damaged part of the wire to cut & splice in new wire. Also, the tech said the wire is a coaxial type that cannot be spliced. Is that true? I really want to do this repair myself but need some guidance. If you can help me, I would be most grateful. If not, 1) can you tell me where to find the correct replacement wire and 2) can you recommend a technician in the NJ/NY area who can do the repair? Thank you.
  30. #29
    bez101's Avatar
    Jul 2008
    8,492
    the wire you need is from audi as a repair wire.
    im in the UK so cant point you to a technician.
    but i have never cut and spliced i use the full repair wire and run it back upfront to the head unit
  31. #30
    Aug 2012
    Thanks for te quick reply. Last (I think ) question: Can you point me to a wiring diagram so I can try and replace the wire myself? One of your posts said it is a fairly simple job and I am kinda handy.
  32. #31
    27,099
    Nah you dont get coaxial repair wires, you get coax cables you can cut & splice, but you have 2 options, find the damage & repair via soldering/temp twist & tape or run new coaxial through with correct connectors on ends.
  33. #32
    Jun 2011
    13
    Quote Originally Posted by mzwolfie View Post
    Fixed my cab cable at the point where it runs between the boot lid and the main body. Don't worry about all that coax rubbish, we're not listening to faint radio signal on alpha centauri. I just soldered/spliced a piece of wire in across the central core and then wrapped in a pience of insulating tape then twisted the outer shielding mess together but this leaves a shield gap. So I wrapped the whole repaired area in tin foli and wrapped in insulating it all together to make a neat job and stop it falling apart. Works fine. btw the A4 cab signal is notorious for dropping in and out anyway but this fix improves things as it keep the cable length optimum. I did think about extending the cable by adding an extra pice of wire at the repair point and running it across the boot lid or in the boot perpenidcualr to the exisiting cable to maximise reception. Will try it one day to see if it makes a difference and will repost.
