I have run a VAG scan last night - and the results are below - module 55 - Xenon range - I am assuming this is what would be faulty?? If so no fault codes found!! Driving to work this morning still faulty, although the warning light comes on and off - but the lights do not self level as I tested them
Any help would be appreciated
- will perform another scan later today - im baffled!
VAG-COM Version: Release 409.1-S
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01: Engine
Controller: 8E0 910 560
Component: 4.2L V8/5V G 0030
Coding: 0011711
Shop #: WSC 63351
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 8E0 614 517 Q
Component: ABS/ESP allrad 3032
Coding: 04595
Shop #: WSC 06435
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 08: Auto HVAC
Controller: 8E0 820 043 Q
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
No Faults Found
Address 09: Cent. Elect.
Controller: 8E0 907 279 F
Component: int. Lastmodul RDW 0416
Coding: 01011
Shop #: WSC 63351
Skipping Address 15-Airbags
Address 16: Steering wheel
Controller: 8E0 953 549 N
Component: Lenksáulenmodul 0308
Coding: 00041
Shop #: WSC 63351
Address 17: Instruments
Controller: 8E0 920 980 L
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 01400
Shop #: WSC 00658
WAUZZZ8E43A358411 AUZ6Z0C0013296
No Faults Found
Address 45: Inter. Monitor
Controller:
Note: Excessive Comm Errors
Address 46: Central Conv.
Controller: 8E0 959 433 BC
Component: Komfortgerát TBF 1712
Coding: 06859
Shop #: WSC 00726
1 Fault Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
Address 55: Xenon Range
Controller: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 63351
No Faults Found
Address 56: Radio
Controller: 8E0 035 195 P
Component: symphony II NP2 0152
Coding: 01200
Shop #: WSC 00636
No Faults Found
Address 76: Park Assist
Controller: 8Z0 919 283 A
Component: Parkingsyst. A4 RDW D09
Coding: 00104
Shop #: WSC 63351
No Faults Found
End --------------------------------------------------------------------------------------------------
