Badger5JMB Retrofits
Results 1 to 34 of 34
    S3 Owner
    Sep 2009
    Midlands
    123
    Just Had Revo Installed - Question and Concerns.
    Hi all,
    I had Revo stage 1 installed yesterday (59 plate S3 with DSG) and I have to say that so far I`m not that impressed, when I remapped my old Focus ST the difference was astronomical but with the Revo the S3 does not feel that much faster than standard to be honest.
    Does it start to loosen up over time or does this indicate that something is not quite right? I am going to give the car a few days but if it still feels the same by the start of next week I may take it back to the Revo dealer and ask them to take a look .... or am I just expecting too much?
    Opinions appreciated please.
    East Sussex
    618
    It depends on how they have set your car up, I got to say with mine it made a substantial difference, and even more notable when it was removed. but with that engine there is not a great deal you can do on a DSG at the bottom end, (ofc unless you spend an arm and leg), but after 2.5k revs you should notice a difference for sure all the way up to the red line.
    Jul 2003
    Berkshire
    34
    I had my S3 Revo'd (Stage 1) last week and as part of the remap, some elements of the ECU are reset so the car has to re-learn various settings such as fuel octane, timing and other settings, some even relating to your individual driving style etc. AMD advised that you need about 4 hours of driving time before it's all settled so make sure you've given it at least this long...
    With that said, my S3 has always felt quick and I even ran some data through VCDS to check if it wasn't already mapped. Turns out it wasn't and I've only done a couple of hours driving since the map and can already feel a huge improvement in performance . Whoever mapped your car should've checked first to ensure it hadn't been mapped previously and would've also checked the car on the road to make sure all was running well before mapping it.
    If everything else checks out ok then as a last gasp hope, your car will be slower in hot weather so today isn't the best day for comparison!
    Hope that helps,
    Pete.
    BOSSS3's Avatar
    Sep 2009
    South Africa
    119
    Needs time to adapt just give it a few miles and then you will see magic happen!
    2008 Audi S3
    REVO Stage 1
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,050
    It should feel MUCH quicker straight away.
    If it doesnt then something is wrong.
    Maybe the settings are incorrect?
    Go back to the REVO agent and have it checked, including the settings.
    For your info I am running.
    Boost 7
    Timing 6
    Fuel 9
    Always ran on Shell VPower and the car does improve further as the ECU adapts
    Good luck
    Paul
    Now:
    -MK2 Golf Gti 16V/VR6, Oak Green, Shrick, Intake, Decat, Kish Retrim, Lenso BSX..
    -BMW 335d Xdrive, Estoril Blue, fully loaded.
    Before:
    S3 (8P), Ibis, DSG, Milltek, SHARK
    BMW 320d M Sport
    S3 (8P), Sprint, REVO, H&R Springs, BBS CHs,
    Golf MK5 GTi 20TFSI - REVO Stage1, Red.
    Golf MK5 GTi 20TFSI - Std, Shadow Blue
    Civic Type `R`
    Golf MK4 GTi 18T - 200bhp, MTM ECU, Forge DV
    Golf MK3 VR6 - Cat Back
    Corrado VR6 - JAMEX
    Corrado G60 - JAMEX, BRM Charger rebuild
    etc....
    akash_sky1's Avatar
    Glasgow (Sheffield occas.)
    1,209
    if it was already mapped wouldn't the tuner have realised? As said you need a few hundred miles for the ECU to fully adjust to the new parameters. but check there's not faults such as with the diverter valve.
    A3 2.0TFSI quattro Sportback Lava Grey | | GIAC K03 Extreme Map | Autotech HPFP | RS4 Fuel Regulator | Neuspeed P-Flo | BSH PCV Fix | MV Sport DP | S3 Intake Cam | 285 BHP & 320 lb Ft Torque
    Votex Kit | TD Pro race 1.2 | Schwarze Audi Rings | Alu Rails | Sachs Clutch | H & R Now gone. Current- A5 Cab 2012
    Mar 2008
    Bradford, WY
    788
    sounds like they didnt load the ecu settings
    A3 2.0 TDI Optics Black S-Line, FR&RTuning Stage 3! GT20 Hybrid Turbo, THS TFSI FMIC, Sachs performance clutch kit+SMF, Milltek 2.5" Turbo-Back Non-Res Exhaust, ITG Maxogen Induction, EGR Delete with FR&RTuning Map out, Custom Black 18" RS4, 35mm H&R springs, S3 brakes, EBC Yellowstuff, front splitter, HID Xenons, S3 tailgate Spoiler, 09 Rear Lights, Retrofit Audi Ipod, S3 Air vents, Bose sound+retrofit JBL Subwoofer 1200W.
    Milltek Cat-back Non-Res for S3 2.0T FOR SALE both 3dr and 5dr PM
    KRL
    KRL's Avatar
    Jul 2007
    523
    Like PaulAR said check what settings you are running. If I put my car back into stock mode it feels extremely slow so I am guessing your settings may not have been configured correctly.
    Ice Silver S3 + every single option + REVO + BSH Street Can + Forge Twintake + Autotech
    S3 Owner
    Sep 2009
    Midlands
    123
    All,
    Thanks for the replies, the car has defo not been mapped before as I had the car brand new. I seem to recall the boost setting as being 6 but can`t remember the other 2 (although I was asked about what fuel I use - VPower) so as I said I will give the car a few days and then if need be i`ll go back to the Revo authorised dealer and ask them to check the car over (for info the car was taken for a test drive before the map was installed). I plan on giving it a decent run tomorrow morning so hopefully that will help, fingers crossed.
    Again thanks
    beanoir's Avatar
    Sharpest Tongue in the West
    Jan 2007
    51 Degrees North
    2,173
    I had mine ('10 S3 Manual) remapped with Revo software at AmD 2 weeks ago. I too was a bit underwhelmed for the drive home (about 30 miles) but I took it up to the Peak District the next day for the weekend, did a 500 mile round trip and by the time I was home I can assure you I was noticing a huge difference, and this weekend I had the chance to put it to work around the country lanes and I love it even more.
    So maybe some take a bit longer to settle after the ECU is reset than others, I dont know, but give it a couple of hundred miles before you make judgement.
    Also, did you not not get a rolling road print out before and after the remap? I did, and that quite clearly shows the difference!
    Porsche Cayman S |Jeep Grand Cherokee|1988 Ford Fiesta XR2
    www.essexdriversclub.com
    S3 Owner
    Sep 2009
    Midlands
    123
    I asked about a rolling road session but the dealer only had a 2 wheel drive setup so it could not be done, when I arrived the car was taken out and checked to see how it runs followed by connecting to VCDS to ensure there were no reported problems with the ECU. Then the remap and configuration was done followed by again connecting to VCDS to clear all the errors that the remap produced and then the drive home, my concern stems from the comparison made when I had my Focus ST remapped. When that was done the results were instantly apparent whereas with the Revo it just feels like a slight increase in torque rather than all out power. I am hoping it gets better but at the moment I feel underwhelmed as obviously the way everyone goes on about Revo I am expecting huge gains. Time will tell (as will a trip back to the dealer if need be!).
    Jul 2003
    Berkshire
    34
    Hehe that's funny Nick... would you believe AmD Surrey said they don't recommend rolling road checks anymore as they now see it as an uncessary risk with all the cooling required, risk of cars jumping off (!) etc. and that the ECU now measures everything and has all the safeguards and checks so you don't need to test power directly anymore. Could just be because Surey don't have a 4WD rolling road and Essex do!
    So out of interest, what was your before & after BHP at the wheels?
    beanoir's Avatar
    Jan 2007
    51 Degrees North
    2,173
    Quote Originally Posted by silstream View Post
    Well in fairness the guy who first served me said it wouldn't include a rolling road, but when I questioned it Ben piped up from the back of the office and said "he's the lad from the Audi Sport forum, we do the rolling road for those guys" They don't need to do it as the Revo software just gets downloaded and standard settings applied, especially if it's just a stage 1.
    My first run was 273bhp and 269lb/ft, following the re-map it was showing 306bhp and 299lb/ft. Ben said that will increase bu about 12-15bhp once the ECU has settled and it sure feels like it has over the last week or two actually.
    How was yours?
    beanoir's Avatar
    Jan 2007
    51 Degrees North
    2,173
    Quote Originally Posted by PaulAr View Post
    Boost 7
    Timing 6
    Fuel 9
    Good luck
    Paul
    Thats interesting Paul, mine was set up for V Power but my settings are:
    Boost 6
    Timing 5
    Fuel 9
    I wonder what difference that makes between the two cars...?
    JamesS4cab's Avatar
    Mar 2008
    1,122
    I have the same settings as you and couldnt quite get the timing to 6 as when we did this, it was over correcting and they said that this was due to needing new spark plugs. When I had mine installed, I did 4 or 5 flat out runs for 10-15 mins to make sure everything was perfectly set up and by the time we were done, it was really noticeable how much difference there was.
    "Dont get me wrong. Ugly girls need loving. Just not by me."
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,137
    Quote Originally Posted by taylorc View Post
    I'm not that impressed
    Need I say more
    Jul 2003
    Berkshire
    34
    Mine is running well Nick - no rolling road for me but good service from AMD and really noticable improvement (still haven't done 4 hours driving so more to come)... There's a definite increase in boost but car feels somehow smoother too... like everyone says, feels like it should have come from the factory like this...
    My settings are:
    Boost 7
    Timing 5
    Fuel 7
    Surprised you all have Fuel 9 as I use the 99 RON from Tesco which should be more than a match for VPower... Still not worried - car is getting better by the day and I'm already saving for induction kit & exhaust
    beanoir's Avatar
    Jan 2007
    51 Degrees North
    2,173
    Quote Originally Posted by N8 View Post
    Need I say more
    Yes thank you N8, we all know you have a mate who offers custom code.....yawn
    akash_sky1's Avatar
    1,209
    Need I say more
    .... and you have a friend who does Shark Performance remaps which are the best in the world!!!
    S3 Owner
    Sep 2009
    Midlands
    123
    I have just taken it for a bit of a run down a duel carriageway and I can definately say that there is not much (if any) noticable difference, admittedly I have not done many miles since the remap but I cannot see how the ECU adapting will make that much difference, ok maybe it might smooth things out a bit but the shove that I am expecting should be there right from the off (in my opinion anyway) so as I said before if things do not improve significantly by the weekend it`s back to the Revo dealer for me!
    Feb 2008
    2,817
    must be something wrong if thats the case. i'd take it back to whoever remapped it and see what can come of it.
    2000 AMK S3, Revo'd, forge 007p, B8's, H&R's, tarox g88's, ferrodo ds2500's, and in the fastest colour
    BOSSS3's Avatar
    Sep 2009
    South Africa
    119
    Well for me after I had mine flashed it did feel a bit quicker but after 60-80miles the car felt like a demon!
    2008 Audi S3
    REVO Stage 1
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,050
    Need I say more
    Doesn`t matter how good the product is, if the dealer gets it wrong, then you will be disappointed.
    In that scenario, you should draw the dealers integrity into question, not the product.
    How many times do we hear AUDI dealers making an arse of the product? Too many by all accounts.
    So does that mean AUDIS are suspect or the dealer?
    Answers on a postcard to the usual address.........
    Paul
    Now:
    Before:
    BMW 320d M Sport
    Civic Type `R`
    Corrado VR6 - JAMEX
    etc....
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Sod the postcard....Audi dealers are crap
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    I got a beutiful set of brand new face lift S3 alloys today Paul....can i be in your gang now ?
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,050
    Quote Originally Posted by paddy View Post
    How can I say no
    Now:
    Before:
    BMW 320d M Sport
    Civic Type `R`
    Corrado VR6 - JAMEX
    etc....
  28. #27
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Aww shucks......just need a T.Shirt now
  29. #28
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,050
    Just wait until your clutch starts slipping, then you will really be in the S3 club
    Now:
    Before:
    BMW 320d M Sport
    Civic Type `R`
    Corrado VR6 - JAMEX
    etc....
  30. #29
    phil76's Avatar
    Feb 2008
    SHEFFIELD
    564
    As has been mentioned above 1st port of call the dealer and the DV but surely they should have noticed the DV or did they/you not take it a test drive when it was done? also have they done the DSG software upgrade otherwise its just going to change up when it starts motoring will it not?
    Phantom Black S3,Giac stg 1,Evoms intake,Lamin-x
    (to do list,update signature pic)
  31. #30
    S3 Owner
    Sep 2009
    Midlands
    123
    I have just taken the car back to Aldon Automotive to check my Revo settings and everything was set correctly (Boost = 6, Timing = 4, Fuel =9) so they checked the diverter valve (apparently it`s common for them to split) but this was also ok.
    Revo suggested taking the car out for data logging so that the settings can be changed to a safe limit and they have now been amended to Boost = 7, Timing = 6 and Fuel = 9. Now the car feels much better and hopefully as the ECU adapts it will get even better with time
    Also, I can`t praise Aldon Automotive enough, the service was fantastic and they didn`t charge for checking the car over or the data logging. If anyone in the West Midlands area needs a good tuning company I would certainly recommend checking them out
  32. #31
    tku
    tku's Avatar
    Sep 2009
    639
    Boost - 7 Timing - 6 Fuel - 9 were the settings that Revo put on mine when I got the car remapped by them. I can definitely notice the difference..Just wondering how come you actually started off with 6 - 4 - 9 ..They also put 9 - 7 - 9 for when I'm running good fuel with cool weather.
  33. #32
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,137
    LoL at you guys, Revo is amazing software, its why I don't have it.
  34. #33
    chrissy1502002's Avatar
    Portsmouth'ish
    247
    LOL @ N8
    Brilliant Black A3 2.0T S-line Quattro Special Edition. S3 front brakes, Turbo back Milltek including race cat, APR Intercooler, Evoms air intake, AMD Stage 2 map, Upgraded OEM DV, Sachs Race Clutch, SMF conversion, Forge short shifters, S3 wing mirrors, S3 Rear end, Interior LED conversion, Bi-Xenon's, LED DRL's, BBS CH's, MY 09 Rear lights, Full leather, Tinted rear windows, Custom black front grills.
  35. #34
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,137
    Glad some1 is having a laugh on this forum, because its f**king hard work at times tbh
