Sky InsuranceJMB Retrofits
Results 1 to 9 of 9
    Sep 2005
    Jhb - South Africa
    85
    2010 Audi S3 Sportback - alarm beep - VCDS
    Hi All,
    I have just taken delivery of my new S3 Sportback S-Tronic.
    On VCDS, I am some how not able to access the central convenience. I am trying to activate the beep on locking the car with the fob (key), and I am not winning. Does any one have a clue how to do this on the VAGCOM/VCDS.
    As a side note, I activated the windows open/close on the fob from a function on the DIS. I also can not access this module on VAGCOM/VCDS.
    Thank you in advance,
    Ved
    2010 Audi S4 (S-Tronic)
    2010 Audi S3 (Sportback, S-Tronic)
    ex cars :
    2007 Audi S3
    2007 Audi TT (S-Tronic)
    2006 Audi A3 2.0T
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,166
    You can't even access the module you mean? Can you access the others ok?
    8P2 S3
    KRL
    KRL's Avatar
    Jul 2007
    523
    Might be a stupid question but did you have the ignition switched on?
    Ice Silver S3 + every single option + REVO + BSH Street Can + Forge Twintake + Autotech
    JohnS3's Avatar
    Oct 2004
    3,021
    Are you using a real Ross Tech cable or a copy?
    27,013
    It could very well be you have such a new module that vagcom isnt aware of, saw this recently on another new S3 on here, think need to do a complete scan then send to RT if you have a genuine cable, otherwise they wont help.
    Sep 2005
    Jhb - South Africa
    85
    Yes, I have a genuine cable.
    Yes, the ignition on.
    Yes, I have been using VAGCOM for the last 4 years. Used it extensively on my previous S3.
    @NHN : Who at RT do I need send the scan to ?
    ex cars :
    2007 Audi S3
    2006 Audi A3 2.0T
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    have you updated your vag com fully?
    Phil_T's Avatar
    Revo Stage 2+ Audi S3
    Oct 2009
    236
    It was me, our cars are new so they havent release a module yet so I cant change anything he emailed me something back but I dont have a clue what he means
    Revo Stage 2+ - Miltek Non Res Turbo Back Exhaust - Evoms Intake - Autotech Fuel
    Pump - Forge DV - Sachs Clutch - BSH Engine/Gearbox Mounts - BSH PCV Mod - RS4
    FPR Valve - Airlift Performance Struts With Adjustable Top Mounts & Droplinks with Accuair Management - H & R Anti Roll Bars - 42 Draft Designs Shifter Bushes - BBS E28 Magnesium Motorsport Wheels - Piano
    Black Optics Grill & Fogs - Piano Black Door Mirrors - Carbon Fibre Front Splitter & Rear Diffuser
    27,013
    Yeap it was Phil if you PM me what he sent you maybe I can have a looksy & see if can understand it.
