EM TuningMonster Motorsport
    Audi a3 2.0TDI 2004 drivers door/central locking problems
    Hello Guys,
    New to the forum so apologies if i'm rusty.
    Problem with my drivers side door/central locking on my Audi A3 2.0TDI 2004 plate..Help!!.. 1st off all my immobiliser doesn't work, so I have to open/lock the door manually on the drivers side. This may be related to the other main problem which is on the drivers side door none of the electrics are working; the electric windows, electric door mirrors, the interior door lock & the lights are all disabled.
    M.O.T passed 2weeks ago, and battery was changed recently. No warning lights are coming on the dash.
    The passengers side is fine with the electric window and light working ok, so my guess is a connection has been lost or a fuse blown on the drivers side. In desperate need of your help as whenever I go to the stealers they always seem to rip me off.
    Charlie
    27,105
    Welcome.
    Check the fuse box thats on the end of the dash drivers side via removable end trim, chances are this has blown one, also remote battery would also be one to check aswell for remote lock/unlock, note this is not the immo system at all, immo would stop car starting, nothing to do with locking systems.
    [QUOTE=NHN;854250]Welcome.
    Thanks NHN much appreciated
    Sep 2009
    22
    just bumping this up as i have the same issue also lately any idea what fuse number or how to fix it
