Chris NottMonster Motorsport
Results 1 to 20 of 20
Thread: Misfire Help!!
    May 2008
    349
    Misfire Help!!
    My s3 has suddenly developed what i can only describe as a misfire, if i build the revs very slow then it seem ok and revs pretty freely in neutral. The problem is if i want to accelerate or drive fairly quickly.
    Power is lost and the car judders, i can also hear chattering as though i was backing on and off the throttle.
    My technical knowledge is pretty much zero but there was a lot of talk of the standard diverter valves failing, could this cause it?
    Or could it be something like the spark plugs or coild pack?
    the car is a 2007/57 s3 with 25k, was serviced a while back at Audi and has been running fine.
    I am using GIAC software and the Evoms so am in two minds weather or not to go straight to Audi or try a local garage and see if anything shows on a diagnostic check.
    Any ideas or advice would be great so i can pass it on to the garage.
    GIAC, EVOMS, H & R
    Khufu's Avatar
    West coast of Scotland
    5,693
    missing suggests coilpacks but I guess your best bet is to connect to a diagnosis lead to see what it says. Has the engine management light come on? Are these the same symptoms of fuel pump wear too?
    Jamiekip's Avatar
    Jan 2009
    710
    On our spec engines it usually comes back to injectors or spark plugs.
    Sparkplugs - Denso Iridiums seem to be the cure
    Injectors are a warranty job - do you still get the miss-fire issue on your standard map?
    Personally I would put your stock intake back on and flash back to the stock map and book it in with your dealer ASAP. Pain in the ass, but not worth giving them any ammo.
    Good luck
    Oct 2008
    888
    Have a wee look here. Mis-fire
    l havent had a misfire since lve also just put denso iridium plugs in mine.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,304
    Quote Originally Posted by Sohrob View Post
    Mine misfired at 6500rpm for a while after having the Revo Stage2 software installed,and after a session of datalogging,it was decided that we would try the coilpacks first(which weren't the problem),then the plugs(which also weren't the problem),and in desperation I had a go with a couple of packs of injector cleaner,as I knew the sort of reception I would get from my local dealer.
    This seems to have done the trick if not removed it completely,and I am sure that a few thousand miles worth of cheap supermarket fuel was the culprit,so that was a lesson learned.
    The coilpacks would be the first place to look,as this seems to be the most common fault,followed by the plugs,and leaving the most costly one till last.
    May 2008
    349
    Thanks guys, with the car being modded for round 10k miles or so i can only assume that something like the coils have failed or the plugs have worn out etc.
    For the last 13k the car has only EVER drank v power do i doubt its down to crappy fuel.
    Going to get a friend to hook it up to the diagnostics and see if that shows anything before putting it back to stock and trying Audi.
    Thanks again.
    GIAC, EVOMS, H & R
    Jamiekip's Avatar
    Jan 2009
    710
    If your mate had VAGCOM run some data logging too, might help throw up the issue
    May 2008
    349
    Also most people seemed to get there misfire very high in the rev range, my car gets driven right upto the limiter daily with no probs. The misfire im experiencing can be from as low as 2000 rpm.
    Not sure if he has vag com but they are able to reset service lights and run checks etc. Will this be the same?
    GIAC, EVOMS, H & R
    Mar 2009
    Cheshire
    374
    Had a misfire on mine just after I got it - diagnostics showed it was a faulty ignition coil, and sure enough one rusty coil replacement later it went away. I had the ECU light on though, so if you've not got that it seems less likely it's a coil failure.
    S3 (8V) S-Tronic Estoril Blue; A3 2.0TFSI S-Line quattro, Dolphin Grey [sold]
    Jamiekip's Avatar
    Jan 2009
    710
    With an injector issue it's always there, only sometimes it's so minor you can't physically feel/hear it. Data logging may expose it though.
    I'll be intereted to hear how they diagnose it... fingers crossed they nail it on the first for you.
    May 2008
    349
    Also had the car up at Awesome on the rollers 2 weeks ago and they didnt mention anything.
    Hmmm the joys of a non standard car, if i hadnt touched it i would be straight down to Audi.
    GIAC, EVOMS, H & R
    Spin140's Avatar
    Mar 2005
    Derbyshire, England
    2,013
    How very true but then you would be bored, got to be worth flashing abck to stock and see if the fault still occurs, if so take it back to AUDI.
    Good luck
    Wife - 12 BMW 320D 181 bhp, 8 Speed Auto, Melbourne Red, Heated Leather, privacy.
    10 S3 SB, Phantom, Buckets,Int light Pack, Privacy. (Sold)
    Golf GTi MK6 - Revo stage 2, ITG, Milltek Race TBE, AP Racing 4 pot BBK - Sold.
    10 S3 SB, Phantom, Buckets,Int light Pack, Privacy,Nav, Park sensors, 6 disc, Revo Stage 1, ITG Enclosed Intake - Sold
    BMW M135i F20 - Bloody good straight from the box !
    "Fast Cars are Safer...."
    Phantom black S3/
    Mar 2009
    137
    So what is a difference between a missfire and a fuel cut in terms of engine noise etc... ??
    Phantom Black S3/ APR stg 2+ / Forge CAI / APR HPFP / Miltek TBE / Forge DV / Forge Catch Tank / Forge T. body / VF Engine mounts / ECS EM / KW V3 / 19" BBS CH "Black" / 18" Team Dynamics Motorsort / Denso Iridium IK24 / Forge Twincooler / Helix Race Clutch + Flywheel / H&R ARBs / JVC Multimedia + TV Tuner / Kicker sound system over 3,000W RMS / TT-RS Steering wheel / Whiteline Anti-lift kit / Brembo Porsche GT2 BBK / soon: RECARO POLE POSITION SEATS,
    May 2008
    349
    4 new coils,good as new
    GIAC, EVOMS, H & R
    Sep 2006
    Surrey
    1,224
    Is changing the coils a DIY job? Also, how much did it cost all in. I'm getting misfires from mine quite alot =/
    Audi A3 (8P) 2.0TDI SE .:. Ebony Black, Sports Suspension, Vienna Beige Sports Leather Seats, Concert II & BOSE, 6 CD-Changer, Xenons, Acoustic Parking Sensors & All The Packs .:.
    Gone but not forgotten
    AuldReekie's Avatar
    Feb 2009
    UK
    766
    Seems the A3/S3 are susceptable to this. My engine management light came on the other day and Audi diagnosed sporadic misfire in two of the cylinders. It is booked in this Friday to have all the coil packs changed too. Warranty no arguement.
    Glad you resolved it.
    May 2008
    349
    Out of pure lazyness i didnt even take the car to Audi and have it done under warranty, end up costing 170 for the coils and fitting.
    Only needed one but i thought i may aswell do the lot.
    GIAC, EVOMS, H & R
    AuldReekie's Avatar
    Feb 2009
    UK
    766
    That's what Audi recommended too. If you have the problem with one or more, they will do the lot as subsequent failures are common.
    Not bad price you got though mate.
    Mar 2009
    Cheshire
    374
    Quote Originally Posted by emzino View Post
    When the bloke did mine it looked piss easy tbh - unplug, remove old coil, put new one in, reconnect.
    Sep 2006
    Surrey
    1,224
    Oh ok. Might have a go myself. Just need to get the coils then. I guess it's like changing spark plugs then
