AH FabricationsBadger5
Results 1 to 17 of 17
    kaz219's Avatar
    Jun 2008
    Manchester/Liverpool Uni
    1,796
    Aftermarket HU Help :S
    Hi guys.
    Car in question is my 2004/54 Audi A3 TDI S-Line DSG.
    I've got an Alpine Headunit but I've wired the RED and YELLOW wires together so it stays on permanetly untill i pull the face off.
    However, I now want the HU to go off when the keys come out! It gets a bit annoying taking the HU off when your just popping in somewhere for a min or so.
    I cant afford the CANBUS adapter but, i was told i could get a wire from somewhere and join it with another wire in the HU (im assuming the red one) to make the HU go off when the keys come out.
    I found Yoga's thread in the ICE section but it didnt say what wires.
    If someone could help, I would really really appreciate it :D
    My knowledge of any wires except what the wires in the headunit do is limited lol
    Cheers and Thanks in Advance!
    Audi A3 S-Line DSG - sold
    Golf Mk4 Autograph - sold
    Currently Vtec'in around in an Accord Type R :P
    For Sale: ST3 Remap Console - PM Me :P
    Vagcom'd too
    pns2007's Avatar
    Nov 2008
    627
    I believe you will need something like this. I had to get one on my last VW
    http://caraudiosecurity.com/shop/pro...s_id/8075.html
    (edit
    didn't see that bit!)
    redbutcher's Avatar
    Aug 2007
    Northants
    657
    So you'll be looking for a switched feed. In the 8p you can take it straight from the fuse box as I've done for my Parrot kit. MarcQuinlivan has a nice pic of the fuse you need in the post below:
    clicky
    Jon
    Now A3 less......
    kaz219's Avatar
    Jun 2008
    1,796
    Hmmm... So i just shove a wire in the fuse connector and conect it to the red wire on my stereo - sounds simple enough :D
    Thanks Redbutcher
    But will that not cause the fuse to blow?
    Vagcom'd too
    redbutcher's Avatar
    Aug 2007
    Northants
    657
    No problem mate.
    I'm guessing your yellow wire is a permanant live and the red wire is the switched feed.
    I don't think you'll have any problems with the fuse going though I'm not the worlds best car electrics bod on the forum (hopefully one of them can confirm this for you if they see this post).
    All I did was remove the fuse, wrap the wire around one of the pins and shove the fuse back in - works a treat .
    Jon
    Now A3 less......
    kaz219's Avatar
    Jun 2008
    1,796
    Quote Originally Posted by redbutcher View Post
    No problem mate.
    Nice one mate!
    Cant wait till its warm again!
    Get all this bloody mods out my bedroom! lol
    Are you over on uk-mkivs too - recognise the car in your avator!
    Vagcom'd too
    redbutcher's Avatar
    Aug 2007
    Northants
    657
    Quote Originally Posted by kaz219 View Post
    Yup - well spotted mate . I used to have a MK5 Golf so used to spend most of my time over there until I got the A3.
    Jon
    Now A3 less......
    kaz219's Avatar
    Jun 2008
    1,796
    :D Same ere - i use to have a Mk4 Autograph Edition - good cars the golf - mine just kept breaking down and when the gearbox blew for the 2nd time - i sold it lol
    Vagcom'd too
    GeoffT's Avatar
    Aug 2007
    Exmouth
    267
    You need to make sure you connect to the correct pin of the existing fuse connection. If you connect to the "supply" side, the new circuit will need it's own fuse in-line to protect it. If you connect to the "load" side, the new circuit is adding to the load on the existing fuse. Depending on the existing circuit rating it's possible the new circuit may overload it and blow it.
    The best way of doing it is to get a "piggy-back" fuse connector which takes 2 fuses, 1 to protect the original circuit and 1 for the new circuit created by the flying lead supplied . See below:
    A3 Sportback Sport 2.0 TDI 140 Mauritius Blue, Black/Grey matrix, GSM prep in armrest, MFSW, 17" 16 spoke wheels, Acoustic Parking rear, Cruise, Non-smoking pack, Symphony II+
    kaz219's Avatar
    Jun 2008
    1,796
    GeoffT - where can i get one from. Searched on the bay and stuff and cant find a decent one :S
    Looked on the bay and my local Incaraudio shop but nothing :S
    Thanks for that :D
    Vagcom'd too
    kaz219's Avatar
    Jun 2008
    1,796
    Vagcom'd too
    GeoffT's Avatar
    Aug 2007
    Exmouth
    267
    You're welcome, glad you found one.
    kaz219's Avatar
    Jun 2008
    1,796
    :D
    Vagcom'd too
    A3 3.2Q Sport
    Jan 2009
    73
    Quote Originally Posted by GeoffT View Post
    So which side of the fuse is the supply side then? i'm putting a parrot kit in and the kit has an inline fuse already so might as well plug it in that side...
    Apr 2009
    136
    Hello all, first post so be nice......
    I will be fitting my Becker Indianapolis to my 2004 A3. Am I right in thinking i will need this CAN-BUS adaptor for the pulse singnals and reverse sensor?
    If so, once I have this adaptor, what other lead will I need?
    and....
    Where is the best place for fascia that matches the current trim, Audi?
    Thanks all
    Apr 2009
    136
    Bump.... sorry
    Gti Jazz Blue's Avatar
    Feb 2007
    Hampshire
    1,654
    Quote Originally Posted by MattyV5 View Post
    and....
    Thanks all
    Not sure on the CAN-BUS interface but I can vouch for the Audi single DIN trim as I used that with my Alpine HU and it matches the rest of the dash trim perfectly (as you'd expect).
    Paul
    Gone not forgotten -
    92 Golf Gti Mark 2 16V.
    VCDS HEX-USB+CAN
